Hello all,
I'm a newbie to both Alfresco and Tomcat, so forgive me if my question is a foolish one! However, I've intensively searched the internet and found no reference to my problem.
I'm trying to implement a custom content transformation based on the RuntimeExecutableContentTransformer class.
I've set up the appropriate .xml file and the transformer is loaded properly.
Here's the problem:
The invoked script (or executable) can't read and write the $target en $source files. ($CATALINA_HOME/temp/Alfresco/RuntimeExecutableContentTransformer_source_xxxxx.* and $CATALINA_HOME/temp/Alfresco/RuntimeExecutableContentTransformer_target_xxxxx.*)
It can however write to other files in this directory from the script, just not the ones created for that particular transformation.
The files seem to be locked, but I can modify them by hand from the linux shell, even while the transformation-process is running.
Alfresco is running under the root-context. File permissions are set appropriately.
I'm using the standard Tomcat/Alfresco 2.0 distributable with Debian Etch and MySQL 5.
Any help would be greatly appreciated.
K. Ayachi
