When spring loaded automatically bpmn, drools how to load?
feihuli
hi, Hello everybody , in activiti , there is a Business rule task components , you can call drools rules file . drl
But the official said the document is very simple, there are a lot of places do not understand , can only get groped , we encounter a problem, simply can not find the solution online , and ask you, if met , there is no good way .
I'm using spring automated deployment , to load bpmn file, in the configuration Business rule task component, there is no place to specify which rules file . Drl, always lead to the implementation of this component at the time , and reported no binding rule error , I found abroad activiti forum is not spring loaded configuration files and drl file approach does not explain how the deployment spring automatically processed , there are solutions to it?
Manual loading as follows :
ProcessEngine processEngine = ProcessEngines.getDefaultProcessEngine (); RepositoryService repositoryService = processEngine.getRepositoryService ();
RuntimeService runtimeService = processEngine.getRuntimeService ();
repositoryService.createDeployment ()
  . addClasspathResource ("rulesdemo.bpmn20.xml")
  . addClasspathResource ("rules.drl")
  . deploy ();
runtimeService.startProcessInstanceByKey ("rulesdemo");
4 REPLIES 4
trademak
Your question is very hard to understand due to the strange English sentences. But did you also configure the process engine configuration with the RulesDeployer like shown here?
<blockcode>
<property name="customPostDeployers">
      <list>
        <bean class="org.activiti.engine.impl.rules.RulesDeployer" />
      </list>
    </property>
</blockcode>
feihuli
Sorry, google translate these English words are generated, there may be not fluent, I was in China, my English is not very good, I was in-depth study activiti, this question makes me a little confused, so come here to ask, it seems language I did not express nerve disorders, can send me some documentation about Business rule task components, little detail
feihuli
Almost forgot, my mailbox is [email protected], thank you very much
trademak
If the user guide doesn't provide enough details, please look at the Activiti in Action book, which contains a detailed business rule task example.
Best regards,
