Hello, sorry for my english.
For 3 days alfresco has begun to fail me at the start and I can not find the reason.
Paste the LOG, if you can help me, please:
14:43:58,672 WARN [remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
14:43:59,586 WARN [alfresco.util.OpenOfficeConnectionTester] A connection to OpenOffice could not be established.
14:44:00,524 INFO [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.Oracle9Dialect.
14:44:00,557 INFO [domain.schema.SchemaBootstrap] Bypassing schema update checks.
14:44:01,723 INFO [repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /srv/alfresco/data
14:44:01,930 INFO [admin.patch.PatchExecuter] Checking for patches to apply …
14:44:01,993 INFO [repo.module.ModuleServiceImpl] Found 0 module(s).
14:44:02,096 INFO [service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_16-b02; maximum heap size 986,125MB
14:44:02,097 INFO [service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.1.0 (482) schema 64 - Installed version 2.1.0 (482) schema 64
14:44:02,329 ERROR [web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Unknown Exception in Transaction.
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:292)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:155)
at org.alfresco.repo.workflow.WorkflowInterpreter$1.doWork(WorkflowInterpreter.java:291)
at org.alfresco.repo.workflow.WorkflowInterpreter$1.doWork(WorkflowInterpreter.java:282)
at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:260)
at org.alfresco.repo.workflow.WorkflowInterpreter.interpretCommand(WorkflowInterpreter.java:280)
at org.alfresco.repo.workflow.WorkflowInterpreter.onBootstrap(WorkflowInterpreter.java:149)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:920)
at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:883)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:492)
Caused by: javax.transaction.RollbackException: Transaction didn't commit: Failed to prepare: requires rollback
at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:430)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:239)
… 40 more
Caused by: org.alfresco.repo.search.IndexerException: Failed to prepare: requires rollback
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory.prepare(AbstractLuceneIndexerAndSearcherFactory.java:684)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.beforeCommit(AlfrescoTransactionSupport.java:634)
at org.springframework.transaction.support.TransactionSynchronizationUtils.triggerBeforeCommit(TransactionSynchronizationUtils.java:48)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.triggerBeforeCommit(AbstractPlatformTransactionManager.java:821)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.processCommit(AbstractPlatformTransactionManager.java:637)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:624)
at org.springframework.transaction.interceptor.TransactionAspectSupport.commitTransactionAfterReturning(TransactionAspectSupport.java:307)
at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:420)
… 41 more
Caused by: org.alfresco.repo.search.IndexerException: Invalid state MARKED_ROLLBACK
at org.alfresco.repo.search.impl.lucene.index.IndexInfo.getTransition(IndexInfo.java:1171)
at org.alfresco.repo.search.impl.lucene.index.IndexInfo.setStatus(IndexInfo.java:1099)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneBase.setStatus(AbstractLuceneBase.java:256)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerImpl.setRollbackOnly(AbstractLuceneIndexerImpl.java:549)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerImpl.prepare(AbstractLuceneIndexerImpl.java:484)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory.prepare(AbstractLuceneIndexerAndSearcherFactory.java:679)
… 48 more
14:44:02,332 ERROR [[Catalina].[localhost].[/alfresco]] Excepción enviando evento inicializado de contexto a instancia de escuchador de clase org.springframework.web.context.ContextLoaderListener
… 40 more
… 41 more
… 48 more
14:44:02,334 ERROR [[Catalina].[localhost].[/alfresco]] Excepción enviando evento inicializado de contexto a instancia de escuchador de clase org.alfresco.web.app.ContextListener
… 40 more
… 41 more
… 48 more
25-abr-2012 14:44:02 org.apache.catalina.core.StandardContext start
GRAVE: Error listenerStart
GRAVE: Falló en arranque del Contexto [/alfresco] debido a errores previos
25-abr-2012 14:44:03 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Arrancando Coyote HTTP/1.1 en puerto http-8081
25-abr-2012 14:44:03 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:11009
25-abr-2012 14:44:03 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=1/12 config=null
25-abr-2012 14:44:03 org.apache.catalina.storeconfig.StoreLoader load
25-abr-2012 14:44:03 org.apache.catalina.startup.Catalina start
INFO: Server startup in 13722 ms
Exception in thread "NetBIOSRequest" java.lang.NullPointerException
at org.apache.log4j.LogManager.getLogger(LogManager.java:179)
at org.apache.log4j.Logger.getLogger(Logger.java:85)
at org.apache.commons.logging.impl.Log4JLogger.getLogger(Log4JLogger.java:229)
at org.apache.commons.logging.impl.Log4JLogger.isDebugEnabled(Log4JLogger.java:239)
at org.alfresco.filesys.netbios.server.NetBIOSNameServer$NetBIOSRequestHandler.run(NetBIOSNameServer.java:242)
Exception in thread "TCPHostAnnouncer" java.lang.NullPointerException
at org.apache.commons.logging.impl.Log4JLogger.error(Log4JLogger.java:193)
at org.alfresco.filesys.smb.mailslot.HostAnnouncer.run(HostAnnouncer.java:373)
Thanks.
