Folder/item-permissions and problem with DeleteChildren permission
ogda
I'm using Alfresco Community 5.0.d.
I try to achieve the permission concept below in my document library.
For that I have created a new role "Moderator" in the files
alfresco-5.0.d/tomcat/shared/classes/alfresco/extension/model/permissionDefinitions.xml and
alfresco-5.0.d/tomcat/shared/classes/alfresco/extension/model/sitePermissionDefinitions.xml
and some other files.
The role is working (tested with different permission sets).
This is what I need to create:
<ul>
   <li>- Documents
      <ul>
         <li>- Folder A <- read permissions for all users for this folder and all children = working
            <ul>
               <li>- Folder A1 <- role Moderator must not delete this folder but must be able to create children (files and folder)
                  <ul>
                     <li>- Text-File A1.1 <- role Moderator must be able to delete this file, no matter who the author was (except owner = Admin / Site Manager)</li>
                     <li>- Folder A1a <- created by Administrator; must not be deleted by role Moderator
                        <ul>
                           <li>- all children <- role Moderator must be able to delete this files/folders, no matter who the author was (except owner = Admin / Site Manager)</li>
                        </ul>
                     </li>
                  </ul>
               </li>
            </ul>
         </li>
         <li>- Folder B</li>
      </ul>
   </li>
</ul>
So to clarify:
- I have 1 folder and 1 sub-folder created by Admin.
- role Moderator must be able to create and delete content in these 2 folders, no matter who the author was (except owner = Admin / Site Manager)
- Other sub-folders not created by an admin or Site Manager must be deletable by role Moderator.
- The specified 1 folder and the 1 sub-folder must not be deleted by role Moderator.
The problem I have is, that the permission "DeleteChildren" doesn't seem to work or only seems to work in combination with the permission "DeleteNode".
I can't give Folder A1 a permission (by setting the role Moderator), where sub-items can be deleted while Folder A1 cannot be deleted.
I found several other posts without a solution to the not working "DeleteChildren" permission.
Is this permission the wrong concept for what I try to achieve?
Is there any other way I can use to achieve the above concept?
Kind regards,
Joerg
ogda
Here is another topic with the same problem:
https://forums.alfresco.com/forum/developer-discussions/technical-architecture-discussion/cant-delet...
The permission DeleteChildren doesn't seem to work.
Edit:
I found another post to this unresolved topic:
https://forums.alfresco.com/es/node/35325
I can't imagine that one of the core functions of a DMS (allowing to delete items in a folder and preventing the deletion of the main folder) is broken in Alfresco so we must be missing something fundamental here.
