I have this issue with Versioning and I don't know what I'm missing or doing wrong.
I created a Document and browsed the Repository for AllVersions and the Version label is like below.
Name Version Label cmisbjectId
Document1 current workspace://SpacesStore/b7f6fdfc-79c5-4 … aab7d329a5 Document1 1.0 workspace://SpacesStore/b7f6fdfc-79c5-4 … d329a5;1.0
At this point the contents in both the Versions are same.
Then I used the checkOut method in VersioningService and replaced the content and checkIn the changed content and the Version changed as expected and it looked like this.
Now the contents in Version 1.1 and the current are same.
I came across in one of CMIS Document " When a Latest Version of a Version Series is deleted, a previous version becomes Latest version".
But when I used the deleteObject method to delete the version 1.1 and the content in the current Version , I thought should be set to the 1.0 version , but it contains the 1.1 version content.
Secondly, when I want to get the contents of the Version1.1 Document using read method in ContentService, I passed in workspace://SpacesStore/b7f6fdfc-79c5-4 … d329a5;1.1 as the objectId and I get " Object Not Found" error.
