Using Activiti Engine in my Web Application
mfm
I'm new to activiti and I really need help.
I have a python/django web app, and I want to use activiti engine in it.
According to the official book (activiti in action) I understand that there are two ways to connect the two.
Through REST API, or the one I'm trying to use, embedding activiti engine in a java application. Which for what I understand, I would only have to put the jars and it's dependencies in my web application. I'm I right here? If I use it as embedding I do not need REST API?
My biggest doubt comes now. How do I make my web application ready to receive the .bar file that I deploy through eclipse?
Is pyactiviti (Python library which wraps Activiti BPMN2.0 Engine API) anywhere near what I need?
I'm really lost here, and any help would be appreciated.
Regards,
Mónica Casanova
4 REPLIES 4
trademak
Running Activiti embedded with the Java JARs means that you don't have to use the REST API, that's correct.
You don't need to deploy a BAR file, it can also be a single BPMN 2.0 XML file. The Activiti Engine will store this in the Activiti database.
pyactiviti is a library I'm not familiar with as it's not part of the Activiti project.
Best regards,
mfm
thank you very much for your answer, it put me in the right path.
I understand that the Activiti Engine will store the XML file in the Activiti database, what I don't understand is how my application will recognised it. I mean, do I have to program in python in order to fetch the file and run it? is that it?
I really don't understand how python will grab that file and run it.. isn't there an API to do this? Because I can't find anything about this anywhere.
And by activiti database you mean the database I'm connected to, not the in-memory one, right?
Regards,
Mónica Casanova
mfm
Thank you very much for your answer, it put me in the right path.
I understand that the BPMN 2.0 XML file will be stored in the Activiti Database, what I don't understand is how my application will recognise it and run it. If I have to programm it, shouldn't there be a python-acitiviti API? Because I have looked everywhere and I can't seem to find anything about this.. maybe I'm understanding this wrong, but I can't understand how python will recognise the file and run it without it.
Regards,
Mónica Casanova
trademak
Activiti offers an API to retrieve process definitions, start process instances etc.
There's the RepositoryService and the RuntimeService for example.
If pyactiviti also exposes these interfaces I don't know, but I would definitely expect it.
Best regards,
