2008R2 AD-LDAP and Alfresco: SvcErr: DSID-031401E0, problem 5010 (UNAVAIL_EXTENSION)
locutus
Hello all.
I have configured Alfresco 4.0.d running on CentOS 5 and am successfully authenticating with AD LDAP.  I did this several months ago.  When I checked my logs recently I noticed that the nightly scheduled LDAP sync's were failing.  People who were in AD when this was originally configured can login.  I cannot see people in Alfresco who have recently been added to AD.
After troubleshooting the issue, here is the latest state of the logs:
2013-03-23 00:00:42,735  ERROR [quartz.core.JobRunShell] [DefaultScheduler_Worker-5] Job DEFAULT.ldapPeopleJobDetail threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 02231303 User and group import failed
        at org.alfresco.repo.security.sync.ldap.LDAPUserRegistry.processQuery(LDAPUserRegistry.java:1141)
        at org.alfresco.repo.security.sync.ldap.LDAPUserRegistry.getGroups(LDAPUserRegistry.java:667)
        at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer.syncWithPlugin(ChainingUserRegistrySynchronizer.java:632)
        at org.alfresco.repo.security.sync.ChainingUserRegistrySynchronizer.synchronize(ChainingUserRegistrySynchronizer.java:435)
        at org.alfresco.repo.security.sync.UserRegistrySynchronizerJob$1.doWork(UserRegistrySynchronizerJob.java:51)
        at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:519)
        at org.alfresco.repo.security.sync.UserRegistrySynchronizerJob.execute(UserRegistrySynchronizerJob.java:47)
Caused by: javax.naming.OperationNotSupportedException: [LDAP: error code 12 - 00002040: SvcErr: DSID-031401E0, problem 5010 (UNAVAIL_EXTENSION), data 0
^@]; remaining name 'DC=example,DC=com'
Here is the contents of ldap-ad-authentication.properties:
# This flag enables use of this LDAP subsystem for authentication. It may be
# that this subsytem should only be used for synchronization, in which case
# this flag should be set to false.
# This properties file brings together the common options for LDAP authentication rather than editing the bean definitions
# How to map the user id entered by the user to taht passed through to LDAP
# In Active Directory, this can either be the user principal name (UPN) or DN.
# UPNs are in the form <sAMAccountName>@domain and are held in the userPrincipalName attribute of a user
ldap.authentication.userNameFormat=%[email protected]
# The LDAP context factory to use
# The URL to connect to the LDAP server
ldap.authentication.java.naming.provider.url=ldap://1.2.3.4:389
# The authentication mechanism to use for password validation
# Escape commas entered by the user at bind time
# Useful when using simple authentication and the CN is part of the DN and contains commas
# Escape commas entered by the user when setting the authenticated user
# Useful when using simple authentication and the CN is part of the DN and contains commas, and the escaped \, is
# pulled in as part of an LDAP sync
# If this option is set to true it will break the default home folder provider as space names can not contain \
# Comma separated list of user names who should be considered administrators by default
ldap.authentication.defaultAdministratorUserNames=admin,user1,user2
# This flag enables use of this LDAP subsystem for user and group
# synchronization. It may be that this subsytem should only be used for
# authentication, in which case this flag should be set to false.
# The authentication mechanism to use for synchronization
ldap.synchronization.java.naming.security.authentication=simple
# The default principal to bind with (only used for LDAP sync). This should be a UPN or DN
ldap.synchronization.java.naming.security.principal=CN=Alfresco LDAP,OU=Service Accounts,DC=example,DC=com
# The password for the default principal (only used for LDAP sync)
ldap.synchronization.java.naming.security.credentials=supersecret
# If positive, this property indicates that RFC 2696 paged results should be
# used to split query results into batches of the specified size. This
# overcomes any size limits imposed by the LDAP server.
#former entry #ldap.synchronization.queryBatchSize=1000
# If positive, this property indicates that range retrieval should be used to fetch
# multi-valued attributes (such as member) in batches of the specified size.
# Overcomes any size limits imposed by Active Directory.
#former entry #ldap.synchronization.attributeBatchSize=1000
# The query to select all objects that represent the groups to import.
ldap.synchronization.groupQuery=(objectclass\=group)
# The query to select objects that represent the groups to import that have changed since a certain time.
ldap.synchronization.groupDifferentialQuery=(&(objectclass\=group)(!(modifyTimestamp<\={0})))
# The query to select all objects that represent the users to import.
ldap.synchronization.personQuery=(&(objectclass\=user)(userAccountControl\:1.2.840.113556.1.4.803\:\=512))
# The query to select objects that represent the users to import that have changed since a certain time.
ldap.synchronization.personDifferentialQuery=(&(objectclass\=user)(userAccountControl\:1.2.840.113556.1.4.803\:\=512)(!(modifyTimestamp<\={0})))
# The group search base restricts the LDAP group query to a sub section of tree on the LDAP server.
ldap.synchronization.groupSearchBase=DC\=example,DC\=com
# The user search base restricts the LDAP user query to a sub section of tree on the LDAP server.
ldap.synchronization.userSearchBase=DC\=example,DC\=com
# The name of the operational attribute recording the last update time for a group or user.
ldap.synchronization.modifyTimestampAttributeName=whenChanged
#previous entry #ldap.synchronization.modifyTimestampAttributeName=modifyTimestamp
# The timestamp format. Unfortunately, this varies between directory servers.
ldap.synchronization.timestampFormat=yyyyMMddHHmmss'.0Z'
# The attribute name on people objects found in LDAP to use as the uid in Alfresco
ldap.synchronization.userIdAttributeName=sAMAccountName
# The attribute on person objects in LDAP to map to the first name property in Alfresco
# The attribute on person objects in LDAP to map to the last name property in Alfresco
# The attribute on person objects in LDAP to map to the email property in Alfresco
# The attribute on person objects in LDAP to map to the organizational id  property in Alfresco
ldap.synchronization.userOrganizationalIdAttributeName=company
# The default home folder provider to use for people created via LDAP import
ldap.synchronization.defaultHomeFolderProvider=largeHomeFolderProvider
# The attribute on LDAP group objects to map to the authority name property in Alfresco
# The attribute on LDAP group objects to map to the authority display name property in Alfresco
ldap.synchronization.groupDisplayNameAttributeName=displayName
# The group type in LDAP
ldap.synchronization.groupType=group
# The person type in LDAP
ldap.synchronization.personType=user
# The attribute in LDAP on group objects that defines the DN for its members
# If true progress estimation is enabled. When enabled, the user query has to be run twice in order to count entries.
So based on this error:
I found this article:
http://support.microsoft.com/kb/977180
I don't have access to the Windows environment.  So here is the question for the community:
Am I doing something wrong or is something mis-configured somewhere?  If no to those, is there a workaround?  Or is the only solution to get the Windows team to apply the update mentioned in the microsoft article?
Thanks!
michaelböckling
It is possible you are hitting this issue: https://issues.alfresco.com/jira/browse/MNT-5897
Just adapt your queries and try again.
locutus
I had restarted Alfresco after making your suggested changes but I still could not see the ldap user in Alfresco.  I tried again the next day (after the scheduled sync job ran) and I can see the user now.
Saw this in catalina.out - thanks!
2013-03-26 00:01:11,822  WARN  [security.sync.ChainingUserRegistrySynchronizer] [ldap-ad1 User Creation and Association2] Updating user 'dmcneill'. This user will in future be assumed to originate from user registry 'ldap-ad1'.
