09-01-2009 02:08 AM
# The default authentication chain
authentication.chain=alfrescoNtlm1:alfrescoNtlm,passthru1:passthru,ldap1:ldap-adAll the other files from the subsystems\Authentication folder have been modified accordingly. User:System INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
User:System INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [managed, alfrescoNtlm1]
User:System INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [managed, alfrescoNtlm1] complete
User:System INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [managed, passthru1]
User:System INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [managed, passthru1] complete
User:System INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'fileServers' subsystem, ID: [default] complete
User:System INFO [management.subsystems.ChildApplicationContextFactory] Starting 'imap' subsystem, ID: [default]
User:System INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'imap' subsystem, ID: [default] complete
User:System INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Synchronization' subsystem, ID: [default]
User:System INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [managed, ldap1]
User:System INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [managed, ldap1] complete
User:System INFO [security.sync.ChainingUserRegistrySynchronizer] Synchronizing users and groups with user registry 'ldap1'
User:System INFO [security.sync.ChainingUserRegistrySynchronizer] Retrieving users changed since 1/09/2009 14:58:28 from user registry 'ldap1'
User:System INFO [security.sync.ChainingUserRegistrySynchronizer] Retrieving all groups from user registry 'ldap1'
User:System INFO [security.sync.ChainingUserRegistrySynchronizer] Finished synchronizing users and groups with user registry 'ldap1'
User:System INFO [security.sync.ChainingUserRegistrySynchronizer] 0 user(s) and 0 group(s) processed
User:System INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Synchronization' subsystem, ID: [default] complete16:01:22,721 User:admin ERROR [web.scripts.AbstractRuntime] Exception from executeScript - redirecting to status template error: 08010034 Wrapped Exception (wit
emplate): 08010033 Failed to execute script '/org/alfresco/repository/person/person.put.json.js (in classpath store file:C:/Alfresco/tomcat/webapps/alfresco/WEB
es/alfresco/templates/webscripts)': 08010032 User not found: USERNAME
org.alfresco.web.scripts.WebScriptException: 08010034 Wrapped Exception (with status template): 08010033 Failed to execute script '/org/alfresco/repository/pers
put.json.js (in classpath store file:C:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts)': 08010032 User not found: USERNAME
at org.alfresco.web.scripts.AbstractWebScript.createStatusException(AbstractWebScript.java:613)
at org.alfresco.web.scripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:165)
at org.alfresco.repo.web.scripts.RepositoryContainer$2.execute(RepositoryContainer.java:357)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:326)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecute(RepositoryContainer.java:407)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecuteAs(RepositoryContainer.java:424)
at org.alfresco.repo.web.scripts.RepositoryContainer.executeScript(RepositoryContainer.java:288)
at org.alfresco.web.scripts.AbstractRuntime.executeScript(AbstractRuntime.java:262)
at org.alfresco.web.scripts.AbstractRuntime.executeScript(AbstractRuntime.java:139)
at org.alfresco.web.scripts.servlet.WebScriptServlet.service(WebScriptServlet.java:122)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
Caused by: org.alfresco.scripts.ScriptException: 08010033 Failed to execute script '/org/alfresco/repository/person/person.put.json.js (in classpath store file:
at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:178)
at org.alfresco.repo.processor.ScriptServiceImpl.executeScript(ScriptServiceImpl.java:274)
at org.alfresco.repo.web.scripts.RepositoryScriptProcessor.executeScript(RepositoryScriptProcessor.java:108)
at org.alfresco.web.scripts.AbstractWebScript.executeScript(AbstractWebScript.java:819)
at org.alfresco.web.scripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:90)
… 21 more
Caused by: org.alfresco.repo.security.authentication.AuthenticationException: 08010032 User not found: USERNAME
at org.alfresco.repo.security.authentication.RepositoryAuthenticationDao.setEnabled(RepositoryAuthenticationDao.java:563)
at org.alfresco.repo.management.subsystems.ChainingSubsystemProxyFactory$1.invoke(ChainingSubsystemProxyFactory.java:95)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at $Proxy91.setEnabled(Unknown Source)
at org.alfresco.repo.jscript.People.enableAccount(People.java:290)
at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:243)
at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:66)
at org.mozilla.javascript.gen.c7._c1(file:C:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/repository/pers
put.json.js:51)
at org.mozilla.javascript.gen.c7.call(file:C:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/repository/per
.put.json.js)
at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:108)
at org.mozilla.javascript.gen.c7._c0(file:C:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/repository/pers
put.json.js:96)
.put.json.js)
.put.json.js)
at org.mozilla.javascript.gen.c7.exec(file:C:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/repository/per
.put.json.js)
at org.alfresco.repo.jscript.RhinoScriptProcessor.executeScriptImpl(RhinoScriptProcessor.java:457)
at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:174)
… 25 more09-04-2009 08:37 AM
09-04-2009 09:04 AM
09-06-2009 06:47 PM
