09-16-2012 05:41 PM
document.delete(true);cmisSession.query(queryString, false);11-19-2012 09:55 AM
2012-11-19 15:32:38,623 ERROR [freemarker.runtime] [http-8080-4] Template processing error: "get(properties) failed on instance of org.alfresco.repo.template.TemplateNode"
The problematic instruction:
==> ${node.properties.creator!""} [on line 206, column 15 in org/alfresco/cmis/lib/atomentry.lib.atom.ftl]
in user-directive entry [on line 202, column 1 in org/alfresco/cmis/lib/atomentry.lib.atom.ftl]
in user-directive entryLib.row [on line 23, column 1 in org/alfresco/cmis/queries.post.atomfeed.ftl]
Java backtrace for programmers:
freemarker.template.TemplateModelException: get(properties) failed on instance of org.alfresco.repo.template.TemplateNode
at freemarker.ext.beans.BeanModel.get(BeanModel.java:224)
at freemarker.core.Dot._getAsTemplateModel(Dot.java:76)
at freemarker.core.Expression.getAsTemplateModel(Expression.java:89)
at freemarker.core.Dot._getAsTemplateModel(Dot.java:74)
at freemarker.core.DefaultToExpression._getAsTemplateModel(DefaultToExpression.java:100)
at freemarker.core.Expression.getStringValue(Expression.java:93)
at freemarker.core.DollarVariable.accept(DollarVariable.java:76)
at freemarker.core.Environment.visit(Environment.java:221)
at freemarker.core.MixedContent.accept(MixedContent.java:92)
at freemarker.core.IfBlock.accept(IfBlock.java:82)
at freemarker.core.Environment.visit(Environment.java:406)
at freemarker.core.BodyInstruction.accept(BodyInstruction.java:93)
at freemarker.core.Macro$Context.runMacro(Macro.java:172)
at freemarker.core.Environment.visit(Environment.java:614)
at freemarker.core.UnifiedCall.accept(UnifiedCall.java:106)
at freemarker.core.IteratorBlock$Context.runLoop(IteratorBlock.java:167)
at freemarker.core.Environment.visit(Environment.java:428)
at freemarker.core.IteratorBlock.accept(IteratorBlock.java:102)
at freemarker.core.Environment.visit(Environment.java:310)
at freemarker.core.CompressedBlock.accept(CompressedBlock.java:73)
at freemarker.core.Environment.process(Environment.java:199)
at org.alfresco.repo.template.FreeMarkerProcessor.process(FreeMarkerProcessor.java:202)
at org.springframework.extensions.webscripts.AbstractWebScript.renderTemplate(AbstractWebScript.java:879)
at org.springframework.extensions.webscripts.DeclarativeWebScript.renderFormatTemplate(DeclarativeWebScript.java:267)
at org.springframework.extensions.webscripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:147)
at org.alfresco.repo.web.scripts.RepositoryContainer$2.execute(RepositoryContainer.java:410)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:388)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecute(RepositoryContainer.java:479)
at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecuteAs(RepositoryContainer.java:517)
at org.alfresco.repo.web.scripts.RepositoryContainer.executeScript(RepositoryContainer.java:333)
at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:377)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:470)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:877)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:594)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1675)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor692.invoke(Unknown Source)
at freemarker.ext.beans.BeansWrapper.invokeMethod(BeansWrapper.java:870)
at freemarker.ext.beans.BeanModel.invokeThroughDescriptor(BeanModel.java:277)
at freemarker.ext.beans.BeanModel.get(BeanModel.java:184)
… 69 more
Caused by: org.alfresco.service.cmr.repository.InvalidNodeRefException: Node does not exist: workspace://SpacesStore/1192c6b2-bcf4-453e-86f5-b8793fce396f(Status[changeTxnId=f0528cc7-0fe2-4b57-a0bb-e2e224712ec2, dbTxnId=2111, deleted=true])
at org.alfresco.repo.node.db.DbNodeServiceImpl.getNodePairNotNull(DbNodeServiceImpl.java:177)
at org.alfresco.repo.node.db.DbNodeServiceImpl.hasAspect(DbNodeServiceImpl.java:996)
at sun.reflect.GeneratedMethodAccessor232.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
at org.alfresco.repo.tenant.MultiTNodeServiceInterceptor.invoke(MultiTNodeServiceInterceptor.java:105)
at $Proxy15.hasAspect(Unknown Source)
at org.alfresco.repo.service.StoreRedirectorProxyFactory$RedirectorInvocationHandler.invoke(StoreRedirectorProxyFactory.java:215)
at $Proxy16.hasAspect(Unknown Source)
at org.alfresco.repo.node.MLPropertyInterceptor.getPivotNodeRef(MLPropertyInterceptor.java:323)
at org.alfresco.repo.node.MLPropertyInterceptor.invoke(MLPropertyInterceptor.java:173)
at org.alfresco.enterprise.repo.sync.SyncPropertyInterceptor.invoke(SyncPropertyInterceptor.java:157)
at org.alfresco.repo.node.NodeRefPropertyMethodInterceptor.invoke(NodeRefPropertyMethodInterceptor.java:212)
at $Proxy15.getProperties(Unknown Source)
at sun.reflect.GeneratedMethodAccessor301.invoke(Unknown Source)
at org.alfresco.repo.audit.DisableAuditableBehaviourInterceptor.invoke(DisableAuditableBehaviourInterceptor.java:113)
at org.alfresco.repo.transaction.RetryingTransactionInterceptor$1.execute(RetryingTransactionInterceptor.java:69)
at org.alfresco.repo.transaction.RetryingTransactionInterceptor.invoke(RetryingTransactionInterceptor.java:59)
at org.alfresco.repo.template.TemplateNode.getProperties(TemplateNode.java:263)
… 75 more
2012-11-19 15:32:38,631 ERROR [extensions.webscripts.AbstractRuntime] [http-8080-4] Exception from executeScript - redirecting to status template error: 10190003 Wrapped Exception (with status template): 10193430 Error during processing of the template 'get(properties) failed on instance of org.alfresco.repo.template.TemplateNode'. Please contact your system administrator.
org.springframework.extensions.webscripts.WebScriptException: 10190003 Wrapped Exception (with status template): 10193430 Error during processing of the template 'get(properties) failed on instance of org.alfresco.repo.template.TemplateNode'. Please contact your system administrator.
at org.springframework.extensions.webscripts.AbstractWebScript.createStatusException(AbstractWebScript.java:1050)
Caused by: org.alfresco.service.cmr.repository.TemplateException: 10193430 Error during processing of the template 'get(properties) failed on instance of org.alfresco.repo.template.TemplateNode'. Please contact your system administrator.
at org.alfresco.repo.template.FreeMarkerProcessor.process(FreeMarkerProcessor.java:206)
… 25 more
Caused by: freemarker.template.TemplateModelException: get(properties) failed on instance of org.alfresco.repo.template.TemplateNode
… 28 more
… 69 more
… 75 more
