08-07-2008 03:33 AM
# Alfresco init script for Ubuntu
# 2 nov 2007 Joost Horward
export JAVA_HOME="/usr/lib/jvm/java-6-sun"    ## NEU!!
export JRE_HOME="/usr/lib/jvm/java-6-sun"      ## NEU!!
export ALFRESCO_HOME=/opt/alfresco
export CATALINA_BASE=/opt/alfresco/tomcat
export CATALINA_HOME=/opt/alfresco/tomcat
export PIDFILE=/var/run/alfresco
export LOGFILE=/var/log/alfresco/alfresco.log
# Set any default JVM values
export JAVA_OPTS='-Xms128m -Xmx512m -server -Djava.io.tmpdir=/var/lib/alfresco/tmp'
export JAVA_OPTS="${JAVA_OPTS} -Djava.rmi.server.hostname=localhost" ## NEU !!
HTTP Status 404 - /alfresco/
type Status report
message /alfresco/
description The requested resource (/alfresco/) is not available.
Apache Tomcat/5.5.23
		08-07-2008 04:11 AM
root@nxxxx999:/var/log/alfresco/tomcat/logs# cat cat*
07.08.2008 10:05:22 org.apache.coyote.http11.Http11BaseProtocol init
07.08.2008 10:05:22 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 830 ms
07.08.2008 10:05:22 org.apache.catalina.core.StandardService start
07.08.2008 10:05:22 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.23
07.08.2008 10:05:22 org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
07.08.2008 10:05:23 org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive share.war
07.08.2008 10:05:25 org.apache.catalina.startup.HostConfig deployWAR
07.08.2008 10:05:41 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
SCHWERWIEGEND: Context [/alfresco] startup failed due to previous errors
07.08.2008 10:05:43 org.apache.coyote.http11.Http11BaseProtocol start
07.08.2008 10:05:43 org.apache.catalina.storeconfig.StoreLoader load
07.08.2008 10:05:43 org.apache.catalina.startup.Catalina start
INFO: Server startup in 21205 ms
10:05:25,477  INFO  [web.site.FrameworkHelper] Successfully Initialized Web Framework
10:05:37,845  INFO  [config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
10:05:39,255  WARN  [remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
Cannot load JDBC driver class 'org.gjt.mm.mysql.Driver'
java.lang.ClassNotFoundException: org.gjt.mm.mysql.Driver
   at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1359)
   at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1205)
   at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
   at java.lang.Class.forName0(Native Method)
   at java.lang.Class.forName(Class.java:169)
   at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:760)
   at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:540)
   at org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider.getConnection(LocalDataSourceConnectionProvider.java:81)
   at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:76)
   at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2006)
   at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1289)
   at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:804)
   at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:744)
   at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:131)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1118)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1085)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:429)
   at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:250)
   at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:141)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:247)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:161)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:245)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:124)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1019)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:809)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:425)
		08-07-2008 04:58 AM
10:43:21,941  WARN  [remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
10:43:26,521  ERROR [transform.swf.PDFToSWFContentTransformer] Failed to start SWF2PDF transformer:
Execution result:
   os:         Linux
   command:    pdf2swf -V
   succeeded:  false
   exit code:  1
   out:
   err:        Cannot run program "pdf2swf": java.io.IOException: error=2, No such file or directory
10:43:28,093  INFO  [domain.schema.SchemaBootstrap] Executing database script /opt/alfresco/tomcat/temp/Alfresco/AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-59782.sql (Copied from classpath:alfresco/dbscripts/upgrade/1.4/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoSchemaUpdate-1.4-1.sql).
10:43:28,111  ERROR [domain.schema.SchemaBootstrap] Statement execution failed:
   SQL:  ALTER TABLE applied_patch        ENGINE = InnoDB
   Error: Table 'alfresco.applied_patch' doesn't exist
   File: /opt/alfresco/tomcat/temp/Alfresco/AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-59782.sql
   Line: 31
10:43:28,113  ERROR [domain.schema.SchemaBootstrap] Schema auto-update failed
08-29-2008 08:53 AM
rm -r /var/lib/alfresco/alf_data/*3.) Die alfresco-Datenbank gelöscht und neu erstellt habe mit:mysql -u root -pdrop database alfresco;create database alfresco;grant all privileges on alfresco.* to alfresco@localhost identified by 'alfresco';4.) Alfresco Server neu gestartet habe
