gwt and webscript calling problems
alessandro_orig
I have a gwt (google web toolkit) application which calls some webscripts, if i try to run my gwt application in hosted mode (to debug it) the application is executed on another port of another application server different from the application server on which i have installed alfresco
when my code calls the webscript the browser gives a window error (debug script) with Access denied, maybe it is not able to find the webscript
if i start my application not in hosted mode but in the same tomcat of my alfresco installation all webscripts called works perfectly
what is the problem???
openpj
Elite Collaborator
Elite Collaborator
Maybe you must change some webscript settings on the descriptor file, it seems to be an authentication problem.
Can you publish more details/source code about your Alfresco webscript implementation?
