08-27-2015 05:23 AM
after some time creating and editing documents in Nuxeo 7.2, I get this error:
No ManagedConnections available within configured blocking timeout ( 100 [ms] ) for pool org.apache.geronimo.connector.outbound.SinglePoolMatchAllConnectionInterceptor@19397d12
javax.el.ELException: org.nuxeo.ecm.core.api.local.LocalException: Failed to load repository default: Connection pool is fully used, consider increasing nuxeo.vcs.blocking-timeout-millis (currently 100) or nuxeo.vcs.max-pool-size (currently 20)
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:339)
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:348)
at org.jboss.el.parser.AstPropertySuffix.invoke(AstPropertySuffix.java:58)
at org.jboss.el.parser.AstValue.invoke(AstValue.java:96)
at org.jboss.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276)
at org.nuxeo.ecm.platform.ui.web.rest.services.URLPolicyServiceImpl.navigate(URLPolicyServiceImpl.java:528)
at org.nuxeo.ecm.platform.ui.web.rest.RestfulPhaseListener.beforePhase(RestfulPhaseListener.java:94)
at com.sun.faces.lifecycle.Phase.handleBeforePhase(Phase.java:228)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:99)
at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:219)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:647)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.nuxeo.wss.servlet.BaseWSSFilter.doFilter(BaseWSSFilter.java:127)
at org.nuxeo.wss.servlet.FailSafeWSSFilter.doFilter(FailSafeWSSFilter.java:56)
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:83)
at org.jboss.seam.web.ExceptionFilter.doFilter(ExceptionFilter.java:64)
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:69)
at org.jboss.seam.web.RedirectFilter.doFilter(RedirectFilter.java:45)
at org.nuxeo.elasticsearch.web.sync.UIThreadMarker.doFilter(UIThreadMarker.java:46)
at org.jboss.seam.servlet.SeamFilter.doFilter(SeamFilter.java:158)
at org.nuxeo.ecm.core.management.jtajca.internal.Log4jWebFilter.doFilter(Log4jWebFilter.java:67)
at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.doFilterInternal(NuxeoAuthenticationFilter.java:423)
at org.nuxeo.ecm.platform.ui.web.auth.service.NuxeoAuthFilterChain.doFilter(NuxeoAuthFilterChain.java:36)
at org.nuxeo.ecm.platform.ui.web.auth.oauth.NuxeoOAuthFilter.doFilter(NuxeoOAuthFilter.java:120)
at org.nuxeo.ecm.platform.ui.web.auth.service.NuxeoAuthFilterChain.doFilter(NuxeoAuthFilterChain.java:34)
at org.nuxeo.ecm.platform.ui.web.auth.oauth2.NuxeoOAuth2Filter.doFilter(NuxeoOAuth2Filter.java:68)
at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.doFilter(NuxeoAuthenticationFilter.java:391)
at org.nuxeo.ecm.platform.web.common.exceptionhandling.NuxeoExceptionFilter.doFilter(NuxeoExceptionFilter.java:75)
at org.nuxeo.ecm.platform.web.common.encoding.NuxeoEncodingFilter.doFilter(NuxeoEncodingFilter.java:73)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:748)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:486)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:411)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:338)
at org.nuxeo.ecm.platform.ui.web.rest.FancyURLFilter.doFilter(FancyURLFilter.java:110)
at org.nuxeo.ecm.platform.web.common.requestcontroller.filter.NuxeoRequestControllerFilter.doFilter(NuxeoRequestControllerFilter.java:139)
at org.nuxeo.ecm.webdav.service.WIRequestFilter.doFilter(WIRequestFilter.java:58)
at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.doFilterInternal(NuxeoAuthenticationFilter.java:578)
at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:168)
at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:233)
at org.nuxeo.ecm.platform.web.common.requestcontroller.filter.NuxeoCorsFilter.doFilter(NuxeoCorsFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:503)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:421)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
Caused by: org.nuxeo.ecm.core.api.local.LocalException: Failed to load repository default: Connection pool is fully used, consider increasing nuxeo.vcs.blocking-timeout-millis (currently 100) or nuxeo.vcs.max-pool-size (currently 20)
at org.nuxeo.ecm.core.repository.RepositoryService.getSession(RepositoryService.java:228)
at org.nuxeo.ecm.core.api.local.LocalSession.createSession(LocalSession.java:117)
at org.nuxeo.ecm.core.api.local.LocalSession.getSession(LocalSession.java:107)
at org.nuxeo.ecm.core.api.AbstractSession.resolveReference(AbstractSession.java:344)
at org.nuxeo.ecm.core.api.AbstractSession.getDocument(AbstractSession.java:953)
at org.nuxeo.ecm.webapp.context.NavigationContextBean.navigateToRef(NavigationContextBean.java:640)
at org.nuxeo.ecm.webapp.context.NavigationContextBean.navigateTo(NavigationContextBean.java:727)
at sun.reflect.GeneratedMethodAccessor1275.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.jboss.seam.util.Reflections.invoke(Reflections.java:22)
at org.jboss.seam.intercept.RootInvocationContext.proceed(RootInvocationContext.java:32)
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:56)
at org.jboss.seam.transaction.RollbackInterceptor.aroundInvoke(RollbackInterceptor.java:28)
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68)
at org.jboss.seam.core.BijectionInterceptor.aroundInvoke(BijectionInterceptor.java:79)
at org.nuxeo.ecm.platform.ui.web.util.NuxeoExceptionInterceptor.aroundInvoke(NuxeoExceptionInterceptor.java:78)
at org.jboss.seam.core.ConversationInterceptor.aroundInvoke(ConversationInterceptor.java:56)
at org.jboss.seam.core.MethodContextInterceptor.aroundInvoke(MethodContextInterceptor.java:44)
at org.jboss.seam.intercept.RootInterceptor.invoke(RootInterceptor.java:107)
at org.jboss.seam.intercept.JavaBeanInterceptor.interceptInvocation(JavaBeanInterceptor.java:196)
at org.jboss.seam.intercept.JavaBeanInterceptor.invoke(JavaBeanInterceptor.java:114)
at org.nuxeo.ecm.webapp.context.NavigationContextBean_$$_javassist_seam_13.navigateTo(NavigationContextBean_$$_javassist_seam_13.java)
at org.nuxeo.ecm.platform.ui.web.rest.RestHelper.initContextFromRestRequest(RestHelper.java:107)
at sun.reflect.GeneratedMethodAccessor1274.invoke(Unknown Source)
at org.nuxeo.ecm.platform.ui.web.rest.RestHelper_$$_javassist_seam_12.initContextFromRestRequest(RestHelper_$$_javassist_seam_12.java)
at sun.reflect.GeneratedMethodAccessor2295.invoke(Unknown Source)
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:335)
... 94 more
Caused by: org.nuxeo.ecm.core.api.DocumentException: Connection pool is fully used, consider increasing nuxeo.vcs.blocking-timeout-millis (currently 100) or nuxeo.vcs.max-pool-size (currently 20)
at org.nuxeo.ecm.core.storage.sql.ra.ConnectionFactoryImpl.getSession(ConnectionFactoryImpl.java:168)
at org.nuxeo.ecm.core.repository.RepositoryService.getSession(RepositoryService.java:226)
... 145 more
Caused by: org.nuxeo.ecm.core.storage.StorageException: Connection pool is fully used, consider increasing nuxeo.vcs.blocking-timeout-millis (currently 100) or nuxeo.vcs.max-pool-size (currently 20)
at org.nuxeo.ecm.core.storage.sql.ra.ConnectionFactoryImpl.getConnection(ConnectionFactoryImpl.java:114)
at org.nuxeo.ecm.core.storage.sql.ra.ConnectionFactoryImpl.getSession(ConnectionFactoryImpl.java:166)
... 146 more
Caused by: javax.resource.ResourceException: No ManagedConnections available within configured blocking timeout ( 100 [ms] ) for pool org.apache.geronimo.connector.outbound.SinglePoolMatchAllConnectionInterceptor@19397d12
at org.apache.geronimo.connector.outbound.AbstractSinglePoolConnectionInterceptor.getConnection(AbstractSinglePoolConnectionInterceptor.java:86)
at org.apache.geronimo.connector.outbound.ThreadLocalCachingConnectionInterceptor.getConnection(ThreadLocalCachingConnectionInterceptor.java:70)
at org.apache.geronimo.connector.outbound.TransactionEnlistingInterceptor.getConnection(TransactionEnlistingInterceptor.java:49)
at org.apache.geronimo.connector.outbound.TransactionCachingInterceptor.getConnection(TransactionCachingInterceptor.java:101)
at org.apache.geronimo.connector.outbound.ConnectionHandleInterceptor.getConnection(ConnectionHandleInterceptor.java:43)
at org.apache.geronimo.connector.outbound.TCCLInterceptor.getConnection(TCCLInterceptor.java:39)
at org.apache.geronimo.connector.outbound.ConnectionTrackingInterceptor.getConnection(ConnectionTrackingInterceptor.java:66)
at org.apache.geronimo.connector.outbound.AbstractConnectionManager.allocateConnection(AbstractConnectionManager.java:77)
at org.nuxeo.runtime.jtajca.NuxeoContainer$ConnectionManagerWrapper.allocateConnection(NuxeoContainer.java:838)
at org.nuxeo.ecm.core.storage.sql.ra.ConnectionFactoryImpl.getConnection(ConnectionFactoryImpl.java:100)
... 147 more
I tried increasing nuxeo.vcs.blocking-timeout-millis and nuxeo.vcs.max-pool-size, but after a while, I get the same error.
I've tried searching how can I fix this and why it happens, but with no results. Can someone explain me why it happens and how can I solve the problem?
07-25-2016 10:57 AM
I cannot confirm it finally, since the bug was not always there from the beginning and sometimes appeared only later, but from our first tests it seems that Hotfix 13 really fixed our issue. It is very interesting that there are so many customers not having the issue, since it doesn't seem to be our special configuration but a general Nuxeo problem that causes the error. Nevertheless
01-11-2017 08:06 AM
hello ,I am getting same error as above in Nuxeo FT 8.2 Version,i am uploading document in nuxeo using document service and and retrieving through the NXQL query and it is working fine, but after some time i got the connection pool error and after restarting a nuxeo all operations are working. So is there any solution related to this problem? Is this possible to allow all connection in nuxeo?
04-10-2017 10:25 AM
I am getting the same error above in Nuxeo 7.10 LTS 2015. Can somebody help me to fix this problem?
09-17-2019 02:26 AM
just hit this one with nuxeo v10.10, says
