Kerberos+ AD+ Alfresco Problem! help
subemontes
Hi all!
first and foremost, description.
Machine A _> Alfresco
Machie b -> SQL
Machine c-> Alf_data
Machine d -> Domain Controler
Info:
http://wiki.alfresco.com/wiki/Configuring_the_CIFS_and_web_servers_for_Kerberos/AD_integration
http://wiki.alfresco.com/wiki/Enterprise_Security_and_Authentication_Configuration
http://java.sun.com/javase/6/docs/technotes/guides/security/jaas/tutorials/GeneralAcnOnly.html
And many posts in forums in this one, many from belmeki…
No luck.
Take the easy point first.
in http://wiki.alfresco.com/wiki/Enterprise_Security_and_Authentication_Configuration
are told that allowing kerberos is as easy as modify 2 files:
jaas-authentication-context.xml
java.security
java.security.config
well… it didnt work.
Here's jaas:
<beans>
    <!– The authentication component.                                      –>
    <!– Jass authentication - most of the config goes somewhere else       –>
    <bean id="authenticationComponent"
                 class="org.alfresco.repo.security.authentication.jaas.JAASAuthenticationComponent">
        <property name="realm">
            <value>REALM</value>
        </property>
        <property name="jaasConfigEntryName">
            <value>Alfresco</value>
        </property>
    </bean>
    <!– DAO that rejects changes - JAAS is read only at the moment.      –>
    <!– It does allow users to be deleted with out warnings from the UI. –>
    <!– The user is still present in JAAS, only the personal information is removed from alfresco. –>
    <bean name="authenticationDao" class="org.alfresco.repo.security.authentication.DefaultMutableAuthenticationDao" >
        <property name="allowDeleteUser">
            <value>true</value>
        </property>
    </bean>
</beans>
Here's the line of java.security
login.config.url.1=file:C:/Program Files/Java/jdk1.6.0_07/jre/lib/security/java.login.config
and java.security.config
Alfresco {
   com.sun.security.auth.module.Krb5LoginModule sufficient;
com.sun.net.ssl.client {
other {
And here's the horrible error (that i dont fully understand):
17:43:07,014 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.alfresco.repo.domain.hibernate.dialect.AlfrescoSQLServerDialect.
17:43:10,810 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
17:43:14,482 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: \\172.16.1.103\alfresco$\alf_data
17:43:14,529 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Comprobando si hay parches para aplicar …
17:43:15,092 INFO  [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
17:43:15,295 ERROR [org.alfresco.smb.protocol.auth] No valid CIFS authentication combination available
17:43:15,295 ERROR [org.alfresco.smb.protocol.auth] Either enable Kerberos support or use an authentication component that supports MD4 hashed passwords
17:43:15,310 ERROR [org.alfresco.smb.protocol] CIFS server configuration error, Invalid CIFS authenticator configuration
org.alfresco.error.AlfrescoRuntimeException: Invalid CIFS authenticator configuration
   at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.initialize(EnterpriseCifsAuthenticator.java:378)
Anyone can give a hand ?
Really angry about this one…
6 REPLIES 6
subemontes
Next Try:
Really hard way… tokens… cifs… passwords…
Starting… following that web and
http://forums.alfresco.com/en/viewtopic.php?f=9&t=14741&p=48528&hilit=No+valid+CIFS+authentication+c...
And mainly
http://forums.alfresco.com/en/viewtopic.php?f=9&t=14773&p=48590&hilit=kerberos#p48590
So i Have a real example… I have configured it like in the manual… didnt work.
But, before asking, i need someone answer in some thing…
If all my net is Microsoft…. ¿Is useful tryint to use tokens? or the first of my post (just another wili) will work ?
any help ?
subemontes
And After following the
Here's the error:
18:32:34,929 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
18:32:38,679 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: \\X.X.X.X\alfresco$\alf_data
18:32:38,741 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Comprobando si hay parches para aplicar …
18:32:39,288 INFO  [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
18:32:40,257 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_07-b06; maximum heap size 960,000MB
18:32:40,257 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.9.0 (B 683) schema 116 - Installed version 2.9.0 (B 683) schema 116
18:32:44,366 ERROR [org.alfresco.web.app.servlet.KerberosAuthenticationFilter] HTTP Kerberos web filter error
javax.security.auth.login.LoginException: Integrity check on decrypted field failed (31)
   at com.sun.security.auth.module.Krb5LoginModule.attemptAuthentication(Krb5LoginModule.java:696)
   at com.sun.security.auth.module.Krb5LoginModule.login(Krb5LoginModule.java:542)
   at javax.security.auth.login.LoginContext.invoke(LoginContext.java:769)
   at javax.security.auth.login.LoginContext.access$000(LoginContext.java:186)
   at javax.security.auth.login.LoginContext$4.run(LoginContext.java:683)
   at javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:680)
   at javax.security.auth.login.LoginContext.login(LoginContext.java:579)
   at org.alfresco.web.app.servlet.KerberosAuthenticationFilter.init(KerberosAuthenticationFilter.java:366)
   at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:221)
   at org.apache.catalina.core.ApplicationFilterConfig.setFilterDef(ApplicationFilterConfig.java:302)
   at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:78)
   at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:3635)
   at org.apache.catalina.core.StandardContext.start(StandardContext.java:4222)
Caused by: KrbException: Integrity check on decrypted field failed (31)
   at sun.security.krb5.internal.crypto.DesCbcEType.decrypt(DesCbcEType.java:154)
   at sun.security.krb5.internal.crypto.DesCbcMd5EType.decrypt(DesCbcMd5EType.java:33)
   at sun.security.krb5.internal.crypto.DesCbcEType.decrypt(DesCbcEType.java:125)
   at sun.security.krb5.EncryptedData.decrypt(EncryptedData.java:168)
   at sun.security.krb5.KrbAsRep.<init>(KrbAsRep.java:87)
   at sun.security.krb5.KrbAsReq.getReply(KrbAsReq.java:449)
   at sun.security.krb5.Credentials.sendASRequest(Credentials.java:406)
   at sun.security.krb5.Credentials.acquireTGT(Credentials.java:355)
   at com.sun.security.auth.module.Krb5LoginModule.attemptAuthentication(Krb5LoginModule.java:662)
   … 39 more
18:32:45,210 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Excepción arrancando filtro Authentication Filter
javax.servlet.ServletException: Failed to login HTTP server service
   at org.alfresco.web.app.servlet.KerberosAuthenticationFilter.init(KerberosAuthenticationFilter.java:380)
:?  :?  :? HELP :?  :?
subemontes
Ok. Update:
We return to first and "simple" configuration:
I Installed "filemon" from sysinternals, to know if java was really using java.login.config…
I modify java.security in this way:
login.config.url.1=file:${user.home}/.java.login.config
login.config.url.2=file:${java.home}/jre/lib/security/java.login.config
login.config.url.3=file:${java.home}/lib/security/java.login.config
login.config.url.4=file:${java.home}/java.login.config
login.config.url.5=file:C:/Program Files/Java/jdk1.6.0_07/jre/lib/security/java.login.config
Using preference and inhttp://java.sun.com/j2se/1.4.2/docs/guide/security/jaas/spec/com/sun/security/auth/login/ConfigFile....
explains that it must go checking all folders… but filemon didnt show that file accesses (it shows java.security only)
The error running the alfresco is this:
13:21:59,571 INFO  [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
13:21:59,852 ERROR [org.alfresco.smb.protocol.auth] No valid CIFS authentication combination available
13:21:59,852 ERROR [org.alfresco.smb.protocol.auth] Either enable Kerberos support or use an authentication component that supports MD4 hashed passwords
13:21:59,852 ERROR [org.alfresco.smb.protocol] CIFS server configuration error, Invalid CIFS authenticator configuration
Anyone has a solution plZ!
subemontes
Update:
Have modify the file-servers.xml to try to configure. CIFS with passthorg.
Error.
    <!– <authenticator type="enterprise">–>
     <authenticator type="passthru">
      <server>192.168.1.100</server>
</authenticator>
</config>
Error:
14:55:23,506 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Comprobando si hay parches para aplicar …
14:55:24,147 INFO  [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
14:55:24,397 ERROR [org.alfresco.smb.protocol] CIFS server configuration error, No valid authentication servers found for passthru
org.alfresco.error.AlfrescoRuntimeException: No valid authentication servers found for passthru
   at org.alfresco.filesys.server.auth.passthru.PassthruAuthenticator.initialize(PassthruAuthenticator.java:1208)
Any idea ?
subemontes
WOW! Have found a way to work with kerberos tokens and AND.
He gets credentials and enter…
But fails against CIFS… damm
subemontes
Updated:
Bad Luck… the tokens where working but no autentificacion was possible.
Because We get short on time, I checked the way to configure NTLM v2, and without the CIFS server (anyone knows if it is useful) and we are working without kerberos but NTLM.
Will try again in few days!…
