I have a question abot what document formats alfresco can convert between. For example word->PDF, PDF->rtf etc. Does there exist a list of what formats is handled?
There are a few convertions available, mostly based on what OpenOffice can do as this is what Alfresco uses. (the installer provides this) If you add an OCR program you can also set Alfresco to convert from tiff to txt, rtf or html depending on the program you use. I've also tested ppt to pdf, for that you need to install swftools.
Alfresco is "modular", so you can set it up as you like it…
Hope I've enlighted you a bit, and welcome to the forum
