I upgraded my Alfresco installation from 4.2.d to 5.0.b. I restored the database and contentstore from a cold backup. Upon restart of the new 5.0.b installation, all documents are available, but indexing is not working. The solr.log is showing this:
21:35:00,049 ERROR [org.alfresco.solr.tracker.MetadataTracker] First transaction was not found with the correct timestamp.
21:35:00,049 ERROR [org.alfresco.solr.tracker.MetadataTracker] SOLR has successfully connected to your repository however the SOLR indexes and repository database do not match.
21:35:00,049 ERROR [org.alfresco.solr.tracker.MetadataTracker] If this is a new or rebuilt database your SOLR indexes also need to be re-built to match the database.
21:35:00,050 ERROR [org.alfresco.solr.tracker.MetadataTracker] You can also check your SOLR connection details in solrcore.properties.
21:35:00,058 ERROR [org.alfresco.solr.tracker.AbstractTracker] Tracking failed
org.alfresco.error.AlfrescoRuntimeException: 09130004 Initial acl transaction not found with correct timestamp
at org.alfresco.solr.tracker.AclTracker.checkRepoAndIndexConsistency(AclTracker.java:361)
at org.alfresco.solr.tracker.AclTracker.trackRepository(AclTracker.java:313)
at org.alfresco.solr.tracker.AclTracker.doTrack(AclTracker.java:104)
at org.alfresco.solr.tracker.AbstractTracker.track(AbstractTracker.java:155)
at org.alfresco.solr.tracker.TrackerJob.execute(TrackerJob.java:47)
So it appears I need to rebuild the index. The Alfresco documentation on this seems to be geared to the older version of SOLR. How do I rebuild the index in SOLR4? I'm not a programmer, so I would appreciate help.
