STARTSWITH on simple String property in pageprovider does not works
Yvan_Frezefond
I have no result when I use STARTSWITH predicate in my page provider on a simple String property. If I change the predicate with a LIKE all is working.
Is there someone with the same issue ?
Thanks.
__11
Write the NXQL query without the "SELECT * FROM Document WHERE" part which is already generated).
Then add your where clause conditions which need to filter for specific DocType.
Also use this **AND ecm:fulltext = '?*' **
__11
Note: PageProvider may give WARNING .. Please ignore and use, it works.
Yvan_Frezefond
The explication is in the documentation :
STARTSWITH matches path-like values. When used with ecm:path, it matches documents whose path is strictly under the specified path. When used with an arbitrary string-based property, it assumes that the property value has the form of a /-separated path, and then matches if the value is equal to or under the specified path.
My property value has not the form of a /-separated path.
Thanks.
