03-06-2012 09:31 AM
I installed the 4th hotfix. If i want to open or upload a file in any workspace, i get the next error.
Document does not exist.
The upload part works fine only after the upload nuxeo wants to open the document and i get the same error. If i uninstall the hotfix all the documents opens fine also the one i just uploaded.
I,m using clean Nuxeo 5.5 installation on Ubuntu 11.10 (Virtualbox)
regards John
03-06-2012 09:53 AM
Did you try restarting Nuxeo after the hotfix install? Also what is the complete error you get (use pastebin.com)?
03-06-2012 10:31 AM
Exception
03-06-2012 10:32 AM
Hello Florent,
03-06-2012 10:33 AM
A workaroud to wait for a real fix: create a new document under the collaboration domain whose name is sections
03-06-2012 10:50 AM
I think not using hotfix for the moment is a better workaroud. lucky Nuxeo makes it very easy to go back one hotfix
03-06-2012 01:32 PM
A new version of nuxeo-5.5.0-HF04, 1.1.0, is available.
03-06-2012 02:14 PM
And its working again thanks for the fast fix
