Installation of Alfresco against Oracle instance
janet1969
created an oracle database on a remote server with a user called alfresco and the privilege grant any granted to the user
installed tomcat 6 and Oracle JDBC driver ocdbc14.jar on tomcat server
environment is Linux
Environment
Operating System Linux:
Web server:
Tomcat version  6.0.18
Database
Database version: is 10g 10.2.0.4 Enterprise edition
JDK and JRE
install JDK and JRE version
java version "1.6.0_23"
Java(TM) SE Runtime Environment (build 1.6.0_23-b05)
Java HotSpot(TM) Client VM (build 19.0-b09, mixed mode, sharing)
Configuration
One server with Oracle installed
One server  with tomcat, JDK and alfresco installed no other tomcat instances on the server
Testing
Tested that app server can connect to database by writing a test java classs
followed the instructions for installing using a war file contained in unzip file alfresco-community-3.4.c.zip ie copied alfresco and share war to webapps directory of tomcat server software
started the server and enter the url to alfresco got following errors
17:33:20,085 INFO  [org.alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/domain/cache-strategies.properties]
17:33:26,985 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'messageService' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'SearchService' while setting bean property 'searchService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'SearchService' defined in class path resource [alfresco/public-services-context.xml]:
This is repeated for each bean… any ideas
janet
11 REPLIES 11
gangadharjwala
i tried below steps in my location.but the tables were not registering on the DB and the alfersco & share dash boards were not comming through browesr
below is the db details i placed in alfresco-global.properties file.
db.name=xe
db.username=alfresco
db.password=alfresco
db.host=localhost
db.port=1521
db.driver=oracle.jdbc.OracleDriver
db.url=jdbcSmiley Surprisedracle:thin:@${db.host}:${db.port}:${db.name}
db.pool.validate.query=SELECT 1 FROM DUAL
hibernate.dialect=org.alfresco.repo.domain.hibernate.dialect.AlfrescoOracle9Dialect
And i placed ojdbc14.jar file on /tomcat/lib folder.
i attached the alfresco.log file.
can u please help me out on this…
mrogers
What version of alfresco are you using?
