JPA problem[help]
banw
   I am studing JPA ,but met some problems.Followings are the background.
   JPA : activiti-jpa-pu, no domain model is used.
   main error message:Entity does not exist: example.Point - 1
   There is one entity in the DB,but after the program aborted,the item  is deleted from the Table.
   Anybody can help me?
  Thanks in advance.
1 activiti.cfg.xml
       xsi:schemaLocation="http://www.springframework.org/schema/beans   http://www.springframework.org/schema/beans/spring-beans.xsd">
  <bean id="processEngineConfiguration" class="org.activiti.engine.impl.cfg.StandaloneProcessEngineConfiguration">
    <!– Database configurations –>
    <property name="jdbcUrl" value="jdbc:h2:tcp://localhost/activiti" />
    <property name="jdbcDriver" value="org.h2.Driver" />
    <property name="jdbcUsername" value="sa" />
    <property name="jdbcPassword" value="" />
    <!– -JPA –>
    <property name="jpaPersistenceUnitName" value="activiti-jpa-pu" />
   <property name="jpaHandleTransaction" value="true" />
   <property name="jpaCloseEntityManager" value="true" />
   <!– Mail –>
   <property name="mailServerHost"  value="smtp.sohu.com" />
   <property name="mailServerPort"  value="25" />
   <property name="mailServerUsername" value="[email protected]" />
   <property name="mailServerPassword" value="670819" />
   <!– Job  –>
    <property name="jobExecutorActivate" value="true" />
  </bean>
  <bean id="Point" class="example.Point" />
  <bean id="FieldAccessJPAEntity" class="example.FieldAccessJPAEntity" />
</beans>
MyProcess.bpmn20.xml  <?xml version="1.0" encoding="UTF-8"?>
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlnsSmiley Surprisedmgdc="http://www.omg.org/spec/DD/20100524/DC" xmlnsSmiley Surprisedmgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test">
  <process id="process3" name="process3">
    <serviceTask id="servicetask1" name="Service Task" activiti:expression="${POINT.setX(9)}"   ></serviceTask>
    <sequenceFlow id="flow3" name="" sourceRef="startevent1" targetRef="servicetask1"></sequenceFlow>
    <userTask id="usertask1" name="User Task" activiti:assignee="kermit"></userTask>
    <sequenceFlow id="flow4" name="" sourceRef="servicetask1" targetRef="usertask1"></sequenceFlow>
    <sequenceFlow id="flow5" name="" sourceRef="usertask1" targetRef="endevent1"></sequenceFlow>
  </process>
3 Entity example
   package example;
import java.io.Serializable;
import javax.persistence.*;
@Entity
@Table(name="POINT")
public class Point implements Serializable {
    private static final long serialVersionUID = 1L;
    @Id
    @GeneratedValue
    private long id;
    private int x;
    private int y;
    public Point() {
    Point(int x, int y) {
        this.x = x;
        this.y = y;
    public Long getId() {
        return id;
    public void setId(Long id) {
       this.id = id;
    public int getX() {
         return x;
    public int getY() {
         return y;
    public void setY(int y){
       this.y = y;
    public void setX(int x){
       this.x = x;
4 Main function fragments
                         Point Pt = new Point(0,0);
        Pt.setId((long)1);
       Variables.put("POINT",Pt);
5 One entity has existed in the DB before the program started.
   But after the program aborted, the entity was deleted from the DB.
6 Console messages:2012-5-21 16:17:17 org.activiti.engine.impl.interceptor.CommandContext close
严重: Error while closing command context
org.activiti.engine.ActivitiException: Error while evalutaing expression
   at org.activiti.engine.impl.el.JuelExpression.getValue(JuelExpression.java:61)
   at org.activiti.engine.impl.bpmn.behavior.ServiceTaskExpressionActivityBehavior.execute(ServiceTaskExpressionActivityBehavior.java:39)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationActivityExecute.execute(AtomicOperationActivityExecute.java:44)
   at org.activiti.engine.impl.interceptor.CommandContext.performOperation(CommandContext.java:77)
   at org.activiti.engine.impl.persistence.entity.ExecutionEntity.performOperationSync(ExecutionEntity.java:530)
   at org.activiti.engine.impl.persistence.entity.ExecutionEntity.performOperation(ExecutionEntity.java:525)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerStart.eventNotificationsCompleted(AtomicOperationTransitionNotifyListenerStart.java:52)
   at org.activiti.engine.impl.pvm.runtime.AbstractEventAtomicOperation.execute(AbstractEventAtomicOperation.java:56)
   at org.activiti.engine.impl.pvm.runtime.AbstractEventAtomicOperation.execute(AbstractEventAtomicOperation.java:49)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionCreateScope.execute(AtomicOperationTransitionCreateScope.java:49)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerTake.execute(AtomicOperationTransitionNotifyListenerTake.java:65)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionDestroyScope.execute(AtomicOperationTransitionDestroyScope.java:115)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerEnd.eventNotificationsCompleted(AtomicOperationTransitionNotifyListenerEnd.java:36)
   at org.activiti.engine.impl.persistence.entity.ExecutionEntity.take(ExecutionEntity.java:365)
   at org.activiti.engine.impl.bpmn.behavior.BpmnActivityBehavior.performOutgoingBehavior(BpmnActivityBehavior.java:102)
   at org.activiti.engine.impl.bpmn.behavior.BpmnActivityBehavior.performDefaultOutgoingBehavior(BpmnActivityBehavior.java:51)
   at org.activiti.engine.impl.bpmn.behavior.FlowNodeActivityBehavior.leave(FlowNodeActivityBehavior.java:44)
   at org.activiti.engine.impl.bpmn.behavior.FlowNodeActivityBehavior.execute(FlowNodeActivityBehavior.java:36)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationProcessStartInitial.eventNotificationsCompleted(AtomicOperationProcessStartInitial.java:46)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationProcessStart.eventNotificationsCompleted(AtomicOperationProcessStart.java:45)
   at org.activiti.engine.impl.persistence.entity.ExecutionEntity.start(ExecutionEntity.java:319)
   at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:72)
   at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:31)
   at org.activiti.engine.impl.interceptor.CommandExecutorImpl.execute(CommandExecutorImpl.java:24)
   at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:42)
   at org.activiti.engine.impl.RuntimeServiceImpl.startProcessInstanceByKey(RuntimeServiceImpl.java:54)
   at example.Test.main(Test.java:91)
Caused by: org.activiti.engine.ActivitiException: Entity does not exist: example.Point - 1
   at org.activiti.engine.impl.variable.JPAEntityMappings.findEntity(JPAEntityMappings.java:130)
   at org.activiti.engine.impl.variable.JPAEntityMappings.getJPAEntity(JPAEntityMappings.java:119)
   at org.activiti.engine.impl.variable.JPAEntityVariableType.getValue(JPAEntityVariableType.java:77)
   at org.activiti.engine.impl.persistence.entity.VariableInstanceEntity.getValue(VariableInstanceEntity.java:158)
   at org.activiti.engine.impl.persistence.entity.VariableScopeImpl.getVariable(VariableScopeImpl.java:93)
   at org.activiti.engine.impl.el.VariableScopeElResolver.getValue(VariableScopeElResolver.java:65)
   at org.activiti.engine.impl.javax.el.CompositeELResolver.getValue(CompositeELResolver.java:231)
   at org.activiti.engine.impl.juel.AstIdentifier.eval(AstIdentifier.java:81)
   at org.activiti.engine.impl.juel.AstMethod.invoke(AstMethod.java:79)
   at org.activiti.engine.impl.juel.AstMethod.eval(AstMethod.java:75)
   at org.activiti.engine.impl.juel.AstEval.eval(AstEval.java:50)
   at org.activiti.engine.impl.juel.AstNode.getValue(AstNode.java:26)
   at org.activiti.engine.impl.juel.TreeValueExpression.getValue(TreeValueExpression.java:114)
   at org.activiti.engine.impl.delegate.ExpressionGetInvocation.invoke(ExpressionGetInvocation.java:33)
   at org.activiti.engine.impl.delegate.DelegateInvocation.proceed(DelegateInvocation.java:3error end!
7)
   at org.activiti.engine.impl.delegate.DefaultDelegateInterceptor.handleInvocation(DefaultDelegateInterceptor.java:25)
   at org.activiti.engine.impl.el.JuelExpression.getValue(JuelExpression.java:50)
   … 58 more
sebastian_s
Your xml files got messed up somehow. Please repost them correctly.
