Groovy script in scriptTask, process variable scoping issue?
jpalomaki
I have a Serializable Java bean object stored in process variable "application":
public class Application implements Serializable {
    private String identifier;
    // Getter + setter
Now if I modify this object in a groovy script using a <scriptTask /> like so:
<scriptTask id="setIdentifier" scriptFormat="groovy">
    <script>
        application.identifier = "123"
        // OR: application.setIdentifier("123")
    </script>
</scriptTask>
then the identifier is not stored to the Application object pointed to by the process variable "application".
If I do this however:
<scriptTask id="setIdentifier" scriptFormat="groovy" activiti:resultVariable="application">
    <script>
        application
    </script>
</scriptTask>
then the object pointed to the by the process variable "application" is indeed updated.
So it seems that a copy of the original object is made for the duration of the script, even if I refer to the process variable directly.
Is this expected behavior?
Jukka
jpalomaki
Oh and just for the record, this also works:
    <script>
        def local = application
        local.identifier = "123"
        application = local
    </script>
</scriptTask>
Regards,
Jukka
jbarrez
mmm, it must be something groovy specific then, because the engine doesnt do any copies.
mathiasd
I'm encoutering the same problem with a javascript task : http://forums.activiti.org/en/viewtopic.php?f=6&t=2394
I think the problem is that the object is updated only if there is an affectation (with the sign = ) in the script.
