Installation problem with clean 4.0.d install
![tarapenner tarapenner](https://connect.hyland.com/legacyfs/online/avatars/Blue-user-logo.png)
Options
‎02-16-2012 07:02 PM
This is my first try at an Alfresco installation, and I'm a bit stuck. Using a clean 64-bit 2008 Windows VPS I ran the setup wizard for 4.0.d (easy installation). Afterwards, I was unable to access Alfresco using http://270.0.0.1:8080/alfresco or http://270.0.0.1:8080/share. So I did a bit of investigation, and discovered that the JAVA_HOME environment variable needed to be set (which I did - C:\Alfresco\java\jre).
Then I stopped and started the Alfresco service. Still no luck. I've pasted the contents of my alfresco.log file below. I see I've got an issue with Open Office, but is there anything else that I'm not seeing that could be causing me problems? I'm pretty new to this and appreciate any help.![Smiley Happy Smiley Happy](/i/smilies/16x16_smiley-happy.png)
Tara
15:40:00,451 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
15:40:00,595 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
15:40:24,289 WARN [org.alfresco.util.AbstractTriggerBean] Job ehCacheTracerJob is not active/enabled
15:40:35,009 INFO [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor Repository Template Processor for extension ftl
15:40:35,009 INFO [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor Repository Script Processor for extension js
15:40:52,150 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.PostgreSQLDialect.
15:40:59,073 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
15:40:59,565 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Search' subsystem, ID: [Search, managed, solr]
15:40:59,789 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Search' subsystem, ID: [Search, managed, solr] complete
15:41:05,689 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'thirdparty' subsystem, ID: [thirdparty, default]
15:41:06,176 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'thirdparty' subsystem, ID: [thirdparty, default] complete
15:41:06,176 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'OOoDirect' subsystem, ID: [OOoDirect, default]
15:41:09,132 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
15:41:09,176 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'OOoDirect' subsystem, ID: [OOoDirect, default] complete
15:41:09,441 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
15:41:09,450 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
15:41:11,358 WARN [org.alfresco.repo.admin.patch.PatchExecuter] Patch description is not available: Patch[ id=patch.migrateAttrDelete, description=patch.migrateAttrDelete.description, fixesFromSchema=0, fixesToSchema=4106, targetSchema=4107]
15:41:12,324 WARN [org.alfresco.repo.admin.patch.PatchExecuter] Patch description is not available: Patch[ id=patch.activitiesEmailTemplate, description=patch.activitiesEmailTemplate.description, fixesFromSchema=0, fixesToSchema=5005, targetSchema=5006]
15:41:13,135 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Applying patch 'patch.siteLoadPatch.swsdp' (Loads a sample site into the repository.).
15:41:13,456 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
15:41:13,748 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete
15:41:29,644 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Applying patch 'patch.exampleJavaScript' (Loads sample Javascript file into datadictionary scripts folder).
15:41:29,851 INFO [org.alfresco.repo.admin.patch.PatchExecuter]
=== Applied patch ===
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary/app:scripts (workspace://SpacesStore/a080e74e-9841-41b4-a7e4-7f1343bc57b0)
RESULT:
Site swsdp imported.
15:41:29,869 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
15:41:29,976 INFO [org.alfresco.repo.module.ModuleServiceImpl] Installing module 'org.alfresco.module.vti' version 1.2.
15:41:29,996 DEBUG [org.alfresco.repo.module.ModuleComponentHelper] Started module 'ModuleDetails[{module.version=1.2, module.description=Alfresco Vti Extension, module.id=org.alfresco.module.vti, module.repo.version.max=999, module.title=Vti, module.repo.version.min=0, module.installState=INSTALLED, module.installDate=2012-02-16T10:36:51.896-08:00}]' including 0components.
15:41:29,996 DEBUG [org.alfresco.repo.module.ModuleComponentHelper] Installed module found in distribution: org.alfresco.module.vti
15:41:30,016 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'fileServers' subsystem, ID: [fileServers, default]
15:41:32,636 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'fileServers' subsystem, ID: [fileServers, default] complete
15:41:32,636 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'imap' subsystem, ID: [imap, default]
15:41:32,747 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'imap' subsystem, ID: [imap, default] complete
15:41:32,747 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'email' subsystem, ID: [email, outbound]
15:41:32,993 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'email' subsystem, ID: [email, outbound] complete
15:41:32,993 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'email' subsystem, ID: [email, inbound]
15:41:33,366 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'email' subsystem, ID: [email, inbound] complete
15:41:33,366 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'googledocs' subsystem, ID: [googledocs, default]
15:41:33,463 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'googledocs' subsystem, ID: [googledocs, default] complete
15:41:33,463 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Subscriptions' subsystem, ID: [Subscriptions, default]
15:41:33,502 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Subscriptions' subsystem, ID: [Subscriptions, default] complete
15:41:33,541 INFO [org.alfresco.repo.usage.UserUsageTrackingComponent] Disabled - clear non-missing user usages …
15:41:33,563 INFO [org.alfresco.repo.usage.UserUsageTrackingComponent] Found 4 users to clear
15:41:33,669 INFO [org.alfresco.repo.usage.UserUsageTrackingComponent] … cleared non-missing usages for 4 users
15:41:33,669 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Synchronization' subsystem, ID: [Synchronization, default]
15:41:33,835 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Synchronization' subsystem, ID: [Synchronization, default] complete
15:41:34,056 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_22-b04; maximum heap size 989.875MB
15:41:34,056 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community). Current version: 4.0.0 (4003) schema 5,025. Originally installed version: 4.0.0 (4003) schema 5,025.
15:41:34,056 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'ActivitiesFeed' subsystem, ID: [ActivitiesFeed, default]
15:41:34,159 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'ActivitiesFeed' subsystem, ID: [ActivitiesFeed, default] complete
15:41:34,159 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Replication' subsystem, ID: [Replication, default]
15:41:34,179 INFO [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Replication' subsystem, ID: [Replication, default] complete
Tara
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
RESULT:
Labels:
Archive
8 REPLIES 8
Options
‎02-16-2012 07:09 PM
That logging looks good. One thing I note is that the local loop back address is 127 not 270, from what you have posted you are using the wrong URL.
Options
‎10-30-2014 09:15 AM
Hello sir
How can trigger my job on start up of my alfresco server?
Options
‎02-16-2012 08:10 PM
Thanks so much for the quick reply. I actually was trying http://127.0.0.1:8080/share and was getting the same result (sorry for the typo).
I thought it was fixed at first anyway, because I'm now getting the login screen, but I'm not there yet. What I did change was the database password. This is a little embarrassing, and I honestly don't remember changing it, but I must have because as soon as I changed it to 'alfresco' I got the login screen.
Unfortunately though, admin for username and password is not working. I keep getting the message "The remote server may be unavailable or your authentication details have not been recognized."
When I go to http://127.0.0.1:8080/alfresco/ I'm getting a message that says HTTP Status 404.
I think I'm getting there though! Any other suggestions are appreciated.
Options
‎02-16-2012 10:14 PM
Oh - and just to clarify, I do realize that I need to get the web client working before the password for Share will work.
![chengwu chengwu](https://connect.hyland.com/legacyfs/online/avatars/Blue-user-logo.png)
Options
‎02-17-2012 10:52 AM
I believe during the easy installation there is a question asking admin user password, this will be the password you are using to login.
Options
‎02-17-2012 08:34 PM
After a bit of digging, I think that the issue may be memory related. Below is the log file from Catalina (out), and after that, the file referenced with more information about the Java error. My JAVA_OPTS in Catalina.sh are current set to: JAVA_OPTS="$JAVA_OPTS -Xmx32GB -Xss1024k -XX:MaxPermSize:256m -server".
Catalina Log:
# A fatal error has been detected by the Java Runtime Environment:
# java.lang.OutOfMemoryError: requested 2152336 bytes for Chunk::new. Out of swap space?
# Internal Error (allocation.cpp:215), pid=19220, tid=12916
# Error: Chunk::new
2012-02-17 17:58:36,623 WARN [alfresco.util.AbstractTriggerBean] [Thread-1] Job ehCacheTracerJob is not active/enabled
2012-02-17 17:58:43,873 INFO [extensions.webscripts.TemplateProcessorRegistry] [Thread-1] Registered template processor Repository Template Processor for extension ftl
2012-02-17 17:58:43,873 INFO [extensions.webscripts.ScriptProcessorRegistry] [Thread-1] Registered script processor Repository Script Processor for extension js
2012-02-17 17:58:58,756 INFO [domain.schema.SchemaBootstrap] [Thread-1] Schema managed by database dialect org.hibernate.dialect.PostgreSQLDialect.
2012-02-17 17:59:06,111 INFO [domain.schema.SchemaBootstrap] [Thread-1] No changes were made to the schema.
2012-02-17 17:59:06,495 INFO [management.subsystems.ChildApplicationContextFactory] [Thread-1] Starting 'Search' subsystem, ID: [Search, managed, lucene]
2012-02-17 17:59:06,930 INFO [management.subsystems.ChildApplicationContextFactory] [Thread-1] Startup of 'Search' subsystem, ID: [Search, managed, lucene] complete
2012-02-17 17:59:08,885 INFO [management.subsystems.ChildApplicationContextFactory] [Thread-1] Starting 'thirdparty' subsystem, ID: [thirdparty, default]
2012-02-17 17:59:09,351 ERROR [transform.magick.AbstractImageMagickContentTransformerWorker] [Thread-1] ImageMagickContentTransformerWorker not available: 01170000 Failed to perform ImageMagick transformation:
Execution result:
os: Windows Server 2008 R2
command: [./ImageMagick/bin/convert, C:\Windows\TEMP\Alfresco\ImageMagickContentTransformerWorker_init_source_7426349511954529365.gif[0], C:\Windows\TEMP\Alfresco\ImageMagickContentTransformerWorker_init_target_8355165616680620510.png]
succeeded: false
exit code: 1
out:
err: Cannot run program "./ImageMagick/bin/convert": CreateProcess error=2, The system cannot find the file specified
2012-02-17 17:59:09,351 ERROR [content.transform.RuntimeExecutableContentTransformerWorker] [Thread-1] Failed to start a runtime executable content transformer:
Execution result:
command: [./bin/pdf2swf, -V]
succeeded: false
exit code: 1
out:
err: Cannot run program "./bin/pdf2swf": CreateProcess error=2, The system cannot find the file specified
2012-02-17 17:59:09,351 INFO [management.subsystems.ChildApplicationContextFactory] [Thread-1] Startup of 'thirdparty' subsystem, ID: [thirdparty, default] complete
2012-02-17 17:59:09,367 INFO [management.subsystems.ChildApplicationContextFactory] [Thread-1] Starting 'OOoDirect' subsystem, ID: [OOoDirect, default]
2012-02-17 17:59:11,135 INFO [management.subsystems.ChildApplicationContextFactory] [Thread-1] Startup of 'OOoDirect' subsystem, ID: [OOoDirect, default] complete
2012-02-17 17:59:11,705 INFO [node.index.FullIndexRecoveryComponent] [Thread-1] Index recovery started: 15 transactions.
2012-02-17 17:59:11,705 INFO [node.index.FullIndexRecoveryComponent] [Thread-1] 10 % complete.
2012-02-17 17:59:11,705 INFO [node.index.FullIndexRecoveryComponent] [Thread-1] 20 % complete.
2012-02-17 17:59:11,721 INFO [node.index.FullIndexRecoveryComponent] [Thread-1] 30 % complete.
2012-02-17 17:59:12,697 INFO [node.index.FullIndexRecoveryComponent] [Thread-1] 40 % complete.
Additional info:
# Internal Error (allocation.cpp:215), pid=26736, tid=29544
# Error: Chunk::new
# JRE version: 6.0_22-b04
# Java VM: Java HotSpot(TM) 64-Bit Server VM (17.1-b03 mixed mode windows-amd64 )
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
————— T H R E A D —————
Current thread (0x0000000000372800): JavaThread "CompilerThread0" daemon [_thread_in_native, id=29544, stack(0x0000000064510000,0x0000000064550000)]
Stack: [0x0000000064510000,0x0000000064550000]
Current CompileTask:
C2:2247 org.apache.lucene.index.TermsHashPerField.quickSort([Lorg/apache/lucene/index/RawPostingList;II)V (267 bytes)
————— P R O C E S S —————
Java Threads: ( => current thread )
0x0000000066c70800 JavaThread "Timer-6" daemon [_thread_blocked, id=17196, stack(0x00000000695e0000,0x0000000069620000)]
0x0000000066c70000 JavaThread "Thread-11" daemon [_thread_blocked, id=6724, stack(0x00000000695a0000,0x00000000695e0000)]
0x0000000066c6f000 JavaThread "indexTrackerThread2" daemon [_thread_in_Java, id=28800, stack(0x0000000069970000,0x00000000699b0000)]
0x0000000066c6e800 JavaThread "indexTrackerThread1" daemon [_thread_blocked, id=30152, stack(0x0000000069900000,0x0000000069940000)]
0x0000000066c6d800 JavaThread "indexThread10" daemon [_thread_blocked, id=4788, stack(0x0000000069560000,0x00000000695a0000)]
0x0000000066c6d000 JavaThread "indexThread9" daemon [_thread_blocked, id=29172, stack(0x0000000069520000,0x0000000069560000)]
0x0000000066c6c000 JavaThread "indexThread8" daemon [_thread_blocked, id=29824, stack(0x00000000694b0000,0x00000000694f0000)]
0x0000000066c6b800 JavaThread "indexThread7" daemon [_thread_blocked, id=12492, stack(0x0000000069470000,0x00000000694b0000)]
0x0000000066c6b000 JavaThread "indexThread6" daemon [_thread_blocked, id=30128, stack(0x0000000069430000,0x0000000069470000)]
0x0000000066c6a000 JavaThread "indexThread5" daemon [_thread_blocked, id=23624, stack(0x00000000693f0000,0x0000000069430000)]
0x0000000066c69800 JavaThread "indexThread4" daemon [_thread_blocked, id=6596, stack(0x00000000693b0000,0x00000000693f0000)]
0x0000000066c68800 JavaThread "indexThread3" daemon [_thread_blocked, id=21112, stack(0x0000000069370000,0x00000000693b0000)]
0x0000000066c68000 JavaThread "MessageDispatcher" [_thread_in_native, id=30412, stack(0x00000000692c0000,0x0000000069300000)]
0x0000000066c67000 JavaThread "Timer-5" [_thread_blocked, id=26868, stack(0x0000000069280000,0x00000000692c0000)]
0x0000000066c66800 JavaThread "Timer-4" [_thread_blocked, id=10708, stack(0x0000000069240000,0x0000000069280000)]
0x0000000066c65800 JavaThread "Timer-3" [_thread_blocked, id=13532, stack(0x0000000069200000,0x0000000069240000)]
0x0000000064340800 JavaThread "Timer-2" [_thread_blocked, id=28544, stack(0x00000000691c0000,0x0000000069200000)]
0x000000006433f800 JavaThread "Timer-1" [_thread_blocked, id=1484, stack(0x0000000069330000,0x0000000069370000)]
0x000000006433f000 JavaThread "indexThread2" daemon [_thread_blocked, id=29624, stack(0x0000000069180000,0x00000000691c0000)]
0x000000006433e000 JavaThread "indexThread1" daemon [_thread_blocked, id=20004, stack(0x0000000069140000,0x0000000069180000)]
0x0000000064332000 JavaThread "IndexInfo Cleaner Deamon" daemon [_thread_blocked, id=29900, stack(0x0000000069100000,0x0000000069140000)]
0x000000006433d800 JavaThread "JobAcquisitionThread" [_thread_blocked, id=27784, stack(0x00000000690c0000,0x0000000069100000)]
0x000000006433d000 JavaThread "RMI TCP Connection(idle)" daemon [_thread_blocked, id=3120, stack(0x0000000069080000,0x00000000690c0000)]
0x000000006433c000 JavaThread "RMI RenewClean-[208.88.7.143:50506,org.alfresco.util.remote.server.socket.HostConfigurableSocketFactory@0]" daemon [_thread_blocked, id=29352, stack(0x0000000069040000,0x0000000069080000)]
0x000000006433b800 JavaThread "RMI TCP Accept-50506" daemon [_thread_in_native, id=30300, stack(0x0000000069000000,0x0000000069040000)]
0x000000006433a800 JavaThread "RMI TCP Connection(idle)" daemon [_thread_blocked, id=30308, stack(0x0000000068fc0000,0x0000000069000000)]
0x000000006433a000 JavaThread "RMI RenewClean-[208.88.7.143:50505,org.alfresco.util.remote.server.socket.HostConfigurableSocketFactory@0]" daemon [_thread_blocked, id=26500, stack(0x0000000068f80000,0x0000000068fc0000)]
0x0000000064339000 JavaThread "RMI TCP Accept-50505" daemon [_thread_in_native, id=14392, stack(0x0000000068f40000,0x0000000068f80000)]
0x0000000064338800 JavaThread "RMI TCP Connection(idle)" daemon [_thread_blocked, id=25468, stack(0x0000000068f00000,0x0000000068f40000)]
0x0000000064337800 JavaThread "RMI RenewClean-[208.88.7.143:50504,org.alfresco.util.remote.server.socket.HostConfigurableSocketFactory@0]" daemon [_thread_blocked, id=15784, stack(0x0000000068ec0000,0x0000000068f00000)]
0x0000000064337000 JavaThread "RMI TCP Accept-50504" daemon [_thread_in_native, id=26648, stack(0x0000000068e80000,0x0000000068ec0000)]
0x0000000064336800 JavaThread "RMI TCP Connection(idle)" daemon [_thread_blocked, id=14992, stack(0x0000000068e40000,0x0000000068e80000)]
0x0000000064335800 JavaThread "RMI RenewClean-[208.88.7.143:50502,org.alfresco.util.remote.server.socket.HostConfigurableSocketFactory@0]" daemon [_thread_blocked, id=29032, stack(0x0000000068e00000,0x0000000068e40000)]
0x0000000064335000 JavaThread "RMI TCP Accept-50502" daemon [_thread_in_native, id=30132, stack(0x0000000068dc0000,0x0000000068e00000)]
0x0000000064334000 JavaThread "RMI RenewClean-[208.88.7.143:50501,org.alfresco.util.remote.server.socket.HostConfigurableSocketFactory@0]" daemon [_thread_blocked, id=29028, stack(0x0000000068d80000,0x0000000068dc0000)]
0x0000000064333800 JavaThread "RMI TCP Accept-50501" daemon [_thread_in_native, id=27484, stack(0x0000000068d40000,0x0000000068d80000)]
0x0000000064332800 JavaThread "Thread-4" daemon [_thread_blocked, id=29192, stack(0x0000000068d00000,0x0000000068d40000)]
0x0000000064331000 JavaThread "DefaultScheduler_QuartzSchedulerThread" [_thread_blocked, id=28952, stack(0x0000000068c40000,0x0000000068c80000)]
0x0000000064330800 JavaThread "DefaultScheduler_Worker-10" [_thread_blocked, id=15072, stack(0x0000000068c00000,0x0000000068c40000)]
0x000000006432f800 JavaThread "DefaultScheduler_Worker-9" [_thread_blocked, id=28764, stack(0x0000000068bc0000,0x0000000068c00000)]
0x000000006432f000 JavaThread "DefaultScheduler_Worker-8" [_thread_blocked, id=27524, stack(0x0000000068b80000,0x0000000068bc0000)]
0x000000006432e000 JavaThread "DefaultScheduler_Worker-7" [_thread_blocked, id=7140, stack(0x0000000068b40000,0x0000000068b80000)]
0x000000006432d800 JavaThread "DefaultScheduler_Worker-6" [_thread_blocked, id=12068, stack(0x0000000068b00000,0x0000000068b40000)]
0x000000006432d000 JavaThread "DefaultScheduler_Worker-5" [_thread_blocked, id=22036, stack(0x0000000068ac0000,0x0000000068b00000)]
0x000000006432c000 JavaThread "DefaultScheduler_Worker-4" [_thread_blocked, id=12340, stack(0x0000000068a80000,0x0000000068ac0000)]
0x000000006432b800 JavaThread "DefaultScheduler_Worker-3" [_thread_blocked, id=26872, stack(0x0000000068a40000,0x0000000068a80000)]
0x000000006432a800 JavaThread "DefaultScheduler_Worker-2" [_thread_blocked, id=5252, stack(0x0000000068a00000,0x0000000068a40000)]
0x000000006432a000 JavaThread "DefaultScheduler_Worker-1" [_thread_blocked, id=18272, stack(0x00000000689c0000,0x0000000068a00000)]
0x0000000064329000 JavaThread "Timer-0" daemon [_thread_blocked, id=26268, stack(0x0000000068980000,0x00000000689c0000)]
0x0000000064328800 JavaThread "SolrWatcherScheduler_QuartzSchedulerThread" [_thread_blocked, id=18544, stack(0x0000000068940000,0x0000000068980000)]
0x0000000064327800 JavaThread "SolrWatcherScheduler_Worker-3" [_thread_blocked, id=4212, stack(0x0000000068900000,0x0000000068940000)]
0x0000000064327000 JavaThread "SolrWatcherScheduler_Worker-2" [_thread_blocked, id=25620, stack(0x00000000688c0000,0x0000000068900000)]
0x0000000064326800 JavaThread "SolrWatcherScheduler_Worker-1" [_thread_blocked, id=19220, stack(0x0000000068880000,0x00000000688c0000)]
0x0000000064325800 JavaThread "RMI TCP Connection(idle)" daemon [_thread_blocked, id=16492, stack(0x0000000068840000,0x0000000068880000)]
0x0000000064325000 JavaThread "RMI RenewClean-[208.88.7.143:50508]" daemon [_thread_blocked, id=19240, stack(0x0000000068800000,0x0000000068840000)]
0x0000000064324000 JavaThread "RMI Scheduler(0)" daemon [_thread_blocked, id=25764, stack(0x00000000687c0000,0x0000000068800000)]
0x0000000064323800 JavaThread "RMI TCP Connection(idle)" daemon [_thread_blocked, id=28868, stack(0x0000000068780000,0x00000000687c0000)]
0x0000000064322800 JavaThread "RMI Reaper" [_thread_blocked, id=19216, stack(0x0000000067740000,0x0000000067780000)]
0x0000000064322000 JavaThread "RMI TCP Accept-50508" daemon [_thread_in_native, id=28504, stack(0x0000000067700000,0x0000000067740000)]
0x0000000064321000 JavaThread "RMI TCP Accept-50500" daemon [_thread_in_native, id=28684, stack(0x00000000676c0000,0x0000000067700000)]
0x0000000065a03000 JavaThread "Store org.alfresco.cache.tagscopeSummaryCache Spool Thread" daemon [_thread_blocked, id=29412, stack(0x0000000067680000,0x00000000676c0000)]
0x00000000671ea000 JavaThread "Store org.alfresco.cache.ticketsCache Spool Thread" daemon [_thread_blocked, id=21032, stack(0x0000000067640000,0x0000000067680000)]
0x0000000066c3c800 JavaThread "net.sf.ehcache.CacheManager@409ba134" daemon [_thread_blocked, id=30588, stack(0x0000000067600000,0x0000000067640000)]
0x0000000064a84000 JavaThread "GC Daemon" daemon [_thread_blocked, id=26660, stack(0x0000000064790000,0x00000000647d0000)]
0x000000006445d000 JavaThread "Thread-1" [_thread_blocked, id=30180, stack(0x00000000646b0000,0x00000000646f0000)]
0x0000000064384800 JavaThread "RMI TCP Accept-0" daemon [_thread_in_native, id=28848, stack(0x0000000064610000,0x0000000064650000)]
0x000000000037f800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=26656, stack(0x0000000064590000,0x00000000645d0000)]
0x000000000037c800 JavaThread "CompilerThread1" daemon [_thread_blocked, id=23980, stack(0x0000000064550000,0x0000000064590000)]
=>0x0000000000372800 JavaThread "CompilerThread0" daemon [_thread_in_native, id=29544, stack(0x0000000064510000,0x0000000064550000)]
0x0000000000371000 JavaThread "Attach Listener" daemon [_thread_blocked, id=24696, stack(0x00000000644d0000,0x0000000064510000)]
0x000000000036d800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=29436, stack(0x0000000064490000,0x00000000644d0000)]
0x0000000000356000 JavaThread "Finalizer" daemon [_thread_blocked, id=10676, stack(0x0000000064250000,0x0000000064290000)]
0x0000000000354000 JavaThread "Reference Handler" daemon [_thread_blocked, id=26364, stack(0x0000000064210000,0x0000000064250000)]
0x000000000028c800 JavaThread "main" [_thread_in_native, id=24772, stack(0x0000000000800000,0x0000000000840000)]
Other Threads:
0x0000000000350000 VMThread [stack: 0x0000000000970000,0x00000000009b0000] [id=27004]
0x000000006445b000 WatcherThread [stack: 0x0000000064670000,0x00000000646b0000] [id=8676]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 151488K, used 56004K [0x0000000003c90000, 0x000000000e0e0000, 0x00000000191e0000)
eden space 134720K, 37% used [0x0000000003c90000, 0x0000000006e809c8, 0x000000000c020000)
from space 16768K, 29% used [0x000000000d080000, 0x000000000d5407e8, 0x000000000e0e0000)
to space 16768K, 0% used [0x000000000c020000, 0x000000000c020000, 0x000000000d080000)
tenured generation total 336252K, used 208787K [0x00000000191e0000, 0x000000002da3f000, 0x0000000043c90000)
the space 336252K, 62% used [0x00000000191e0000, 0x0000000025dc4c78, 0x0000000025dc4e00, 0x000000002da3f000)
compacting perm gen total 111360K, used 111186K [0x0000000043c90000, 0x000000004a950000, 0x0000000063c90000)
the space 111360K, 99% used [0x0000000043c90000, 0x000000004a924810, 0x000000004a924a00, 0x000000004a950000)
No shared spaces configured.
Dynamic libraries:
0x0000000000400000 - 0x0000000000416000 C:\Alfresco\tomcat\bin\tomcat6.exe
0x0000000077600000 - 0x00000000777ac000 C:\Windows\SYSTEM32\ntdll.dll
0x00000000773e0000 - 0x00000000774ff000 C:\Windows\system32\kernel32.dll
0x000007fefd650000 - 0x000007fefd6bc000 C:\Windows\system32\KERNELBASE.dll
0x0000000077500000 - 0x00000000775fa000 C:\Windows\system32\USER32.dll
0x000007fefe3b0000 - 0x000007fefe417000 C:\Windows\system32\GDI32.dll
0x000007fefdbb0000 - 0x000007fefdbbe000 C:\Windows\system32\LPK.dll
0x000007fefe540000 - 0x000007fefe60a000 C:\Windows\system32\USP10.dll
0x000007fefe230000 - 0x000007fefe2cf000 C:\Windows\system32\msvcrt.dll
0x000007fefe2d0000 - 0x000007fefe3ab000 C:\Windows\system32\ADVAPI32.dll
0x000007fefdf50000 - 0x000007fefdf6f000 C:\Windows\SYSTEM32\sechost.dll
0x000007fefe0b0000 - 0x000007fefe1de000 C:\Windows\system32\RPCRT4.dll
0x000007fefe820000 - 0x000007feff5a7000 C:\Windows\system32\SHELL32.dll
0x000007feff730000 - 0x000007feff7a1000 C:\Windows\system32\SHLWAPI.dll
0x000007feff7b0000 - 0x000007feff7de000 C:\Windows\system32\IMM32.DLL
0x000007fefe420000 - 0x000007fefe529000 C:\Windows\system32\MSCTF.dll
0x000000006d890000 - 0x000000006df61000 C:\Alfresco\java\jre\bin\server\jvm.dll
0x000007fef8dd0000 - 0x000007fef8e0b000 C:\Windows\system32\WINMM.dll
0x000000006d800000 - 0x000000006d80e000 C:\Alfresco\java\jre\bin\verify.dll
0x000000006d450000 - 0x000000006d477000 C:\Alfresco\java\jre\bin\java.dll
0x000000006d3b0000 - 0x000000006d3ba000 C:\Alfresco\java\jre\bin\hpi.dll
0x00000000777c0000 - 0x00000000777c7000 C:\Windows\system32\PSAPI.DLL
0x000000006d850000 - 0x000000006d862000 C:\Alfresco\java\jre\bin\zip.dll
0x000007fefe610000 - 0x000007fefe812000 C:\Windows\system32\ole32.dll
0x000000006d6a0000 - 0x000000006d6b7000 C:\Alfresco\java\jre\bin\net.dll
0x000007feff7e0000 - 0x000007feff82d000 C:\Windows\system32\WS2_32.dll
0x000007fefe530000 - 0x000007fefe538000 C:\Windows\system32\NSI.dll
0x000007fefcd00000 - 0x000007fefcd54000 C:\Windows\system32\mswsock.dll
0x000007fefced0000 - 0x000007fefced7000 C:\Windows\System32\wship6.dll
0x000007fefc750000 - 0x000007fefc757000 C:\Windows\System32\wshtcpip.dll
0x000007fefcb90000 - 0x000007fefcbeb000 C:\Windows\system32\DNSAPI.dll
0x000007fefb9d0000 - 0x000007fefb9f7000 C:\Windows\system32\IPHLPAPI.DLL
0x000007fefb940000 - 0x000007fefb94b000 C:\Windows\system32\WINNSI.DLL
0x000007fefb5d0000 - 0x000007fefb5e1000 C:\Windows\system32\dhcpcsvc6.DLL
0x000007fefb490000 - 0x000007fefb4a8000 C:\Windows\system32\dhcpcsvc.DLL
0x000007fefa860000 - 0x000007fefa868000 C:\Windows\system32\rasadhlp.dll
0x000007fefb830000 - 0x000007fefb883000 C:\Windows\System32\fwpuclnt.dll
0x000000006d5e0000 - 0x000000006d5ea000 C:\Alfresco\java\jre\bin\management.dll
0x000007fefcee0000 - 0x000007fefcef7000 C:\Windows\system32\CRYPTSP.dll
0x000007fefcac0000 - 0x000007fefcb07000 C:\Windows\system32\rsaenh.dll
0x000007fefd520000 - 0x000007fefd52f000 C:\Windows\system32\profapi.dll
0x000007fefd3f0000 - 0x000007fefd3ff000 C:\Windows\system32\CRYPTBASE.dll
0x000007fefc0e0000 - 0x000007fefc0f5000 C:\Windows\system32\NLAapi.dll
0x000007fefaa50000 - 0x000007fefaa5b000 C:\Windows\System32\winrnr.dll
0x000007fefaa30000 - 0x000007fefaa45000 C:\Windows\system32\napinsp.dll
0x0000000064920000 - 0x0000000064a44000 C:\Alfresco\tomcat\bin\tcnative-1.dll
0x000000006d740000 - 0x000000006d746000 C:\Alfresco\java\jre\bin\rmi.dll
0x000000006d6c0000 - 0x000000006d6cb000 C:\Alfresco\java\jre\bin\nio.dll
VM Arguments:
jvm_args: -Xms128M -Xmx1024M -Dalfresco.home=C:\Alfresco -Dcom.sun.management.jmxremote -Dcatalina.base=C:\Alfresco\tomcat -Dcatalina.home=C:\Alfresco\tomcat -Djava.endorsed.dirs=C:\Alfresco\tomcat\endorsed -XX:MaxPermSize=512m vfprintf
java_command: <unknown>
Launcher Type: generic
Environment Variables:
JAVA_HOME=C:\Alfresco\java\jre
PATH=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;
USERNAME=CT1950$
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 23 Stepping 10, GenuineIntel
————— S Y S T E M —————
OS: Windows NT 6.1 Build 7600
CPU:total 1 (1 cores per cpu, 1 threads per core) family 6 model 23 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1
Memory: 4k page, physical 1048576k(1048576k free), swap 16766332k(9788844k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (17.1-b03) for windows-amd64 JRE (1.6.0_22-b04), built on Sep 15 2010 00:45:56 by "java_re" with MS VC++ 8.0 (VS2005)
time: Fri Feb 17 17:47:53 2012
elapsed time: 121 seconds
Catalina Log:
# Error: Chunk::new
Execution result:
succeeded: false
exit code: 1
out:
Execution result:
succeeded: false
exit code: 1
out:
Additional info:
# Error: Chunk::new
Other Threads:
Heap
Dynamic libraries:
VM Arguments:
USERNAME=CT1950$
OS=Windows_NT
Options
‎02-18-2012 07:35 AM
Does this mean that you only have 1G of memory? That's not enough.
Options
‎02-26-2012 07:56 PM
Hi - sorry for the late response. I upped the memory and everything is working well. I thought 1G would be enough for testing.
ops:
Thanks for the help!
![Smiley Surprised Smiley Surprised](/i/smilies/16x16_smiley-surprised.png)
![](/skins/images/3EA4296CAFBBFFCF1FE252BDE05FE3BC/responsive_peak/images/icon_anonymous_message.png)
