Alfresco 2.0 Preview Installation Problem from Binnary Pack
vinicius
I tried to install Afresco 2.0 Preview from Binnary Pack but happens this problem:
Could you help me?
[root@fortuna install]# ./AlfrescoCommunity-2.0Preview-Linux-x86-Install
This program must be run in a graphical environment
or in silent, unattended mode (with the -S option).
[root@fortuna install]# ./AlfrescoCommunity-2.0Preview-Linux-x86-Install -S
An error has occurred during installation
        error renaming "/opt/alfresco/tomcat/shared/classes/alfresco/extension/custom-db-connection.properties.<%ALF_DB%>": no such file or directory
    while executing
"file rename -force $src $dst"
    (procedure "::InstallJammer::actions::RenameFile" line 6)
    invoked from within
"::InstallJammer::actions::$type $obj"
    while executing
"::InstallJammer::ExecuteActions $action  -parent $id -conditions $eval"
    (procedure "::InstallJammer::actions::ExecuteAction" line 6)
    invoked from within
    while executing
"::InstallJammer::ExecuteActions Silent"
    (procedure "::InstallJammer::InstallMain" line 15)
    invoked from within
    (procedure "main" line 2)
    invoked from within
"main "
    invoked from within
"if {![info exists ::InstallJammer]} { main }"
    (file "/installkitvfs/main.tcl" line 20997)
4 REPLIES 4
paulhh
Hi
You need to pass in which DB config you want to use (the ALF_DB value):
    -DALF_DB=mysql
We will be upgrading to use the just released InstallJammer 1.1 which includes a console-based install mode.  However, that won't be ready in time for the 2.0 release.
Cheers
Paul.
vinicius
Hi Paul,
Thanks for agillity but this option does not work. I tried
./AlfrescoCommunity-2.0Preview-Linux-x86-Install -S -DALF_DB=mysql
and happen same error.
Could you help me?
luã_smiguelsequ
Same problem here:
# ./AlfrescoCommunity-2.0Preview-Linux-x86-Install -S -DALF_DB=mysql
    while executing
    invoked from within
    while executing
    invoked from within
    while executing
    invoked from within
    invoked from within
"main "
    invoked from within
Tested on Fedora Core 4. The directory for  /opt/alfresco/tomcat/shared/classes/alfresco/extension/ is properly created.
"Brain not found; please replace user and retry."
luã_smiguelsequ
Tried to install the new release for today, AlfrescoCommunity-2.0-Linux-x86-Install. I sadly report the exact problem as with the Preview version.
