Authentication problem.
statira
Hi guys! I encountered a strange problem with my alfresco. The thing is I have two accounts for each user, one in format name - John Doe, username - jdoe; and another in format name - jdoe, username - [email protected]. Users can login only with account in [email protected] format, which is fine untill they want to give others access rights for some document because they're looking for the user by his name John Doe which gives them the wrong account jdoe and, of course, the rights given to this account have no effect as he actually uses another account [email protected]! How can I get rid of this double accounts? Why is this even happening?
I'm running version 5.0.a on Ubuntu 14.04. Users access it from their Windows machines. I guess I misconfigured ldap authentication, but current configuration is the only one working, everything else I've tried resulted in another errors.
And another funny thing: if I use
ldap.authentication.userNameFormat=%[email protected]
instead of
ldap.authentication.userNameFormat=%s
the search stop working! Not entirely, advanced search still works fine, but if I just type something in the search box it results in a blank page. But I have one and only account for each user.))
Here is my config.:
### LDAP ###
authentication.chain=passthru1Smiley Tongueassthru,ldap1:ldap
### Passthru Config ###
passthru.authentication.useLocalServer=false
passthru.authentication.domain=
passthru.authentication.servers=10.1.1.1
passthru.authentication.guestAccess=false
passthru.authentication.defaultAdministratorUserNames=admin@company.com
#Timeout value when opening a session to an authentication server, in milliseconds
passthru.authentication.connectTimeout=5000
#Offline server check interval in seconds
passthru.authentication.offlineCheckInterval=300
passthru.authentication.protocolOrder=NetBIOS,TCPIP
passthru.authentication.authenticateCIFS=true
passthru.authentication.authenticateFTP=true
ntlm.authentication.sso.enabled=true
ntlm.authentication.mapUnknownUserToGuest=false
### LDAP-AD Auth ###
ldap.authentication.allowGuestLogin=false
ldap.authentication.java.naming.provider.url=ldap://10.1.1.1:389
ldap.authentication.defaultAdministratorUserNames=admin@company.com
### LDAP-AD Synch ###
ldap.synchronization.java.naming.security.authentication=simple
ldap.synchronization.java.naming.security.principal=admin@company.com
ldap.synchronization.java.naming.security.credentials=password
ldap.synchronization.attributeBatchSize=1000
ldap.synchronization.groupQuery=(objectclass\=group)
ldap.synchronization.groupDifferentialQuery=(&(objectclass\=group)(!(modifyTimestamp<\={0})))
ldap.synchronization.personQuery=(&(objectclass\=user)(userAccountControl\:1.2.840.113556.1.4.803\:\=512))
ldap.synchronization.personDifferentialQuery=(&(objectclass\=user)(userAccountControl\:1.2.840.113556.1.4.803\:\=512)(!(modifyTimestamp<\={0})))
ldap.synchronization.groupSearchBase=dc=diasoft,dc=ru
ldap.synchronization.userSearchBase=dc=diasoft,dc=ru
ldap.synchronization.timestampFormat=yyyyMMddHHmmss'.0Z'
ldap.synchronization.userIdAttributeName=sAMAccountName
ldap.synchronization.userOrganizationalIdAttributeName=company
ldap.synchronization.defaultHomeFolderProvider=largeHomeFolderProvider
ldap.synchronization.groupDisplayNameAttributeName=displayName
ldap.synchronization.groupType=group
ldap.synchronization.personType=user
csyeow
hi ..
may i know how user login to alfresco share http://localhost:8080/share ,
username  jdoe  or  [email protected] ?
maybe you can try this , add dc\=diasoft,dc\=ru
ldap.synchronization.groupSearchBase=dc\=diasoft,dc\=ru
ldap.synchronization.userSearchBase=dc\=diasoft,dc\=ru
restart the alfresco service and try.
if success proceed step 2 , add @company.com
restart alfresco service
try to login use jdoe  on http://localhost:8080/share
hope can help you
statira
Hi, csyeow. Thanks for your reply. I tried what you suggested with no success.
If I use
I can login as jdoe, but only advanced search works this way, and if I use
I can login as [email protected], and search works fine.
But no matter what the config is, both users present in alfresco at the same time, which leads to confusion.
