02-18-2009 02:47 PM
02-26-2009 05:23 AM
02-26-2009 05:45 AM
02-26-2009 11:10 AM
02-26-2009 11:53 AM
01-21-2010 04:35 AM
09:53:24,686 ERROR [quartz.core.ErrorLogger] Job (DEFAULT.ftsIndexerJobDetail threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: java.lang.NullPointerException]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:529)
at java.io.StringReader.<init>(StringReader.java:33)
at org.alfresco.repo.search.impl.lucene.ADMLuceneIndexerImpl.indexProperty(ADMLuceneIndexerImpl.java:1037)
at org.alfresco.repo.search.impl.lucene.ADMLuceneIndexerImpl.createDocuments(ADMLuceneIndexerImpl.java:602)
at org.alfresco.repo.search.impl.lucene.ADMLuceneIndexerImpl.updateFullTextSearch(ADMLuceneIndexerImpl.java:1502)
at org.alfresco.repo.search.impl.lucene.fts.FullTextSearchIndexerImpl.index(FullTextSearchIndexerImpl.java:188)
select * from alf_node_properties np join alf_locale l on (l.id = np.locale_id) where l.locale_str != '.default' and np.string_value is null;
node_id actual_type_n persisted_type_n boolean_value long_value float_value double_value string_value serializable_value qname_id list_index locale_id id version locale_str
857191 0 0 f 0 0 0 106 -1 69730 69730 0 it_IT_
857227 0 0 f 0 0 0 106 -1 69730 69730 0 it_IT_
857071 0 0 f 0 0 0 106 -1 69730 69730 0 it_IT_
02-04-2010 02:14 AM
