I create a New Activiti Project the usual way and I get an Eclipse project with a pom.xml file. I can create diagrams, I can generate JUnit test cases, I can create the .bar file. My problem is I cannot compile and run any of these JUnit tests. No Activiti class is recognized (not even JUnit) despite having all these classes in the .m2 local repository. In fact, I see that my Activiti project is not recognized as a Maven project by Eclipse: – there is no Maven entry in the Project contextual menu – there no "Maven Dependencies" section on the Libraries tab of the Java Build Path dialog
Anyone any idea of how to make the Activiti projects recognized as Maven project by Eclipse?
Some details of my setup: I'm using Activiti 5.14 (brought into Eclipse through the Eclipse update site as usual) and I'm using Eclipse Kepler SR2, more precisely the Eclipse DSL distribution And that has the M2E 1.4.0 Maven plugin included. Don't know exactly which details are relevant and which ones not. I hope is something trivial related to my Eclipse setup.
