Unable to rebuild SOLR Index
cfox570
Running Community 4.0.d
I noticed a problem where new content would not appear in the search results.  I found documentation that said to remove the index directory.   I stopped the server, removed the folder, restarted.   A new index folder was created.  But it appears that none of the repository documents are being indexed. Is there some other trick to kick into gear?
I have confirmed that index is working for new content only.  How do I force the indexing of all of the existing content?
23 REPLIES 23
сougar
Hello, all.
I cannot rebuild my solr index
There is log.
If you have got some conclusions, write it plz.
21:38:35,225 ERROR [org.springframework.extensions.webscripts.AbstractRuntime] Exception from executeScript - redirecting to status template error: 10260001 Wrapped Exception (with status template): 10260008 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/collaboration/tagQuery.get.js': 10260007 Failed to execute search: ASPECT:"{http://www.alfresco.org/model/content/1.0}taggable"
org.springframework.extensions.webscripts.WebScriptException: 10260001 Wrapped Exception (with status template): 10260008 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/collaboration/tagQuery.get.js': 10260007 Failed to execute search: ASPECT:"{http://www.alfresco.org/model/content/1.0}taggable"
   at org.springframework.extensions.webscripts.AbstractWebScript.createStatusException(AbstractWebScript.java:1067)
   at org.alfresco.repo.web.scripts.RepositoryContainer$3.execute(RepositoryContainer.java:429)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:433)
   at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecute(RepositoryContainer.java:491)
   at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecuteAs(RepositoryContainer.java:529)
   at org.alfresco.repo.web.scripts.RepositoryContainer.executeScript(RepositoryContainer.java:345)
   at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:377)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
   at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
   at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
   at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
   at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1002)
   at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
   at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1813)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
Caused by: org.alfresco.scripts.ScriptException: 10260008 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/collaboration/tagQuery.get.js': 10260007 Failed to execute search: ASPECT:"{http://www.alfresco.org/model/content/1.0}taggable"
   at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:202)
   at org.alfresco.repo.processor.ScriptServiceImpl.execute(ScriptServiceImpl.java:212)
   at org.alfresco.repo.processor.ScriptServiceImpl.executeScript(ScriptServiceImpl.java:174)
   at org.alfresco.repo.web.scripts.RepositoryScriptProcessor.executeScript(RepositoryScriptProcessor.java:102)
   at org.springframework.extensions.webscripts.AbstractWebScript.executeScript(AbstractWebScript.java:1305)
   at org.springframework.extensions.webscripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:86)
   … 28 more
Caused by: org.alfresco.error.AlfrescoRuntimeException: 10260007 Failed to execute search: ASPECT:"{http://www.alfresco.org/model/content/1.0}taggable"
   at org.alfresco.repo.jscript.Search.query(Search.java:823)
   at org.alfresco.repo.jscript.Search.query(Search.java:778)
   at org.alfresco.repo.jscript.Search.query(Search.java:737)
   at org.alfresco.repo.jscript.Search.luceneSearch(Search.java:325)
   at org.alfresco.repo.jscript.Search.luceneSearch(Search.java:310)
   at java.lang.reflect.Method.invoke(Method.java:601)
   at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:243)
   at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:66)
   at org.mozilla.javascript.gen.c5._c1(file:/D:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/collaboration/tagQuery.get.js:51)
   at org.mozilla.javascript.gen.c5.call(file:/D:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/collaboration/tagQuery.get.js)
   at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:108)
   at org.mozilla.javascript.gen.c5._c0(file:/D:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/collaboration/tagQuery.get.js:180)
   at org.mozilla.javascript.gen.c5.exec(file:/D:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/collaboration/tagQuery.get.js)
   at org.alfresco.repo.jscript.RhinoScriptProcessor.executeScriptImpl(RhinoScriptProcessor.java:492)
   at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:198)
   … 33 more
Caused by: org.alfresco.repo.search.impl.lucene.LuceneQueryParserException: 10260006 Request failed 500 /solr/alfresco/alfresco?wt=json&fl=DBID%2Cscore&rows=2147483647&df=TEXT&start=0&locale=ru_RU&fq=%7B%21afts%7DAUTHORITY_FILTER_FROM_JSON&fq=%7B%21afts%7DTENANT_FILTER_FROM_JSON
   at org.alfresco.repo.search.impl.solr.SolrQueryHTTPClient.executeQuery(SolrQueryHTTPClient.java:398)
   at org.alfresco.repo.search.impl.solr.SolrQueryLanguage.executeQuery(SolrQueryLanguage.java:49)
   at org.alfresco.repo.search.impl.solr.SolrSearchService.query(SolrSearchService.java:348)
   at org.alfresco.repo.search.SearcherComponent.query(SearcherComponent.java:78)
   at org.alfresco.repo.management.subsystems.SubsystemProxyFactory$1.invoke(SubsystemProxyFactory.java:72)
   at $Proxy10.query(Unknown Source)
   at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
   at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110)
   at org.alfresco.repo.jscript.Search.query(Search.java:803)
   … 55 more
21:38:37,900 ERROR [org.springframework.extensions.webscripts.AbstractRuntime] Exception from executeScript - redirecting to status template error: 10260002 Wrapped Exception (with status template): 10260012 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/slingshot/documentlibrary-v2/doclist.get.js': 10260011 Failed to execute search:  +PATH:"/cm:generalclassifiable/member"
org.springframework.extensions.webscripts.WebScriptException: 10260002 Wrapped Exception (with status template): 10260012 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/slingshot/documentlibrary-v2/doclist.get.js': 10260011 Failed to execute search:  +PATH:"/cm:generalclassifiable/member"
   at org.alfresco.repo.web.scripts.RepositoryContainer$3.execute(RepositoryContainer.java:422)
Caused by: org.alfresco.scripts.ScriptException: 10260012 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/slingshot/documentlibrary-v2/doclist.get.js': 10260011 Failed to execute search:  +PATH:"/cm:generalclassifiable/member"
   … 28 more
Caused by: org.alfresco.error.AlfrescoRuntimeException: 10260011 Failed to execute search:  +PATH:"/cm:generalclassifiable/member"
   at org.alfresco.repo.jscript.Search.query(Search.java:686)
   at org.mozilla.javascript.gen.c6._c15(file:/D:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/documentlibrary-v2/doclist.get.js:913)
   at org.mozilla.javascript.gen.c6.call(file:/D:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/documentlibrary-v2/doclist.get.js)
   at org.mozilla.javascript.optimizer.OptRuntime.callName(OptRuntime.java:97)
   at org.mozilla.javascript.gen.c6._c16(file:/D:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/documentlibrary-v2/doclist.get.js:977)
   at org.mozilla.javascript.gen.c6._c0(file:/D:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/documentlibrary-v2/doclist.get.js:1204)
   at org.mozilla.javascript.gen.c6.exec(file:/D:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/documentlibrary-v2/doclist.get.js)
   … 33 more
Caused by: org.alfresco.repo.search.impl.lucene.LuceneQueryParserException: 10260010 Request failed 500 /solr/alfresco/alfresco?wt=json&fl=DBID%2Cscore&rows=2147483647&df=TEXT&start=0&locale=ru_RU&sort=%40cm%3Aname+asc&fq=%7B%21afts%7DAUTHORITY_FILTER_FROM_JSON&fq=%7B%21afts%7DTENANT_FILTER_FROM_JSON
   … 55 more
shazada
Hi, this is another error probably so open a new Topic.
I don't see anything wrong with the indexes. You should post the beginning of the log.
paul_price
I was looking around for metrics on how long a SOLR index rebuild should take. We have ~ 430,000 docs in our repository. It took about 12 hours to rebuild after a version upgrade (4.1.7 -> 4.1.8) What have others experienced? Is there a guide for us to estimate future rebuilds?
Does the SOLR rebuilds improve in 4.2 or should we expect a similar time when we do that upgrade in a few months?
Does the index rebuild take advantage of the all the available CPU cores, or is it single threaded?
Our hardware is quite robust, with 8 cores and 256GB memory, attached to SAN, on RHEL.
heiko_robert
Star Collaborator
Star Collaborator
Hi Paul,
we droped SOLR from most our bigger systems (> 500k docs) since memory was freaking all the time (Community 4.0.x, 4.2.c).
Exactly at the time of writing we're retesting with 4.2.f and 5.0.a and may take this as a good starting point for a public discussion… 😉
Indexing time is not only dependant from number of doc. The main bottlenek is the text extraction and especially libreoffice/openoffice since it doesn't support any kind of multithreading and is not mature as a server component.
To get a better idea of the indexing to do's you should provide doc numbers grouped by document type (–> transformer):
- text based docs like txt, html, xml (scales well)
- pdf (scales well as long the pdfs are well formed and are not encrypted)
- office docs (word scales well since tika is choosen in most cases, other types don't scale because of libreoffice/OO limitations). We recommend real server solutions like FileConverterPro (http://www.pdfa.org/commercial/fileconverter-3/) which scales excellent and increases redering quality
- non indexed types like images, not supported types like indesign etc. (not relevant for indexing)
We'd love to get a fund for implementing a cache service between transformer and SOLR/lucene. blueprint is here. This would speed up an indexing dramatically.
Anyone interested?
