Need help with migrating 1.4 to 2.1
ajones-barnet
Hello, having trouble migrating from alfresco1.4 to alfresco2.1.
The basic setup is FreeBSD 6.1 using the tomcat from alfresco-community-tomcat-2.1.0.tar.gz
I can get a clean install up and running without any problems. However migrating the data from alfresco14 caused the bellow error. Here is what I did:
- Unpacked alfresco-community-tomcat-2.1.0.tar.gz
- Set  the database to a copy of the mysql14 database
- Set dir.root to /alf_data.
- Copied alfresco14's alf_data to /alf_data
- Deleted /alf_data/lucene-indexes
- Set index.recovery.mode=FULL in tomcat/webapps/alfresco/WEB-INF/classes/alfresco/repository.properties
- start alfresco with alfresco.sh start
Error:
14:52:38,795 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
14:52:40,835 WARN  [org.alfresco.util.OpenOfficeConnectionTester] A connection to OpenOffice could not be established.
14:52:44,541 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
14:52:46,268 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
14:52:48,078 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent] Index recovery started: 2,521 transactions.
14:52:53,944 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    10 % complete.
14:52:56,136 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    20 % complete.
14:52:58,592 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    30 % complete.
14:53:03,515 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    40 % complete.
14:53:08,381 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    50 % complete.
14:53:11,247 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    60 % complete.
14:53:14,834 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    70 % complete.
14:53:20,178 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    80 % complete.
14:53:23,752 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    90 % complete.
14:53:26,737 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    100 % complete.
14:53:26,746 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent] Index recovery completed.
14:56:22,438 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /alf_data
14:56:22,451 ERROR [org.alfresco.repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: System content not found in content store.
14:56:22,451 ERROR [org.alfresco.repo.admin.ConfigurationChecker] Ensure that the 'dir.root' property is pointing to the correct data location.
14:56:22,456 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Ensure that the 'dir.root' property is pointing to the correct data location.
   at org.alfresco.repo.admin.ConfigurationChecker.check(ConfigurationChecker.java:312)
   at org.alfresco.repo.admin.ConfigurationChecker.access$000(ConfigurationChecker.java:72)
   at org.alfresco.repo.admin.ConfigurationChecker$1.execute(ConfigurationChecker.java:178)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:225)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:155)
   at org.alfresco.repo.admin.ConfigurationChecker.onBootstrap(ConfigurationChecker.java:182)
14:56:22,459 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
14:56:22,462 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
Any ideas?
Andrew
13 REPLIES 13
ajones-barnet
No that file does not exist.
dooley
Where you able to resolve this, I'm running into something similar
derek
This is a case of the content store not having the required content.  If you raise a support case then we can have a look at your system's config, etc.
mikef
It looks highly likely that your database and filesystem are out of sync. You need to restore the missing files from somewhere (copy or backup?).
Anytime you see an error like this:
org.alfresco.service.cmr.repository.ContentIOException: Failed to open stream onto channel:
accessor: ContentAccessor[ contentUrl=store://2007/8/3/17/38/8821e46b-4194-11dc-937f-c52bf5323e59.bin, mimetype=text/xml, size=0, encoding=UTF-8, locale=en]
It means you content is not found on the file system. If you are sure you are using the right alf_data location, it must be missing file(s).
Note you can get path to the file relative to the store from the contentUrl above i.e.
Use this to check if the file exists or not. If not, you need to restore from a copy/backup.
