05-05-2008 07:11 PM
<service name="WorkflowWebService" provider="java:RPC" style="wrapped" use="literal">
<documentation>Accesses Workflows via WS</documentation>
<wsdlFile>/wsdl/workflow-service.wsdl</wsdlFile>
<parameter name="springBean" value="workflowService" />
<parameter name="wsdlTargetNamespace" value="http://www.alfresco.org/ws/service/workflow/1.0" />
<parameter name="wsdlServiceElement" value="WorkflowWebServiceService" />
<parameter name="schemaQualified" value="http://www.alfresco.org/ws/service/workflow/1.0" />
<parameter name="wsdlServicePort" value="WorkflowWebService" />
<parameter name="className" value="com.akwa.ws.repo.webservice.workflow.WorkflowWebService" />
<parameter name="wsdlPortType" value="WorkflowWebService" />
<parameter name="typeMappingVersion" value="1.2" />
<operation name="getWorkflows" qname="ns1:getWorkflows" soapAction="" xmlns:ns1="http://www.alfresco.org/ws/service/workflow/1.0" />
<parameter name="allowedMethods" value="getWorkflows" />
</service>
<bean id="workflowService" class="com.akwa.ws.repo.webservice.workflow.WorkflowWebService" >
<property name="workflowServiceImpl">
<ref bean="workflowServiceImpl"/>
</property>
</bean>
Giving “workflowServiceImpl†is an alfresco bean
/** Alfresco JBPM Engine */
private WorkflowServiceImpl workflowServiceImpl = null;
public WorkflowWebService() { }
public void setWorkflowServiceImpl(WorkflowServiceImpl workflowServiceImpl) {
this.workflowServiceImpl = workflowServiceImpl;
System.out.println("WorkflowService : "+this.workflowServiceImpl);
public void getWorkflows() {
if (workflowServiceImpl == null) System.out.println("JBPM Engine null");
for (WorkflowDefinition def : workflowServiceImpl.getAllDefinitions()) {
System.out.println(def.getName()+" : "+def.getDescription());
05-06-2008 08:59 AM
WebServiceFactoryExtended.setEndpointAddress("http://localhost:8080/alfresco/api");
try {
AuthenticationUtils.startSession("admin", "admin");
WorkflowServiceSoapBindingStub workflowsService = WebServiceFactoryExtended.getWorkflowService();
workflowsService.getWorkflows();
ActionServiceSoapBindingStub actionService = WebServiceFactory.getActionService();
System.out.println(actionService.getUsername());
} catch (AuthenticationFault e) {
e.printStackTrace();
} catch (RemoteException e) {
if (this.workflowServiceImpl == null)
System.out.println("WorkflowService is null");
else
System.out.println("WorkflowService is NOT null");
System.out.println("Workflow 1 : "+this.workflowServiceImpl.getWorkflowById("jbpm$1"));
Result : WorkflowService : org.alfresco.repo.workflow.WorkflowServiceImpl@ae166c
12:58:22,328 ERROR [web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'workflowWebService' defined in class path resource [web-services-application-context.xml]: Error setting property values; nested exception is org.springframework.beans.PropertyBatchUpdateException; nested PropertyAccessExceptions (1) are:
PropertyAccessException 1: org.springframework.beans.MethodInvocationException: Property 'workflowServiceImpl' threw exception; nested exception is org.alfresco.error.AlfrescoRuntimeException: Transaction must be active and synchronization is required
Caused by: org.springframework.beans.PropertyBatchUpdateException; nested PropertyAccessException details (1) are:
Caused by: org.alfresco.error.AlfrescoRuntimeException: Transaction must be active and synchronization is required
at org.alfresco.repo.transaction.AlfrescoTransactionSupport.registerSynchronizations(AlfrescoTransactionSupport.java:390)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport.getSynchronization(AlfrescoTransactionSupport.java:375)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport.getResource(AlfrescoTransactionSupport.java:168)
at org.alfresco.repo.workflow.jbpm.JBPMTransactionTemplate.getContext(JBPMTransactionTemplate.java:115)
at org.springmodules.workflow.jbpm31.JbpmTemplate.execute(JbpmTemplate.java:73)
at org.alfresco.repo.workflow.jbpm.JBPMEngine.getWorkflowById(JBPMEngine.java:759)
at org.alfresco.repo.workflow.WorkflowServiceImpl.getWorkflowById(WorkflowServiceImpl.java:319)
at com.akwa.ws.repo.webservice.workflow.WorkflowWebService.setWorkflowServiceImpl(WorkflowWebService.java:29)
at org.springframework.beans.BeanWrapperImpl.setPropertyValue(BeanWrapperImpl.java:786)
at org.springframework.beans.BeanWrapperImpl.setPropertyValue(BeanWrapperImpl.java:606)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValue(AbstractPropertyAccessor.java:49)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:74)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:57)
at org.springframework.beans.factory.support.AbstractBeanFactory.applyPropertyValues(AbstractBeanFactory.java:840)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1026)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:809)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:425)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:250)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:141)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:247)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:161)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:273)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:346)
12:58:22,332 ERROR [[Catalina].[localhost].[/alfresco]] Exception lors de l'envoi de l'évènement contexte initialisé (context initialized) à l'instance de classe d'écoute (listener) org.springframework.web.context.ContextLoaderListener
12:58:22,345 ERROR [[Catalina].[localhost].[/alfresco]] Exception lors de l'envoi de l'évènement contexte initialisé (context initialized) à l'instance de classe d'écoute (listener) org.alfresco.web.app.ContextListener
05-23-2008 09:57 AM
02-12-2010 05:30 AM
BPMEngineRegistry registry = (BPMEngineRegistry)wc.getBean("bpm_engineRegistry");
TaskComponent taskcomponent = registry.getTaskComponent("jbpm");
org.alfresco.error.AlfrescoRuntimeException: 01120004 Transaction must be active and synchronization is required: Thread[http-8080-2,5,main]
at org.alfresco.repo.transaction.AlfrescoTransactionSupport.registerSynchronizations(AlfrescoTransactionSupport.java:436)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport.getSynchronization(AlfrescoTransactionSupport.java:420)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport.getResource(AlfrescoTransactionSupport.java:213)
at org.alfresco.repo.workflow.jbpm.JBPMEngine.getAssignedTasks(JBPMEngine.java:1167)
at org.apache.jsp.Welcome_jsp._jspService(Welcome_jsp.java:127)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:374)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:337)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:266)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
Feb 12, 2010 3:42:45 PM org.apache.catalina.core.ApplicationDispatcher invoke
