I am a Novice, I Encountered a problem when running the user guide's example. 1. Here is the test code public static void main(String args[]){ // Create Activiti process engine ProcessEngine processEngine = ProcessEngineConfiguration .createProcessEngineConfigurationFromResource("activiti.cfg.xml") .buildProcessEngine(); // Get Activiti services RepositoryService repositoryService = processEngine.getRepositoryService(); RuntimeService runtimeService = processEngine.getRuntimeService(); // Deploy the process definition repositoryService.createDeployment() .addClasspathResource("test/NewFile.xml") .deploy(); // Start a process instance runtimeService.startProcessInstanceByKey("financialReport");
2.Here is the configure file <?xml version="1.0" encoding="UTF-8"?> <definitions id="definitions" targetNamespace="http://activiti.org/bpmn20" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlnsmgdc="http://www.omg.org/spec/DD/20100524/DC" xmlnsmgdi="http://www.omg.org/spec/DD/20100524/DI" xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL"> <process id="financialReport" name="Monthly financial report process"> <startEvent id="theStart" /> <sequenceFlow id="flow1" sourceRef="theStart" targetRef="writeReportTask" /> <userTask id="writeReportTask" name="Write monthly financial report"> <documentation>Write monthly financial report for publication to shareholders.</documentation> <potentialOwner> <resourceAssignmentExpression> <formalExpression>accountancy</formalExpression> </resourceAssignmentExpression> </potentialOwner> </userTask> <sequenceFlow id="flow2" sourceRef="writeReportTask" targetRef="verifyReportTask" /> <userTask id="verifyReportTask" name="Verify monthly financial report"> <documentation>Verify monthly financial report composed by the accountancy department. This financial report is going to be sent to all the company shareholders.</documentation> <potentialOwner> <resourceAssignmentExpression> <formalExpression>management</formalExpression> </resourceAssignmentExpression> </potentialOwner> </userTask> <sequenceFlow id="flow3" sourceRef="verifyReportTask" targetRef="theEnd" /> <endEvent id="theEnd" /> </process> </definitions>
when I run the code , some errors occurred, who can help me? thanks.
Exception in thread "main" org.activiti.engine.ActivitiObjectNotFoundException: no processes deployed with key 'financialReport' at org.activiti.engine.impl.persistence.deploy.DeploymentManager.findDeployedLatestProcessDefinitionByKey(DeploymentManager.java:67) at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:64) at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:36) at org.activiti.engine.impl.interceptor.CommandExecutorImpl.execute(CommandExecutorImpl.java:24) at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:61) at org.activiti.engine.impl.interceptor.LogInterceptor.execute(LogInterceptor.java:37) at org.activiti.engine.impl.RuntimeServiceImpl.startProcessInstanceByKey(RuntimeServiceImpl.java:54) at test.Test.main(Test.java:26)
Activiti version needs filename suffix is '.bpmn20.xml' or '.bpmn', otherwise throws an exception org.activiti.engine.ActivitiObjectNotFoundException: no processes deployed with key 'xxx'
