Hi , I have a webscript "testingSchema.xsd.ftl" which is bacsically a xmlschema . this XML schema is refernced by WEB Form under data dictionay . also i have created project using that schema , but now i need to add some new fields in my Xform , then i updated my "testingSchema.xsd.ftl" schema under webscript and add new fields.
My problem is that ,after adding new fields in my XML Schema "testingSchema.xsd.ftl" , and now when i try to edit my xform then it show some error like that : – "java.lang.NullPointerException: expected property {http://www.alfresco.org/model/wcmappmodel/1.0}xmlschema of workspace://SpacesStore/98594422-088b-4335-be36-6cdad43d8a8c for form Client Site Properties Form not to be null.'
Can anyone tell me what is the problem and what is the solution . any help will be highly appreciated . Thanks & Regards Komal
