3.4.e to 4.0a upgrade problem
jakew
Hi All,
I have been trying to upgrade a 3.4.e installation to 4.0a using the following procedure on RHEL 5.  However I am not able to log in after the upgrade.
1. Fresh 4.0a install and verified it works
2. Set db.schema.update = true in alfresco-global.properties
3. Configured DB parameters to point to existing 3.4.e DB
4. Conigured dir.root to point to 3.4.e dir.root
5. Changed index scheme to lucene index.subsystem.name=lucene
6. start alfresco 4.0a
Here is the content of alfresco.log
11:05:44,366 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
11:05:44,503 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
11:05:55,458 WARN  [org.alfresco.util.AbstractTriggerBean] Job ehCacheTracerJob is not active/enabled
11:05:59,836 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor Repository Template Processor for extension ftl
11:05:59,838 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor Repository Script Processor for extension js
11:06:10,949 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
11:06:13,340 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-1365878705663574439.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/link-validation-metadata-removing.sql).
11:06:13,365 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-4565112524309967837.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/varchar-field-sizes-quadruple-increasing.sql).
11:06:13,381 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-7079813555852776164.sql (Copied from classpath:alfresco/dbscripts/create/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoPostCreate-JBPM-FK-indexes.sql).
11:06:13,415 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-8281845189867119897.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/AclChangeSet-Tracking.sql).
11:06:13,475 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-2183382435795223037.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/NodeAssoc-Ordering.sql).
11:06:14,310 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-4638910372714902950.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/Node-Locale.sql).
11:06:28,007 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-2821070537298950547.sql (Copied from classpath:alfresco/dbscripts/create/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoCreate-SubscriptionTables.sql).
11:06:28,453 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] All executed statements:  /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-All_Statements-4475006657655645592.sql.
11:06:29,234 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Normalized schema (pre-bootstrap)  dumped to file /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-8010563341943481105-Startup.xml.
11:06:29,234 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Normalized schema (post-bootstrap) dumped to file /opt/alfresco-4.0.a/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-6298001683746983386.xml.
11:06:29,462 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Search' subsystem, ID: [Search, managed, lucene]
11:06:31,342 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Search' subsystem, ID: [Search, managed, lucene] complete
11:06:32,710 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'thirdparty' subsystem, ID: [thirdparty, default]
11:06:33,254 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'thirdparty' subsystem, ID: [thirdparty, default] complete
11:06:33,254 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'OOoDirect' subsystem, ID: [OOoDirect, default]
11:06:34,448 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'OOoDirect' subsystem, ID: [OOoDirect, default] complete
11:06:47,470 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /opt/alfresco-4.0.a/alf_data
11:06:47,769 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
11:06:59,968 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.fixUserQNames' (Fixes user store qnames to improve native authentication performance).
11:07:00,247 INFO  [org.alfresco.repo.admin.patch.impl.FixUserQNamesPatch] FixUserQNamesPatch: Commencing batch of 35 entries
11:07:08,416 INFO  [org.alfresco.repo.admin.patch.impl.FixUserQNamesPatch] FixUserQNamesPatch: Processed 35 entries out of 35. 100% complete. Rate: 4 per second. 0 failures detected.
11:07:08,417 INFO  [org.alfresco.repo.admin.patch.impl.FixUserQNamesPatch] FixUserQNamesPatch: Completed batch of 35 entries
11:07:12,675 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.redeployJbpmAdhocWorkflow' (Redeploy JBPM adhoc workflow).
11:07:12,712 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.mtFixAdminExistingTenants' (Fix bootstrapped creator/modifier).
11:07:13,205 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.activitiesEmailTemplate' (null).
11:07:18,447 WARN  [org.alfresco.repo.admin.patch.PatchExecuter] Patch description is not available: Patch[ id=patch.activitiesEmailTemplate, description=patch.activitiesEmailTemplate.description, fixesFromSchema=0, fixesToSchema=5005, targetSchema=5006]
11:07:18,561 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.newUserEmailTemplates' (Adds the email templates for notifying new users of their accounts).
11:07:21,568 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.inviteEmailTemplates' (Adds the email templates for inviting users to a Site).
11:07:25,053 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.htmlNotificationMailTemplates' (Adds HTML email templates for notifying users of new content).
11:07:29,272 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.imapSpacesLocaleTemplates' (Adds content templates for IMAP clients (Non-default locales only)).
11:07:32,858 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.fixAclInheritance' (Fixes any ACL inheritance issues.).
11:07:39,838 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.imap.clear.old.messages' (Remove old IMAP message templates).
11:07:43,578 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.migrateAttrDropOldTables' (Drops old alf_*attribute* tables and sequence).
11:07:43,896 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.activitiesTemplatesUpdate' (Updates activities email templates.).
11:07:56,796 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.followingMailTemplates' (Adds email templates for following notifications).
11:07:58,924 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.avmToAdmRemoteStore' (Migrates Share Surf config from AVM sitestore to DM Sites folder.).
11:07:58,925 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Retrieving paths from AVM store: sitestore:/alfresco/site-data
11:08:08,150 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Found: 437 AVM files nodes to migrate
11:08:08,151 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Retrieved: 437 AVM paths in 9226ms
11:08:09,246 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Commencing batch of 12 entries
11:08:10,795 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to find site id: Doc1
11:08:17,239 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Processed 12 entries out of 12. 100% complete. Rate: 1 per second. 0 failures detected.
11:08:17,239 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Completed batch of 12 entries
11:08:17,239 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Created 'surf-config' folders for: 11 sites in 7993ms
11:08:17,243 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Commencing batch of 437 entries
11:08:17,357 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:08:17,406 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-1-1.site~Doc1~dashboard.xml".
java.lang.IllegalArgumentException: nodeRef is a mandatory parameter
   at org.alfresco.util.ParameterCheck.mandatory(ParameterCheck.java:42)
   at org.alfresco.repo.node.db.DbNodeServiceImpl.getNodePairNotNull(DbNodeServiceImpl.java:170)
   at org.alfresco.repo.node.db.DbNodeServiceImpl.getChildByName(DbNodeServiceImpl.java:1777)
   at sun.reflect.GeneratedMethodAccessor451.invoke(Unknown Source)
   at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
   at org.alfresco.repo.tenant.MultiTNodeServiceInterceptor.invoke(MultiTNodeServiceInterceptor.java:104)
   at $Proxy8.getChildByName(Unknown Source)
   at org.alfresco.repo.service.StoreRedirectorProxyFactory$RedirectorInvocationHandler.invoke(StoreRedirectorProxyFactory.java:215)
   at $Proxy9.getChildByName(Unknown Source)
   at org.alfresco.repo.tagging.TagScopePropertyMethodInterceptor.invoke(TagScopePropertyMethodInterceptor.java:129)
   at org.alfresco.repo.node.MLPropertyInterceptor.invoke(MLPropertyInterceptor.java:303)
   at org.alfresco.repo.node.NodeRefPropertyMethodInterceptor.invoke(NodeRefPropertyMethodInterceptor.java:269)
   at org.alfresco.repo.model.filefolder.FileFolderServiceImpl.searchSimple(FileFolderServiceImpl.java:561)
   at org.alfresco.service.cmr.model.FileFolderUtil$SearchAsSystem.doWork(FileFolderUtil.java:120)
   at org.alfresco.service.cmr.model.FileFolderUtil$SearchAsSystem.doWork(FileFolderUtil.java:105)
   at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:519)
   at org.alfresco.service.cmr.model.FileFolderUtil.makeFolders(FileFolderUtil.java:77)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch.migrateNode(AVMToADMRemoteStorePatch.java:502)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch.access$900(AVMToADMRemoteStorePatch.java:77)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch$6.process(AVMToADMRemoteStorePatch.java:381)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch$6.process(AVMToADMRemoteStorePatch.java:359)
   at org.alfresco.repo.batch.BatchProcessor$TxnCallback.execute(BatchProcessor.java:712)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:388)
   at org.alfresco.repo.batch.BatchProcessor$TxnCallback.run(BatchProcessor.java:756)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
11:08:18,467 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
11:08:18,956 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete
11:08:24,394 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-1-1.site~management~dashboard.xml".
org.alfresco.service.cmr.model.FileExistsException: Existing file or folder page.component-1-1.site~management~dashboard.xml already exists
   at org.alfresco.repo.model.filefolder.FileFolderServiceImpl.createImpl(FileFolderServiceImpl.java:1200)
   at org.alfresco.repo.model.filefolder.FileFolderServiceImpl.create(FileFolderServiceImpl.java:1167)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch.migrateNode(AVMToADMRemoteStorePatch.java:545)
11:08:27,822 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-3-1.site~management~dashboard.xml".
org.alfresco.service.cmr.model.FileExistsException: Existing file or folder page.component-3-1.site~management~dashboard.xml already exists
11:08:30,633 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:08:30,677 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.navigation.site~Doc1~dashboard.xml".
11:08:33,094 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:08:33,133 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-2-2.site~Doc1~dashboard.xml".
11:08:33,841 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Unable to create folder: components for path: sitestore:/alfresco/site-data/components/page.navigation.site~management~dashboard.xml - as another txn is busy, will retry later.
11:08:35,398 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-2-2.site~exams~dashboard.xml".
org.alfresco.service.cmr.model.FileExistsException: Existing file or folder page.component-2-2.site~exams~dashboard.xml already exists
11:08:42,160 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:08:42,160 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-1-1.site~Doc1~dashboard.xml".
11:08:51,622 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:08:51,622 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-1-2.site~Doc1~dashboard.xml".
11:08:56,479 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:08:56,479 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-2-1.site~Doc1~dashboard.xml".
11:09:09,363 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:09:09,364 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-2-2.site~Doc1~dashboard.xml".
11:09:46,605 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:09:46,606 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.navigation.site~Doc1~dashboard.xml".
11:09:50,293 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:09:50,294 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.title.site~Doc1~dashboard.xml".
11:09:56,382 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Doc1
11:09:56,383 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/pages/site/Doc1/dashboard.xml".
11:10:10,565 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Processed 437 entries out of 437. 100% complete. Rate: 3 per second. 7 failures detected.
11:10:10,565 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Completed batch of 437 entries
11:10:10,565 ERROR [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: 7 error(s) detected. Last error from entry "sitestore:/alfresco/site-data/pages/site/Doc1/dashboard.xml"
11:10:11,215 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
=== Applied patch                 ===
RESULT:
Script completed
11:10:11,216 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
RESULT:
Re-deployed 1 workflows.
RESULT:
Script completed
RESULT:
Script completed
RESULT:
RESULT:
Generated qnames for 35 users.
RESULT:
Fixed 0 ACLs.
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary/app:email_templates/cm:invite (workspace://SpacesStore/615dd01b-bc6b-42f1-b253-29ff8bf630af)
RESULT:
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary/app:email_templates (workspace://SpacesStore/615dd01b-bc6b-42f1-b253-29ff8bf630af)
RESULT:
Old IMAP message templates have been removed from the repository
RESULT:
Preceded by alternative patch 'patch.eliminateDuplicates'.
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary/app:imap_configs/app:imap_templates (workspace://SpacesStore/615dd01b-bc6b-42f1-b253-29ff8bf630af)
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary/app:email_templates/app:notify_email_templates (workspace://SpacesStore/615dd01b-bc6b-42f1-b253-29ff8bf630af)
RESULT:
Drop tables alf_attributes, alf_global_attributes, alf_list_attribute_entries, alf_map_attribute_entries and sequence alf_attributes_seq
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
RESULT:
Updated 6 activities email templates.
RESULT:
Script completed
11:10:11,217 ERROR [org.alfresco.repo.admin.patch.PatchExecuter]
=== Failed to apply patch         ===
RESULT:
09130007 org.alfresco.service.cmr.model.FileExistsException: Existing file or folder page.navigation.site~management~dashboard.xml already exists
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch$7.execute(AVMToADMRemoteStorePatch.java:397)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch$7.execute(AVMToADMRemoteStorePatch.java:392)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch.applyInternal(AVMToADMRemoteStorePatch.java:402)
   at org.alfresco.repo.admin.patch.AbstractPatch.applyImpl(AbstractPatch.java:407)
   at org.alfresco.repo.admin.patch.AbstractPatch.access$000(AbstractPatch.java:52)
   at org.alfresco.repo.admin.patch.AbstractPatch$2.doWork(AbstractPatch.java:473)
   at org.alfresco.repo.admin.patch.AbstractPatch$2.doWork(AbstractPatch.java:456)
   at org.alfresco.repo.admin.patch.AbstractPatch.apply(AbstractPatch.java:478)
   at org.alfresco.repo.admin.patch.PatchServiceImpl$PatchWork.applyPatch(PatchServiceImpl.java:491)
   at org.alfresco.repo.admin.patch.PatchServiceImpl$PatchWork.execute(PatchServiceImpl.java:403)
   at org.alfresco.repo.admin.patch.PatchServiceImpl.applyPatch(PatchServiceImpl.java:258)
   at org.alfresco.repo.admin.patch.PatchServiceImpl.applyPatchAndDependencies(PatchServiceImpl.java:235)
   at org.alfresco.repo.admin.patch.PatchServiceImpl.applyOutstandingPatches(PatchServiceImpl.java:171)
   at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110)
   at $Proxy92.applyOutstandingPatches(Unknown Source)
   at org.alfresco.repo.admin.patch.PatchExecuter.applyOutstandingPatches(PatchExecuter.java:76)
   at org.alfresco.repo.admin.patch.PatchExecuter$1.doWork(PatchExecuter.java:124)
   at org.alfresco.repo.admin.patch.PatchExecuter$1.doWork(PatchExecuter.java:120)
   at org.alfresco.repo.admin.patch.PatchExecuter.onBootstrap(PatchExecuter.java:128)
   at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEventInternal(SafeApplicationEventMulticaster.java:209)
   at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:180)
   at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:303)
   at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:911)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:428)
   at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:276)
   at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
   at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:637)
   at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:563)
   at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:498)
11:10:11,217 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: 09130008 Not all patches could be applied
   at org.alfresco.repo.admin.patch.PatchExecuter.applyOutstandingPatches(PatchExecuter.java:111)
11:10:35,210 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
11:10:35,313 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
11:10:35,314 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
11:10:35,332 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
11:10:41,776 INFO  [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 313 Web Scripts (+0 failed), 323 URLs
11:10:41,776 INFO  [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 8 Package Description Documents (+0 failed)
11:10:41,776 INFO  [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 0 Schema Description Documents (+0 failed)
11:10:42,527 INFO  [org.springframework.extensions.webscripts.AbstractRuntimeContainer] Initialised Spring Surf Container Web Script Container (in 7190.9834ms)
11:10:42,531 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
11:10:42,534 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
11:19:00,250 INFO  [org.alfresco.web.site.EditionInterceptor] Unable to retrieve License information from Alfresco: 404
Can anyone point out what my problem might be?
17 REPLIES 17
neozone
I try to upgrade 3.4d to 3.4e first and it work fine but now I tried to upgrade to 4.0c and got error
alfresco.log
16:43:32,429 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
16:43:32,635 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
16:43:32,636 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
16:43:32,652 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
16:43:35,700 INFO  [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 312 Web Scripts (+0 failed), 322 URLs
16:43:35,700 INFO  [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 8 Package Description Documents (+0 failed)
16:43:35,700 INFO  [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 0 Schema Description Documents (+0 failed)
16:43:36,093 INFO  [org.springframework.extensions.webscripts.AbstractRuntimeContainer] Initialised Spring Surf Container Web Script Container (in 3422.865ms)
16:43:36,111 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
16:43:36,130 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
16:44:09,973 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
16:44:10,680 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
16:44:19,531 WARN  [org.alfresco.util.AbstractTriggerBean] Job ehCacheTracerJob is not active/enabled
16:44:23,311 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor Repository Template Processor for extension ftl
16:44:23,314 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor Repository Script Processor for extension js
16:44:31,146 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
16:44:36,329 WARN  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema validation found 76 potential problems, results written to: /opt/Alfresco/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-7729956137085131242.txt
16:44:40,525 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-8639831108951393155.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/property-unique-ctx-idx.sql).
16:44:40,551 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-6286575274352160629.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/authority-unique-idx.sql).
16:44:40,572 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-2454741673815749552.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/link-validation-metadata-removing.sql).
16:44:40,588 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-1411128326378611801.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/AVM-rename-dupes.sql).
16:44:40,620 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-9010371475703901702.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/varchar-field-sizes-quadruple-increasing.sql).
16:44:40,630 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-780211093144673093.sql (Copied from classpath:alfresco/dbscripts/create/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoPostCreate-JBPM-FK-indexes.sql).
16:44:40,640 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-6174084635001571861.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/AclChangeSet-Tracking.sql).
16:44:40,848 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-8867617822957404778.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/NodeAssoc-Ordering.sql).
16:44:42,948 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-7558525157751085319.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/Node-Locale.sql).
16:44:50,921 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-6824137677350992050.sql (Copied from classpath:alfresco/dbscripts/create/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoCreate-SubscriptionTables.sql).
16:44:50,942 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-2877739518513007216.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/Solr-Tracking.sql).
16:45:01,169 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] All executed statements:  /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-All_Statements-7816194401649737550.sql.
16:45:04,935 WARN  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema validation found 58 potential problems, results written to: /opt/Alfresco/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Post-Upgrade-2692373446830837063.txt
16:45:08,433 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Normalized schema (pre-bootstrap)  dumped to file /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-1175245410326342522-Startup.xml.
16:45:08,433 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Normalized schema (post-bootstrap) dumped to file /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-7346638812431071634.xml.
16:45:08,671 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Search' subsystem, ID: [Search, managed, lucene]
16:45:09,026 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Search' subsystem, ID: [Search, managed, lucene] complete
16:45:10,880 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'thirdparty' subsystem, ID: [thirdparty, default]
16:45:11,820 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'thirdparty' subsystem, ID: [thirdparty, default] complete
16:45:11,821 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'OOoDirect' subsystem, ID: [OOoDirect, default]
16:45:12,408 WARN  [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
16:45:12,433 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'OOoDirect' subsystem, ID: [OOoDirect, default] complete
16:45:20,848 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /opt/Alfresco/alf_data
16:45:21,382 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
16:45:22,570 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.fixUserQNames' (Fixes user store qnames to improve native authentication performance).
16:45:22,784 INFO  [org.alfresco.repo.admin.patch.impl.FixUserQNamesPatch] FixUserQNamesPatch: Commencing batch of 36 entries
16:45:27,154 INFO  [org.alfresco.repo.admin.patch.impl.FixUserQNamesPatch] FixUserQNamesPatch: Processed 36 entries out of 36. 100% complete. Rate: 8 per second. 0 failures detected.
16:45:27,154 INFO  [org.alfresco.repo.admin.patch.impl.FixUserQNamesPatch] FixUserQNamesPatch: Completed batch of 36 entries
16:45:27,374 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.redeployJbpmAdhocWorkflow' (Redeploy JBPM adhoc workflow).
16:45:27,385 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.imapSpacesLocaleTemplates' (A placeholder patch; usually marks a superceded patch.).
16:45:27,395 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.mtFixAdminExistingTenants' (Fix bootstrapped creator/modifier).
16:45:27,479 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.activitiesEmailTemplate' (null).
16:45:28,509 WARN  [org.alfresco.repo.admin.patch.PatchExecuter] Patch description is not available: Patch[ id=patch.activitiesEmailTemplate, description=patch.activitiesEmailTemplate.description, fixesFromSchema=0, fixesToSchema=5005, targetSchema=5006]
16:45:28,527 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.newUserEmailTemplates' (Adds the email templates for notifying new users of their accounts).
16:45:30,242 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.inviteEmailTemplates' (Adds the email templates for inviting users to a Site).
16:45:30,697 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.htmlNotificationMailTemplates' (Adds HTML email templates for notifying users of new content).
16:45:31,244 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.fixAclInheritance' (Fixes any ACL inheritance issues.).
16:45:33,970 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.imap.clear.old.messages' (Remove old IMAP message templates).
16:45:35,026 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.imapSpacesTemplates2' (Replaces content templates for IMAP clients).
16:45:36,986 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.migrateAttrDropOldTables' (Drops old alf_*attribute* tables and sequence).
16:45:37,091 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.activitiesTemplatesUpdate' (Updates activities email templates.).
16:45:39,240 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.followingMailTemplates' (Adds email templates for following notifications).
16:45:39,700 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.avmToAdmRemoteStore' (Migrates Share Surf config from AVM sitestore to DM Sites folder.).
16:45:39,702 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Retrieving paths from AVM store: sitestore:/alfresco/site-data
16:45:43,645 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Found: 900 AVM files nodes to migrate
16:45:43,645 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Retrieved: 900 AVM paths in 3943ms
16:45:44,067 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Commencing batch of 60 entries
16:45:51,035 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to find site id: Test_Sharepoint_on_Alfresco_Product_Server
16:46:00,905 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Processed 60 entries out of 60. 100% complete. Rate: 3 per second. 0 failures detected.
16:46:00,905 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Completed batch of 60 entries
16:46:00,905 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Created 'surf-config' folders for: 59 sites in 16838ms
16:46:01,166 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Commencing batch of 900 entries
16:46:01,276 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
16:46:01,531 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete
16:46:08,193 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
16:46:08,200 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-1-1.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
   at org.alfresco.repo.node.db.DbNodeServiceImpl.getChildByName(DbNodeServiceImpl.java:1817)
   at sun.reflect.GeneratedMethodAccessor464.invoke(Unknown Source)
   at $Proxy10.getChildByName(Unknown Source)
   at org.alfresco.repo.tagging.TagScopePropertyMethodInterceptor.invoke(TagScopePropertyMethodInterceptor.java:152)
   at org.alfresco.repo.node.MLPropertyInterceptor.invoke(MLPropertyInterceptor.java:305)
   at org.alfresco.repo.model.filefolder.FileFolderServiceImpl.searchSimple(FileFolderServiceImpl.java:589)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch.migrateNode(AVMToADMRemoteStorePatch.java:531)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch.access$1000(AVMToADMRemoteStorePatch.java:78)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch$6.process(AVMToADMRemoteStorePatch.java:410)
   at org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch$6.process(AVMToADMRemoteStorePatch.java:386)
16:46:09,394 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
16:46:09,394 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-2-2.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
16:46:13,777 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
16:46:13,782 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/pages/site/Test_Sharepoint_on_Alfresco_Product_Server/dashboard.xml".
16:46:14,816 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
16:46:14,817 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-1-2.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
16:46:20,989 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
16:46:20,995 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.navigation.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
16:46:24,065 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
16:46:24,066 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-2-1.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
16:46:24,963 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
16:46:24,963 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.title.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
16:46:33,419 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Processed 900 entries out of 900. 100% complete. Rate: 27 per second. 7 failures detected.
16:46:33,419 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Completed batch of 900 entries
16:46:33,419 ERROR [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: 7 error(s) detected. Last error from entry "sitestore:/alfresco/site-data/components/page.component-2-2.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml"
16:46:33,430 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Migrated: 900 AVM nodes to DM in 49363ms
16:46:33,442 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.copiedFromAspect' (Adds peer associations for cm:copiedfrom and cm:workingcopy (new model) and removes cm:source property).
16:46:33,514 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: Commencing batch of 135 entries
16:46:36,809 WARN  [org.alfresco.repo.dictionary.DictionaryDAO] Type not found: {http://www.alfresco.org/model/website/1.0}webassetCollection
16:46:36,950 WARN  [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: Failed to process entry "(6318, workspace://SpacesStore/deaf3527-342b-4cb8-af31-b9d31b3b66a0)".
org.alfresco.error.AlfrescoRuntimeException: 00090000 Node type is not recognised: {http://www.alfresco.org/model/website/1.0}webassetCollection
   at org.alfresco.repo.node.integrity.IncompleteNodeTagger.processNode(IncompleteNodeTagger.java:422)
   at org.alfresco.repo.node.integrity.IncompleteNodeTagger.access$100(IncompleteNodeTagger.java:60)
   at org.alfresco.repo.node.integrity.IncompleteNodeTagger$1.doWork(IncompleteNodeTagger.java:399)
   at org.alfresco.repo.node.integrity.IncompleteNodeTagger$1.doWork(IncompleteNodeTagger.java:391)
   at org.alfresco.repo.node.integrity.IncompleteNodeTagger.beforeCommit(IncompleteNodeTagger.java:405)
   at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.doBeforeCommit(AlfrescoTransactionSupport.java:747)
   at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.doBeforeCommit(AlfrescoTransactionSupport.java:727)
   at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.beforeCommit(AlfrescoTransactionSupport.java:687)
   at org.springframework.transaction.support.TransactionSynchronizationUtils.triggerBeforeCommit(TransactionSynchronizationUtils.java:95)
   at org.springframework.transaction.support.AbstractPlatformTransactionManager.triggerBeforeCommit(AbstractPlatformTransactionManager.java:927)
   at org.springframework.transaction.support.AbstractPlatformTransactionManager.processCommit(AbstractPlatformTransactionManager.java:737)
   at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:723)
   at org.springframework.transaction.interceptor.TransactionAspectSupport.commitTransactionAfterReturning(TransactionAspectSupport.java:393)
   at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:472)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:410)
16:46:36,961 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: Processed 133 entries out of 135. 99% complete. Rate: 38 per second. 1 failures detected.
16:46:36,961 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: Completed batch of 135 entries
16:46:36,961 ERROR [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: 1 error(s) detected. Last error from entry "(162593, workspace://version2Store/54621061-5dc7-4036-8085-208f3592ce9a)"
16:46:36,979 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.publishing.root' (Creates the publishing root folder in the Data Dictionary).
16:46:37,168 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.workflowNotification' (Patch to add workflow email notification email folder and template.).
16:46:37,646 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.nodeTemplatesFolder' (Patch to create new Data Dictionary folder for Share - Create Node by Template).
16:46:37,759 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateMimetypes3' (Fix mimetype for MPEG Audio).
16:46:37,773 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.sitesSpacePermissions' (Patch to remove the EVERYONE Contributor permissions on the Sites Space (parent container of all Sites)).
16:46:37,808 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateWorkflowNotificationTemplates' (Patch to update the workflow notification templates.).
16:46:39,782 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateMimetypes4' (Rationalise mimetypes for PhotoShop and AutoCad).
16:46:41,237 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateMimetypesWMA' (Fix mimetype for MS WMA Streaming Audio).
16:46:41,253 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateFollowingEmailTemplatesPatch' (Patch to update the following notification email templates.).
16:46:42,295 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.addDutchEmailTemplatesPatch' (Patch to add Dutch email templates.).
16:46:44,673 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.fixBpmPackages' (Corrects workflow package types and associations ).
16:46:59,170 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.siteLoadPatch.swsdp' (Loads a sample site into the repository.).
16:47:01,312 ERROR [org.alfresco.repo.admin.patch.PatchExecuter] 00090002 org.alfresco.error.AlfrescoRuntimeException: 00090001 Bootstrap failed
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:361)
   at org.alfresco.repo.admin.patch.impl.SiteLoadPatch.applyInternalImpl(SiteLoadPatch.java:297)
   at org.alfresco.repo.admin.patch.impl.SiteLoadPatch.applyInternal(SiteLoadPatch.java:166)
   at org.alfresco.repo.admin.patch.AbstractPatch$2$1.execute(AbstractPatch.java:466)
   at org.alfresco.repo.admin.patch.AbstractPatch$2$1.execute(AbstractPatch.java:463)
   at org.alfresco.repo.admin.patch.AbstractPatch$2.doWork(AbstractPatch.java:469)
   at $Proxy94.applyOutstandingPatches(Unknown Source)
   at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4135)
   at org.apache.catalina.core.StandardContext.start(StandardContext.java:4630)
   at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:905)
   at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:740)
   at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:500)
   at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:445)
Caused by: org.alfresco.service.cmr.view.ImporterException: Failed to import package at line 71; column 20 due to error: null
   at org.alfresco.repo.importer.view.ViewParser.parse(ViewParser.java:194)
   at org.alfresco.repo.importer.ImporterComponent.parserImport(ImporterComponent.java:414)
   at org.alfresco.repo.importer.ImporterComponent.importView(ImporterComponent.java:263)
   at org.alfresco.repo.importer.ImporterBootstrap.doImport(ImporterBootstrap.java:479)
   at org.alfresco.repo.importer.ImporterBootstrap.access$000(ImporterBootstrap.java:70)
   at org.alfresco.repo.importer.ImporterBootstrap$1$1.execute(ImporterBootstrap.java:350)
   at org.alfresco.repo.importer.ImporterBootstrap$1.doWork(ImporterBootstrap.java:354)
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:357)
   … 66 more
   at org.alfresco.repo.importer.ImporterComponent$NodeImporter.getAssocType(ImporterComponent.java:979)
   at org.alfresco.repo.importer.ImporterComponent$NodeImporter.access$2200(ImporterComponent.java:463)
   at org.alfresco.repo.importer.ImporterComponent$NodeImporter$CreateNewNodeImporterStrategy.importNode(ImporterComponent.java:1358)
   at org.alfresco.repo.importer.ImporterComponent$NodeImporter$ReplaceExistingNodeImporterStrategy.importNode(ImporterComponent.java:1500)
   at org.alfresco.repo.importer.ImporterComponent$NodeImporter.importNode(ImporterComponent.java:608)
   at org.alfresco.repo.importer.view.ViewParser.importNode(ViewParser.java:919)
   at org.alfresco.repo.importer.view.ViewParser.processStartAssoc(ViewParser.java:834)
   at org.alfresco.repo.importer.view.ViewParser.processStartElement(ViewParser.java:333)
   at org.alfresco.repo.importer.view.ViewParser.parse(ViewParser.java:176)
   … 75 more
16:47:01,341 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
RESULT:
Script completed
RESULT:
Script completed
16:47:01,342 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
RESULT:
Script completed
RESULT:
Script completed: rows updated = 0
RESULT:
RESULT:
Script completed
RESULT:
No-op patch
RESULT:
Script completed
RESULT:
RESULT:
Generated qnames for 36 users.
RESULT:
Fixed 0 ACLs.
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary/app:imap_configs/app:imap_templates (workspace://SpacesStore/2de0f4ac-b6dd-4b91-b1c3-686ba1f2134c)
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary/app:email_templates/cm:invite (workspace://SpacesStore/2de0f4ac-b6dd-4b91-b1c3-686ba1f2134c)
RESULT:
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary/app:email_templates (workspace://SpacesStore/2de0f4ac-b6dd-4b91-b1c3-686ba1f2134c)
16:47:01,343 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
RESULT:
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary/app:email_templates/app:notify_email_templates (workspace://SpacesStore/2de0f4ac-b6dd-4b91-b1c3-686ba1f2134c)
RESULT:
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
RESULT:
Updated activities email templates.
RESULT:
Script completed
RESULT:
Completed Share Surf config migration.
RESULT:
Fixed cm:copiedfrom model for 135 nodes.  See file /opt/Alfresco/tomcat/temp/Alfresco/longLife_patches/CopiedFromAspectPatch.log for details.
RESULT:
Imported view into bootstrap location: /app:company_home/app:dictionary (workspace://SpacesStore/2de0f4ac-b6dd-4b91-b1c3-686ba1f2134c)
RESULT:
16:47:01,344 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
RESULT:
RESULT:
Updating mimetypes.
   Finished updating mimetypes.
RESULT:
Permissions corrected.
RESULT:
Workflow Notification Templates successfully updated.
RESULT:
Updating mimetypes.
   Updated 1 content references with mimetype 'application/photoshop' to use 'image/vnd.adobe.photoshop'.
   Indexed 53 nodes in store 'workspace://SpacesStore'.
   Indexed 55 nodes in store 'archive://SpacesStore'.
RESULT:
Updating mimetypes.
RESULT:
Following notification email templates successfully updated.
RESULT:
Script completed
RESULT:
Dutch email templates have been successfully added.
RESULT:
Patch successful. 569 packages converted.
16:47:01,344 ERROR [org.alfresco.repo.admin.patch.PatchExecuter]
RESULT:
   … 66 more
   … 75 more
16:47:01,345 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: 00090003 Not all patches could be applied
16:54:54,462 INFO  [org.alfresco.web.site.EditionInterceptor] Unable to retrieve License information from Alfresco: 404
neozone
this is step I did
1. backup mysql database
2. backup alf_data
3. uninstall alfresco 3.4e
4. drop database alfresco
5. create database alfresco set utf8
6. install alfresco 4.0c (set to mysql jdbc)
7. mv /opt/Alfresco/alf_data   to /opt/Alfresco/alf_data.bak
8. restore alf_data from backup to /opt/Alfresco/ald_data
9. restore mysql database
10. config alfresco-global.properites
## Common Alfresco Properties #
dir.root=/opt/Alfresco/alf_data
alfresco.context=alfresco
alfresco.host=xxxxxxxxxxxxxxxxxxxx
alfresco.port=8080
alfresco.protocol=http
share.context=share
share.host=xxxxxxxxxxxxxxxxxxxx
share.port=8080
share.protocol=http
db.driver=org.gjt.mm.mysql.Driver
db.username=xxxxxxxxxxxxxxxxxxxx
db.password=xxxxxxxxxxxxxxxxxxxx
db.name=alfresco
db.url=jdbc:mysql://localhost/alfresco
### FTP Server Configuration ###
ftp.enabled=true
ftp.port=21
ftp.ipv6.enabled=false
### RMI service ports ###
alfresco.rmi.services.port=50500
avm.rmi.service.port=0
avmsync.rmi.service.port=0
attribute.rmi.service.port=0
authentication.rmi.service.port=0
repo.rmi.service.port=0
action.rmi.service.port=0
deployment.rmi.service.port=0
### External executable locations ###
ooo.exe=/opt/Alfresco/openoffice/program/soffice.bin
ooo.enabled=true
ooo.port=8100
ooo.port=8100
img.root=/opt/Alfresco/common
#img.root=/usr
img.dyn=${img.root}/lib
img.exe=${img.root}/bin/convert
swf.exe=/opt/Alfresco/common/bin/pdf2swf
jodconverter.enabled=false
jodconverter.officeHome=/opt/Alfresco/openoffice
jodconverter.portNumbers=8100
### Initial admin password ###
alfresco_user_store.adminpassword=xxxxxxxxxxxxxxxxxxxx
### E-mail site invitation setting ###
notification.email.siteinvite=true
### File Protocol Root ###
protocols.rootPath=/${spaces.company_home.childname}/${spaces.sites.childname}
### License location ###
dir.license.external=/opt/Alfresco
### Lucene indexing ###
#dir.keystore=${dir.root}/keystore
#solr.port.ssl=8443
### BPM Engine ###
system.workflow.engine.jbpm.enabled=false
# Index Recovery Mode
#index.recovery.mode=FULL
# Outbound Email Configuration
mail.host=xxxxxxxxxxxxxxxxxxxx
#mail.host=smtp.gmail.com
mail.port=25
#mail.port=465
mail.username=xxxxxxxxxxxxxxxxxxxx
#mail.username=xxxxxxxxxxxxxxxxxxxx
mail.password=xxxxxxxxxxxxxxxxxxxx
mail.encoding=UTF-8
mail.from.default=xxxxxxxxxxxxxxxxxxxx
#mail.from.default=xxxxxxxxxxxxxxxxxxxx
mail.smtp.auth=true
mail.protocol=smtp
mail.testmessage.send=true
mail.testmessage.to=xxxxxxxxxxxxxxxxxxxx
mail.testmessage.subject=Outbount_SMTP_TEST_SERVER
mail.testmessage.text=Outbound_SMTP_email_subsystem_is_working
# New Properties
#mail.smtps.starttls.enable=true
#mail.smtps.auth=true
#email.server.allowed.senders=.*
# IMAP
imap.server.enabled=true
imap.server.port=1143
imap.server.host=xxxxxxxxxxxxxxxxxxxx
# CIFS
cifs.enabled=true
cifs.domain=xxxxxxxxxxxxxxxxxxxx
cifs.hostannounce=true
cifs.serverName=xxxxxxxxxxxxxxxxxxxx
cifs.broadcast=192.168.1.255
cifs.urlfile.prefix=http://xxxxxxxxxxxxxxxxxxxx
cifs.ipv6.enabled=false
cifs.tcpipSMB.port=1445
cifs.netBIOSSMB.namePort=1137
cifs.netBIOSSMB.datagramPort=1138
cifs.netBIOSSMB.sessionPort=1139
11. copy mysql-connector-java-5.1.13-bin.jar to /opt/Alfresco/tomcat/lib/mysql-connector-java-5.1.13-bin.jar
that's all….
any solution to solve this problem??
loftux
that's all….
Looks like you had Web quick start installed in your previous install, it is missing that model. Either try to add that, or just add the model as described here https://forums.alfresco.com/en/viewtopic.php?f=8&t=41616
Also, try to delete the site Test_Sharepoint_on_Alfresco_Product_Server before upgrade if you do not have any important data there. The AVMToADMRemoteStorePatch seem to fail from time to time, not sure why. One observation is that an underpowered surver makes the threads clash, try on a more powerful machine. It usually completes, but for a site that do not get their setting files migrated, you may need to manually create them. Their are in folder surf-config, hidden from 4.0.c but I think you can display the folders by adding them in the path in the url. Use node browser to find out where they are.
neozone
Okay I added custom-model-context.xml and webSiteModel.xml  (no warning for this while re index "full" anymore)
But, I not found site name "Test_Sharepoint_on_Alfresco_Product_Server" anymore (search both in share & alfresco explorer)
However, I found it by use this url
http://xxx.xxx.x.xx:8080/alfresco/faces/jsp/admin/avm-console.jsp
by use command
"lsr, sitestore:/alfresco/site-data/components"
do I have to remove them manually  ? eg.
"rm, sitestore:/alfresco/site-data/components/page.component-1-1.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml"
loftux
If the Site has already been deleted, then you can just ignore the errors. Probably a site delete that didn't properly delete avm files, then the patch tries to migrate them from avm store to workSpace/spaceStore and the surf-config folder, but fails since it is not there. But the patch will succeed with all the other sites. Of course Test what I'm saying is correct, but if Alfresco starts up and you can browse all sites, then you are good.
neozone
still get error…..
part1
19:55:18,212 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
19:55:18,448 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
19:55:18,526 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
19:55:18,534 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
19:55:21,691 INFO  [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 312 Web Scripts (+0 failed), 322 URLs
19:55:21,691 INFO  [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 8 Package Description Documents (+0 failed)
19:55:21,691 INFO  [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 0 Schema Description Documents (+0 failed)
19:55:22,087 INFO  [org.springframework.extensions.webscripts.AbstractRuntimeContainer] Initialised Spring Surf Container Web Script Container (in 3533.156ms)
19:55:22,095 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
19:55:22,101 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
19:55:59,050 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
19:55:59,166 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
19:56:08,786 WARN  [org.alfresco.util.AbstractTriggerBean] Job ehCacheTracerJob is not active/enabled
19:56:13,486 INFO  [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor Repository Template Processor for extension ftl
19:56:13,489 INFO  [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor Repository Script Processor for extension js
19:56:20,679 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
19:56:28,077 WARN  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema validation found 76 potential problems, results written to: /opt/Alfresco/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Pre-Upgrade-6192859606807205088.txt
19:56:33,646 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-829056867561289785.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/property-unique-ctx-idx.sql).
19:56:33,803 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-1702379723630241691.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/authority-unique-idx.sql).
19:56:33,878 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-1407390107344397275.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/link-validation-metadata-removing.sql).
19:56:33,941 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-8932334446302860070.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/AVM-rename-dupes.sql).
19:56:34,043 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-6352261866404291865.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.4/org.hibernate.dialect.MySQLInnoDBDialect/varchar-field-sizes-quadruple-increasing.sql).
19:56:34,054 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-2496584916862038826.sql (Copied from classpath:alfresco/dbscripts/create/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoPostCreate-JBPM-FK-indexes.sql).
19:56:34,066 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-4473218059286203517.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/AclChangeSet-Tracking.sql).
19:56:34,605 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-2119513038948552349.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/NodeAssoc-Ordering.sql).
19:56:37,279 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-2402500784077113182.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/Node-Locale.sql).
19:56:45,570 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-5072923951058954481.sql (Copied from classpath:alfresco/dbscripts/create/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoCreate-SubscriptionTables.sql).
19:56:45,593 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-Update-4959054232329514193.sql (Copied from classpath:alfresco/dbscripts/upgrade/4.0/org.hibernate.dialect.MySQLInnoDBDialect/Solr-Tracking.sql).
19:56:56,782 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] All executed statements:  /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-All_Statements-6464186002603769463.sql.
19:56:59,656 WARN  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema validation found 58 potential problems, results written to: /opt/Alfresco/tomcat/temp/Alfresco/Alfresco-MySQLInnoDBDialect-Validation-Post-Upgrade-3577806989894952649.txt
19:57:02,573 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Normalized schema (pre-bootstrap)  dumped to file /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-6451875422155352730-Startup.xml.
19:57:02,573 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Normalized schema (post-bootstrap) dumped to file /opt/Alfresco/tomcat/temp/Alfresco/AlfrescoSchema-MySQLInnoDBDialect-5159460165571404986.xml.
19:57:03,005 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Search' subsystem, ID: [Search, managed, lucene]
19:57:03,362 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Search' subsystem, ID: [Search, managed, lucene] complete
19:57:04,935 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'thirdparty' subsystem, ID: [thirdparty, default]
19:57:06,180 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'thirdparty' subsystem, ID: [thirdparty, default] complete
19:57:06,180 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'OOoDirect' subsystem, ID: [OOoDirect, default]
19:57:47,281 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'OOoDirect' subsystem, ID: [OOoDirect, default] complete
19:57:52,159 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent] Index recovery started: 24,868 transactions.
19:58:01,686 WARN  [org.alfresco.repo.cache.TransactionalCache.org.alfresco.cache.contentDataTransactionalCache] Transactional update cache 'org.alfresco.cache.contentDataTransactionalCache' is full (5000).
19:59:02,042 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    10 % complete.
19:59:26,945 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    20 % complete.
20:00:15,106 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    30 % complete.
20:00:48,472 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    40 % complete.
20:01:14,523 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    50 % complete.
20:01:48,613 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    60 % complete.
20:02:20,844 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    70 % complete.
20:03:00,284 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    80 % complete.
20:03:31,242 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    90 % complete.
20:03:43,997 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent]    100 % complete.
20:03:48,652 INFO  [org.alfresco.repo.node.index.FullIndexRecoveryComponent] Index recovery completed.
20:03:48,886 INFO  [org.alfresco.repo.node.index.AVMFullIndexRecoveryComponent] Rebuilding indexes for 1 AVM Stores
20:03:48,887 INFO  [org.alfresco.repo.node.index.AVMFullIndexRecoveryComponent]     Rebuilding index for sitestore
20:03:49,413 INFO  [org.alfresco.repo.node.index.AVMFullIndexRecoveryComponent]   Reindex   100% complete
20:03:49,413 INFO  [org.alfresco.repo.node.index.AVMFullIndexRecoveryComponent] Finished rebuilding indexes for AVM Stores
20:03:51,072 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /opt/Alfresco/alf_data
20:03:51,128 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
20:03:51,753 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.fixUserQNames' (Fixes user store qnames to improve native authentication performance).
20:03:52,065 INFO  [org.alfresco.repo.admin.patch.impl.FixUserQNamesPatch] FixUserQNamesPatch: Commencing batch of 36 entries
20:03:53,556 INFO  [org.alfresco.repo.admin.patch.impl.FixUserQNamesPatch] FixUserQNamesPatch: Processed 36 entries out of 36. 100% complete. Rate: 24 per second. 0 failures detected.
20:03:53,556 INFO  [org.alfresco.repo.admin.patch.impl.FixUserQNamesPatch] FixUserQNamesPatch: Completed batch of 36 entries
20:03:53,674 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.redeployJbpmAdhocWorkflow' (Redeploy JBPM adhoc workflow).
20:03:53,686 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.imapSpacesLocaleTemplates' (A placeholder patch; usually marks a superceded patch.).
20:03:53,698 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.mtFixAdminExistingTenants' (Fix bootstrapped creator/modifier).
20:03:54,000 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.activitiesEmailTemplate' (null).
20:03:55,047 WARN  [org.alfresco.repo.admin.patch.PatchExecuter] Patch description is not available: Patch[ id=patch.activitiesEmailTemplate, description=patch.activitiesEmailTemplate.description, fixesFromSchema=0, fixesToSchema=5005, targetSchema=5006]
20:03:55,099 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.newUserEmailTemplates' (Adds the email templates for notifying new users of their accounts).
20:03:55,907 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.inviteEmailTemplates' (Adds the email templates for inviting users to a Site).
20:03:57,182 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.htmlNotificationMailTemplates' (Adds HTML email templates for notifying users of new content).
20:03:57,667 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.fixAclInheritance' (Fixes any ACL inheritance issues.).
20:04:00,605 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.imap.clear.old.messages' (Remove old IMAP message templates).
20:04:01,637 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.imapSpacesTemplates2' (Replaces content templates for IMAP clients).
20:04:02,940 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.migrateAttrDropOldTables' (Drops old alf_*attribute* tables and sequence).
20:04:03,850 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.activitiesTemplatesUpdate' (Updates activities email templates.).
20:04:07,250 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.followingMailTemplates' (Adds email templates for following notifications).
20:04:10,842 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.avmToAdmRemoteStore' (Migrates Share Surf config from AVM sitestore to DM Sites folder.).
neozone
part2
20:04:10,843 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Retrieving paths from AVM store: sitestore:/alfresco/site-data
20:04:12,544 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Found: 900 AVM files nodes to migrate
20:04:12,545 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Retrieved: 900 AVM paths in 1702ms
20:04:13,046 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Commencing batch of 60 entries
20:04:16,656 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to find site id: Test_Sharepoint_on_Alfresco_Product_Server
20:04:29,207 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Processed 60 entries out of 60. 100% complete. Rate: 3 per second. 0 failures detected.
20:04:29,207 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Completed batch of 60 entries
20:04:29,208 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Created 'surf-config' folders for: 59 sites in 16162ms
20:04:29,214 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Commencing batch of 900 entries
20:04:29,631 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
20:04:32,731 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete
20:04:41,037 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
20:04:41,308 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-1-1.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
java.lang.IllegalArgumentException: nodeRef is a mandatory parameter
   at org.alfresco.util.ParameterCheck.mandatory(ParameterCheck.java:42)
   at org.alfresco.repo.node.db.DbNodeServiceImpl.getNodePairNotNull(DbNodeServiceImpl.java:170)
   at sun.reflect.GeneratedMethodAccessor486.invoke(Unknown Source)
   at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
   at org.alfresco.repo.tenant.MultiTNodeServiceInterceptor.invoke(MultiTNodeServiceInterceptor.java:104)
   at $Proxy9.getChildByName(Unknown Source)
   at org.alfresco.repo.service.StoreRedirectorProxyFactory$RedirectorInvocationHandler.invoke(StoreRedirectorProxyFactory.java:215)
   at org.alfresco.repo.node.NodeRefPropertyMethodInterceptor.invoke(NodeRefPropertyMethodInterceptor.java:269)
   at org.alfresco.service.cmr.model.FileFolderUtil$SearchAsSystem.doWork(FileFolderUtil.java:120)
   at org.alfresco.service.cmr.model.FileFolderUtil$SearchAsSystem.doWork(FileFolderUtil.java:105)
   at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:519)
   at org.alfresco.service.cmr.model.FileFolderUtil.makeFolders(FileFolderUtil.java:77)
   at org.alfresco.repo.batch.BatchProcessor$TxnCallback.execute(BatchProcessor.java:712)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:388)
   at org.alfresco.repo.batch.BatchProcessor$TxnCallback.run(BatchProcessor.java:756)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
20:04:45,086 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
20:04:45,086 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-2-2.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
20:04:49,394 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
20:04:49,394 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-1-2.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
20:04:49,806 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
20:04:49,807 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/pages/site/Test_Sharepoint_on_Alfresco_Product_Server/dashboard.xml".
20:04:54,536 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
20:04:54,537 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.navigation.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
20:04:58,725 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
20:04:58,725 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.component-2-1.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
20:04:58,967 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] WARNING: unable to migrate path as site id cannot be found: Test_Sharepoint_on_Alfresco_Product_Server
20:04:58,967 WARN  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Failed to process entry "sitestore:/alfresco/site-data/components/page.title.site~Test_Sharepoint_on_Alfresco_Product_Server~dashboard.xml".
20:05:08,129 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Processed 900 entries out of 900. 100% complete. Rate: 23 per second. 7 failures detected.
20:05:08,129 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: Completed batch of 900 entries
20:05:08,129 ERROR [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] AVMToADMRemoteStorePatch: 7 error(s) detected. Last error from entry "sitestore:/alfresco/site-data/pages/site/Test_Sharepoint_on_Alfresco_Product_Server/dashboard.xml"
20:05:08,130 INFO  [org.alfresco.repo.admin.patch.impl.AVMToADMRemoteStorePatch] Migrated: 900 AVM nodes to DM in 55084ms
20:05:08,144 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.copiedFromAspect' (Adds peer associations for cm:copiedfrom and cm:workingcopy (new model) and removes cm:source property).
20:05:08,466 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: Commencing batch of 135 entries
20:05:11,759 ERROR [org.alfresco.repo.node.integrity.IntegrityChecker] Found 2 integrity violations:
The association target type is incorrect:
   Target Node: workspace://SpacesStore/34a1d944-7753-428e-9e59-d640d9c51c3d
   Association: Association[ class=ClassDef[name={http://www.alfresco.org/model/content/1.0}copiedfrom], name={http://www.alfresco.org/model/content/1.0}original, target class={http://www.alfresco.org/model/content/1.0}cmobject, source role=null, target role=null]
   Required Target Type: {http://www.alfresco.org/model/content/1.0}cmobject
   Actual Target Type: {http://www.alfresco.org/model/rule/1.0}rule
   Target Node: workspace://SpacesStore/8e67cd02-ce89-43b2-a02d-35c0c597a0dd
20:05:11,919 WARN  [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: Failed to process entry "(6318, workspace://SpacesStore/deaf3527-342b-4cb8-af31-b9d31b3b66a0)".
org.alfresco.repo.node.integrity.IntegrityException: 00090001 Found 2 integrity violations:
   at org.alfresco.repo.node.integrity.IntegrityChecker.checkIntegrity(IntegrityChecker.java:661)
   at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.beforeCommit(AlfrescoTransactionSupport.java:692)
20:05:11,949 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: Processed 133 entries out of 135. 99% complete. Rate: 38 per second. 1 failures detected.
20:05:11,985 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: Completed batch of 135 entries
20:05:11,985 ERROR [org.alfresco.repo.admin.patch.PatchExecuter] CopiedFromAspectPatch: 1 error(s) detected. Last error from entry "(162593, workspace://version2Store/54621061-5dc7-4036-8085-208f3592ce9a)"
20:05:12,019 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.publishing.root' (Creates the publishing root folder in the Data Dictionary).
20:05:12,295 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.workflowNotification' (Patch to add workflow email notification email folder and template.).
20:05:12,634 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.nodeTemplatesFolder' (Patch to create new Data Dictionary folder for Share - Create Node by Template).
20:05:12,704 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateMimetypes3' (Fix mimetype for MPEG Audio).
20:05:12,716 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.sitesSpacePermissions' (Patch to remove the EVERYONE Contributor permissions on the Sites Space (parent container of all Sites)).
20:05:13,011 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateWorkflowNotificationTemplates' (Patch to update the workflow notification templates.).
20:05:15,321 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateMimetypes4' (Rationalise mimetypes for PhotoShop and AutoCad).
20:05:16,162 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateMimetypesWMA' (Fix mimetype for MS WMA Streaming Audio).
20:05:16,259 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.updateFollowingEmailTemplatesPatch' (Patch to update the following notification email templates.).
20:05:18,174 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.addDutchEmailTemplatesPatch' (Patch to add Dutch email templates.).
20:05:20,454 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.fixBpmPackages' (Corrects workflow package types and associations ).
20:05:33,599 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]    Applying patch 'patch.siteLoadPatch.swsdp' (Loads a sample site into the repository.).
20:05:36,463 ERROR [org.alfresco.repo.admin.patch.PatchExecuter] 00090003 org.alfresco.error.AlfrescoRuntimeException: 00090002 Bootstrap failed
   at org.alfresco.repo.admin.patch.AbstractPatch.applyImpl(AbstractPatch.java:407)
   at org.alfresco.repo.admin.patch.AbstractPatch.access$000(AbstractPatch.java:52)
   at org.alfresco.repo.admin.patch.AbstractPatch$2.doWork(AbstractPatch.java:456)
   at org.alfresco.repo.admin.patch.AbstractPatch.apply(AbstractPatch.java:478)
   at org.alfresco.repo.admin.patch.PatchServiceImpl$PatchWork.applyPatch(PatchServiceImpl.java:491)
   at org.alfresco.repo.admin.patch.PatchServiceImpl$PatchWork.execute(PatchServiceImpl.java:403)
   at org.alfresco.repo.admin.patch.PatchServiceImpl.applyPatch(PatchServiceImpl.java:258)
   at org.alfresco.repo.admin.patch.PatchServiceImpl.applyPatchAndDependencies(PatchServiceImpl.java:235)
   at org.alfresco.repo.admin.patch.PatchServiceImpl.applyOutstandingPatches(PatchServiceImpl.java:171)
   at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110)
   at org.alfresco.repo.admin.patch.PatchExecuter.applyOutstandingPatches(PatchExecuter.java:76)
   at org.alfresco.repo.admin.patch.PatchExecuter$1.doWork(PatchExecuter.java:124)
   at org.alfresco.repo.admin.patch.PatchExecuter$1.doWork(PatchExecuter.java:120)
   at org.alfresco.repo.admin.patch.PatchExecuter.onBootstrap(PatchExecuter.java:128)
   at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEventInternal(SafeApplicationEventMulticaster.java:209)
   at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:180)
   at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:303)
   at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:911)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:428)
   at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:276)
   at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
   … 66 more
   … 75 more
20:05:36,484 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
=== Applied patch                 ===
RESULT:
Script completed
20:05:36,485 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
RESULT:
Script completed
RESULT:
Script completed
RESULT:
RESULT:
Re-deployed 1 workflows.
RESULT:
Script completed
RESULT:
No-op patch
RESULT:
Script completed
RESULT:
RESULT:
RESULT:
Fixed 0 ACLs.
RESULT:
20:05:36,486 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
RESULT:
RESULT:
RESULT:
RESULT:
Old IMAP message templates have been removed from the repository
RESULT:
RESULT:
Drop tables alf_attributes, alf_global_attributes, alf_list_attribute_entries, alf_map_attribute_entries and sequence alf_attributes_seq
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
RESULT:
RESULT:
Script completed
RESULT:
20:05:36,487 INFO  [org.alfresco.repo.admin.patch.PatchExecuter]
RESULT:
RESULT:
RESULT:
RESULT:
RESULT:
Updating mimetypes.
RESULT:
RESULT:
RESULT:
Updating mimetypes.
RESULT:
Updating mimetypes.
RESULT:
RESULT:
Script completed
RESULT:
RESULT:
20:05:36,488 ERROR [org.alfresco.repo.admin.patch.PatchExecuter]
=== Failed to apply patch         ===
RESULT:
   … 66 more
   … 75 more
20:05:36,488 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: 00090004 Not all patches could be applied
   at org.alfresco.repo.admin.patch.PatchExecuter.applyOutstandingPatches(PatchExecuter.java:111)
did something wrong with rule that I put on to site "Alfresco" for when who update/add new wiki ?
http://prntscr.com/57q1e
Or another error that cause problem?
loftux
You have been hit with this issue
https://issues.alfresco.com/jira/browse/ALF-11215
It is the patch patch.siteLoadPatch.swsdp
I just removed that patch from WEB-INF/classes/alfresco/patch/patch-services-context.xml by commenting the relevant bean.
It just adds demo data, and my opinion is that is not something you should do for an upgraded repository.
Just created an issue for its removal https://issues.alfresco.com/jira/browse/ALF-12337
