IE9 and IE11/Edge issue
jasmith
I am having a ton of issues with IE11/Edge on displaying the various activiti tabs. essentially the main panel will not render, and I am receiving no errors on the console. (http://i.imgur.com/rLXAcTu.png)
On IE9 it seems the view of the process instance diagram and some of the deployed process definitions will only render the text and a small gray box. but I am getting an error on the console stating:
This tool only supports document modes 10 or higher.
(http://i.imgur.com/UYvYf7f.png)
strangely enough though it works fine on IE8…
I am trying to implement this for my company but we run IE9+ as our standard so I need it to fluidly on all versions from IE9 and up.
Are there any updates to put fixes for this scheduled?
James
vasile_dirla
Hi James,
Since we are moving towards an Angular JS based UI soon, (and probably the Vaadin application will be deprecated) we won't put much effort in resolving issue into current Vaadin application.
I don't have enough information in order to tell you when exactly it will be available but I can say that you'll like it Smiley Happy
Best regards,
