Issue while using cmis:path in query
binodgarg
hi,
I am using the following select query as "SELECT cmis:name,cmisSmiley Surprisedbjectid,cmisSmiley Tongueath FROM cmis:folder WHERE cmis:name LIKE 'test'" . This is failing and giving the following exception.
org.alfresco.cmis.CMISQueryException - 04180097 Column is not queryable cmis:folder.cmisSmiley Tongueath
Can I not use cmisSmiley Tongueath in the select query ? Is there a way I can make it queryable?
Binod Garg
jpotts
World-Class Innovator
Have you tried this lately? It works fine on 4.0.d (after fixing the capitalization problem–should be cmisSmiley SurprisedbjectId).
Jeff
