Help a Total Newb With AD Sync With Alfresco 4.0.D Please
jwintersteen
I'm trying desperately to get Alfresco 4.0.D to work properly with a AD LDAP system.
Here is the relevant info from the alfresco-global.properties file.
Authentication Chain
authentication.chain=passthru1:passthru,ldap-ad1:ldap-ad,alfrescoNtlm1:alfrescoNtlm
Passthrough
passthru.authentication.sso.enabled=true
passthru.authentication.allowGuestLogin=false
passthru.authentication.authenticateCIFS=false
passthru.authentication.authenticateFTP=false
passthru.authentication.servers=10.0.2.27
passthru.authentication.domain=mydomainname
passthru.authentication.useLocalServer=false
passthru.authentication.defaultAdministratorUserNames=administrator
passthru.authentication.connectTimeout=5000
passthru.authentication.offlineCheckInterval=300
passthru.authentication.protocolOrder=TCPIP,NETBIOS
LDAP Authentication
ldap.authentication.userNameFormat=%s
ldap.authentication.allowGuestLogin=false
ldap.authentication.java.naming.provider.url=ldap://ldapserverip:389
LDAP Synchronization
ldap.synchronization.java.naming.security.principal=CN=adminaccount,CN=admingroup,DC=mydomainname,DC=com
ldap.synchronization.java.naming.security.credentials=mydomainpassword
ldap.synchronization.attributeBatchSize=1000
ldap.synchronization.groupQuery=(objectclass\=group)
ldap.synchronization.personQuery=(&(objectclass\=user)(userAccountControl\:1.2.840.113556.1.4.803\:\=512))
ldap.synchronization.groupDifferentialQuery=(&(objectclass\=group)(!(modifyTimestamp<\={0})))
ldap.synchronization.personDifferentialQuery=(&(objectclass\=user)(userAccountControl\:1.2.840.113556.1.4.803\:\=512)(!(modifyTimestamp<\={0})))
ldap.synchronization.groupSearchBase=DC\=mydomainname,DC\=com
ldap.synchronization.userSearchBase=DC\=mydomainname,DC\=com
ldap.synchronization.timestampFormat=yyyyMMddHHmmss
ldap.synchronization.userIdAttributeName=sAMAccountName
ldap.synchronization.defaultHomeFolderProvider=userHomesHomeFolderProvider
ldap.synchronization.groupType=group
ldap.synchronization.personType=user
synchronization.synchronizeChangesOnly=true
cifs.enabled=false
Passthrough, and authentication work just fine. If I log in with any AD accounts the user is then searchable inside Alfresco, but that is the only way they show up.
I get this synch error from the stdout log:
2012-07-19 10:28:07,042  INFO  [management.subsystems.ChildApplicationContextFactory] [Thread-1] Starting 'Synchronization' subsystem, ID: [Synchronization, default]
2012-07-19 10:28:07,089  INFO  [management.subsystems.ChildApplicationContextFactory] [Thread-1] Starting 'Authentication' subsystem, ID: [Authentication, managed, passthru1]
2012-07-19 10:28:07,809  INFO  [management.subsystems.ChildApplicationContextFactory] [Thread-1] Startup of 'Authentication' subsystem, ID: [Authentication, managed, passthru1] complete
2012-07-19 10:28:07,809  INFO  [management.subsystems.ChildApplicationContextFactory] [Thread-1] Starting 'Authentication' subsystem, ID: [Authentication, managed, ldap-ad1]
2012-07-19 10:28:07,918  INFO  [management.subsystems.ChildApplicationContextFactory] [Thread-1] Startup of 'Authentication' subsystem, ID: [Authentication, managed, ldap-ad1] complete
2012-07-19 10:28:07,918  INFO  [management.subsystems.ChildApplicationContextFactory] [Thread-1] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
2012-07-19 10:28:08,012  INFO  [management.subsystems.ChildApplicationContextFactory] [Thread-1] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete
2012-07-19 10:28:08,012  INFO  [security.sync.ChainingUserRegistrySynchronizer] [Thread-1] Synchronizing users and groups with user registry 'ldap-ad1'
2012-07-19 10:28:08,028  INFO  [security.sync.ChainingUserRegistrySynchronizer] [Thread-1] Retrieving all groups from user registry 'ldap-ad1'
2012-07-19 10:28:08,028  ERROR [security.sync.ChainingUserRegistrySynchronizer] [Thread-1] Synchronization aborted due to error
org.alfresco.repo.security.authentication.AuthenticationException: 06190000 LDAP authentication failed.
   at org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl.buildInitialDirContext(LDAPInitialDirContextFactoryImpl.java:119)
   at org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl.getDefaultIntialDirContext(LDAPInitialDirContextFactoryImpl.java:94)
   at org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl.getDefaultIntialDirContext(LDAPInitialDirContextFactoryImpl.java:87)
   at org.alfresco.repo.security.sync.ldap.LDAPUserRegistry$3.<init>(LDAPUserRegistry.java:670)
   at org.alfresco.repo.security.sync.ldap.LDAPUserRegistry.getGroups(LDAPUserRegistry.java:667)
   at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer.syncWithPlugin(ChainingUserRegistrySynchronizer.java:632)
   at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer.synchronize(ChainingUserRegistrySynchronizer.java:435)
   at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer$6.doWork(ChainingUserRegistrySynchronizer.java:1650)
   at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:519)
   at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer.onBootstrap(ChainingUserRegistrySynchronizer.java:1644)
   at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:97)
   at org.alfresco.repo.management.subsystems.ChildApplicationContextFactory$ChildApplicationContext.publishEvent(ChildApplicationContextFactory.java:485)
   at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:911)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:428)
   at org.alfresco.repo.management.subsystems.ChildApplicationContextFactory$ApplicationContextState.start(ChildApplicationContextFactory.java:685)
   at org.alfresco.repo.management.subsystems.AbstractPropertyBackedBean.start(AbstractPropertyBackedBean.java:667)
   at org.alfresco.repo.management.subsystems.AbstractPropertyBackedBean.onApplicationEvent(AbstractPropertyBackedBean.java:473)
   at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEventInternal(SafeApplicationEventMulticaster.java:209)
   at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:180)
   at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:303)
   at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:276)
   at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
   at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4135)
   at org.apache.catalina.core.StandardContext.start(StandardContext.java:4630)
   at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:637)
   at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:563)
   at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:498)
   at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:445)
Caused by: javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C0903A9, comment: AcceptSecurityContext error, data 52e, v1db1 ]
   at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3041)
   at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2987)
   at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2789)
   at com.sun.jndi.ldap.LdapCtx.connect(LdapCtx.java:2703)
   at com.sun.jndi.ldap.LdapCtx.<init>(LdapCtx.java:293)
   at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:175)
   at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:193)
   at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:136)
   at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:66)
   at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:667)
   at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:288)
   at javax.naming.InitialContext.init(InitialContext.java:223)
   at javax.naming.InitialContext.<init>(InitialContext.java:197)
   at javax.naming.directory.InitialDirContext.<init>(InitialDirContext.java:82)
   at org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl.buildInitialDirContext(LDAPInitialDirContextFactoryImpl.java:114)
   … 50 more
2012-07-19 10:28:08,043  WARN  [security.sync.ChainingUserRegistrySynchronizer] [Thread-1] Failed initial synchronize with user registries
   … 50 more
I would appreciate any help you guys may be able to give. Thanks in advance.
arodriguez
Did your trouble has been fixed ?
I'm having similar issues … if you can share us your knowledge in this matter  Smiley Happy
Best regards.
bopolissimus
There may be other issues, but at least *this* line needs to have the equals signs escaped.  e.g.,
ldap.synchronization.java.naming.security.principal=CN\=adminaccount,CN\=admingroup,DC\=mydomainname,DC\=com
although I didn't hit this problem myself since my *.security.principal is of the form: [email protected]
