Hi, I am new to activiti, and have a problem with the installation. I downloaded activiti-5.4. on my windows seven machine When I first tried ant.demo.start I git an error with the tomcat installation
I the tried again, first downloading tomcat apache-tomcat-6.0.32-windows-x86.zip . When the unsuccessfull instalation is terminated, i have my own dowloaded file apache-tomcat-6.0.32-windows-x86.zip, but also an apache-tomcat-6.0.32.zip file in my donwloads folder. The apache-tomcat-6.0.32.zip file is not expandable.
Here are the log when it came to the installation of tomcat tomcat.install:
internal.tomcat.unzip: [unzip] Expanding: c:\downloads\apache-tomcat-6.0.32.zip into c:\activiti\ap ps
BUILD FAILED c:\activiti\setup\build.xml:159: The following error occurred while executing th is line: c:\activiti\setup\build.xml:324: The following error occurred while executing th is line: c:\activiti\setup\build.xml:341: Error while expanding c:\downloads\apache-tomca t-6.0.32.zip java.io.IOException: Negative seek offset at java.io.RandomAccessFile.seek(Native Method) at org.apache.tools.zip.ZipFile.positionAtCentralDirectory(ZipFile.java: 467) at org.apache.tools.zip.ZipFile.populateFromCentralDirectory(ZipFile.jav a:313) at org.apache.tools.zip.ZipFile.<init>(ZipFile.java:185) at org.apache.tools.ant.taskdefs.Expand.expandFile(Expand.java:170) at org.apache.tools.ant.taskdefs.Expand.execute(Expand.java:132) at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291) at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.jav a:106) at org.apache.tools.ant.Task.perform(Task.java:348) at org.apache.tools.ant.Target.execute(Target.java:390) at org.apache.tools.ant.Target.performTasks(Target.java:411) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399) at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(Single CheckExecutor.java:38) at org.apache.tools.ant.Project.executeTargets(Project.java:1251) at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:442) at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:105)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291) at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.jav a:106) at org.apache.tools.ant.Task.perform(Task.java:348) at org.apache.tools.ant.Target.execute(Target.java:390) at org.apache.tools.ant.Target.performTasks(Target.java:411) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399) at org.apache.tools.ant.Project.executeTarget(Project.java:1368) at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExe cutor.java:41) at org.apache.tools.ant.Project.executeTargets(Project.java:1251) at org.apache.tools.ant.Main.runBuild(Main.java:809) at org.apache.tools.ant.Main.startAnt(Main.java:217) at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280) at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)
Seems like something is wrong with the tomcat zip (corrupted while downloading eg.). Can you delete the apache-tomcat-6.0.32.zip file, and running the setup agian?
