Issue with Webscript conversion from Alfresco3.1 to 3.3
Options
‎07-06-2010 08:09 PM
We are getting following error after the code migrated to 3.3.. any suggestion helps a lot.. thanks a lot.
XML Parsing Error: mismatched tag. Expected: </NUMBER>.
Location: http://xxxxxxxxxxxxxxxxxxxx/getnewsletterlist/xml?context=acc&idList=acc-all-acc&year=2010&month=02
Line Number 79, Column 5: </callstack>
is there any change required in the webscript class from 3.1 to 3.3?
thanks for your time in advance.
Labels:
Archive
4 REPLIES 4
Options
‎07-07-2010 05:39 AM
Yes there are changes between 3.1 and 3.3. Most significantly to Java Based webscripts since the framework changes package from Alfresco to Spring.
But how can anyone comment with the level of detail you have posted?
Options
‎07-07-2010 03:32 PM
I though it is common error. i can post my java class. if it help?
Options
‎07-07-2010 09:07 PM
Here is the code..
import java.io.IOException;
import java.io.Serializable;
import java.io.StringWriter;
import java.util.HashMap;
import java.util.Locale;
import java.util.Map;
import javax.xml.parsers.DocumentBuilder;
import javax.xml.parsers.DocumentBuilderFactory;
import javax.xml.parsers.ParserConfigurationException;
import javax.xml.transform.OutputKeys;
import javax.xml.transform.Transformer;
import javax.xml.transform.TransformerException;
import javax.xml.transform.TransformerFactory;
import javax.xml.transform.dom.DOMSource;
import javax.xml.transform.stream.StreamResult;
import org.alfresco.repo.security.authentication.AuthenticationUtil;
import org.alfresco.service.ServiceRegistry;
import org.alfresco.service.cmr.repository.NodeRef;
import org.alfresco.service.namespace.QName;
import org.alfresco.web.scripts.Cache;
import org.alfresco.web.scripts.DeclarativeWebScript;
import org.alfresco.web.scripts.Status;
import org.alfresco.web.scripts.WebScriptRequest;
import org.apache.log4j.Logger;
import org.w3c.dom.Document;
import org.w3c.dom.Element;
import com.keenan.core.content.model.CustomContentModel;
import com.keenan.utils.KeenanConstants;
import com.keenan.utils.KeenanUtils;
* @author Cignex
* @Package com.keenan.script.pncbridge
* This class is used for creating XML responce of Specific Newsletter from UUID
public class GetNewsLetter extends DeclarativeWebScript
Locale currentLocale = Locale.getDefault();
KeenanUtils keenanUtils=new KeenanUtils();
private final Logger logger = Logger.getLogger(GetNewsLetter.class);
private ServiceRegistry serviceRegistry;
* This Method will take request parameters ,search content and create XML responce as per UUID.
@Override
protected Map<String, Object> executeImpl(final WebScriptRequest _request, final Status _status, final Cache _cache)
final String _rootPath = KeenanConstants.getPropertyValue(KeenanConstants.NEWSLETTER_PATH);
final Map<String, Object> _returnMap = new HashMap<String, Object>();
String _content =null;
StringBuffer _errorContent = null;
AuthenticationUtil.setRunAsUserSystem();
final String _uuid = _request.getParameter("uuid");
final NodeRef _noderef = keenanUtils.getNodeByUuid(_uuid,_rootPath,this.serviceRegistry);
if (_noderef != null)
_content = parseNodeRef(_noderef);
else
_errorContent = new StringBuffer();
_errorContent.append(KeenanConstants.getPropertyValue(KeenanConstants.NEWSLETTER_ERRORTAG));
_errorContent.append(KeenanConstants.getPropertyValue(KeenanConstants.ERROR_MESSAGE));
_errorContent.append(keenanUtils.endTag(KeenanConstants.getPropertyValue(KeenanConstants.NEWSLETTER_ERRORTAG)));
_content=_errorContent.toString();
_returnMap.put(KeenanConstants.getPropertyValue(KeenanConstants.CONTENT_STRING_KEY), _content);
AuthenticationUtil.clearCurrentSecurityContext();
return _returnMap;
// Getter of Service Registry
public ServiceRegistry getServiceRegistry()
return serviceRegistry;
* @param _contentNode
* @return
* This method will create the XML responce of particular Newsletter from UUID.
private String parseNodeRef(final NodeRef _contentNode)
Map<QName, Serializable> _metadataMap;
_metadataMap = getServiceRegistry().getNodeService().getProperties(_contentNode);
StringWriter _stringWriter=null;
Document _document, _doc = null;
try
_document = keenanUtils.parse(_contentNode);
final DocumentBuilderFactory _dbfacxml = DocumentBuilderFactory.newInstance();
DocumentBuilder docBuilder;
docBuilder = _dbfacxml.newDocumentBuilder();
_doc = docBuilder.newDocument();
// Xml generation
final Element root = _doc.createElement(KeenanConstants.getPropertyValue(KeenanConstants.ELEMENT_NEWSLETTER));
_doc.appendChild(root);
// Get uuid from metadata map
final String _uuid = _metadataMap.get(CustomContentModel.PROPERTY_CONTENT_UUID).toString();
final Element _uuidChild = _doc.createElement( KeenanConstants.getPropertyValue(KeenanConstants.ELEMENT_UUID));
_uuidChild.setTextContent(_uuid);
root.appendChild(_uuidChild);
// Get other parameters from generated xml file of newsletter form
final String title = _document.getElementsByTagName( KeenanConstants.getPropertyValue(KeenanConstants.TAG_TITLE)).item(0).getFirstChild().getNodeValue()!=null?_document.getElementsByTagName(KeenanConstants.getPropertyValue(KeenanConstants.TAG_TITLE)).item(0).getFirstChild().getNodeValue():"";
final Element _titleChild = _doc.createElement(KeenanConstants.getPropertyValue(KeenanConstants.getPropertyValue(KeenanConstants.ELEMENT__TITLE)));
_titleChild.setTextContent(title);
root.appendChild(_titleChild);
final Element _publisheddateChild = _doc.createElement(KeenanConstants.getPropertyValue(KeenanConstants.ELEMENT_PUBLISH_DATE));
final String _publishDate = _metadataMap.get(CustomContentModel.PROPERTY_CONTENT_DATE).toString();
_publisheddateChild.setTextContent(keenanUtils.changeDateFormat("yyyy-MM-dd", "E MMM dd hh:mm:ss Z yyyy", _publishDate));
root.appendChild(_publisheddateChild);
final Element _htmlcontentChild = _doc.createElement(KeenanConstants.getPropertyValue(KeenanConstants.ELEMENT_HTMLCONTENT));
final String _htmlcontent = _document.getElementsByTagName(KeenanConstants.getPropertyValue(KeenanConstants.TAG_BODY)).item(0).getFirstChild().getNodeValue()!=null?"<![CDATA[" + _document.getElementsByTagName(KeenanConstants.getPropertyValue(KeenanConstants.TAG_BODY)).item(0).getFirstChild().getNodeValue() + "]]>":"";
_htmlcontentChild.setTextContent(_htmlcontent);
root.appendChild(_htmlcontentChild);
// Transformation to string
final TransformerFactory transfac = TransformerFactory.newInstance();
Transformer trans;
trans = transfac.newTransformer();
trans.setOutputProperty(OutputKeys.OMIT_XML_DECLARATION, KeenanConstants.getPropertyValue(KeenanConstants.YES));
trans.setOutputProperty(OutputKeys.INDENT, KeenanConstants.getPropertyValue(KeenanConstants.YES));
_stringWriter = new StringWriter();
final StreamResult _streamResult = new StreamResult(_stringWriter);
final DOMSource _domSource = new DOMSource(_doc);
trans.transform(_domSource, _streamResult);
_content = _stringWriter.toString();
} catch (final TransformerException e)
logger.error(e.getMessage());
} catch (ParserConfigurationException e)
} finally
try {
if(_stringWriter!=null)
_stringWriter.close();
} catch (IOException e) {
return _content;
// Setter of Service Registry
public void setServiceRegistry(final ServiceRegistry serviceRegistry)
this.serviceRegistry = serviceRegistry;
* @author Cignex
@Override
else
return _returnMap;
* @return
try
// Xml generation
Transformer trans;
} finally
try {
return _content;
Options
‎07-17-2010 04:39 AM
I got the issue and i have fixed it. there is issue in query
