some problems with tomcat, alfresco and mysql
greg
I usually use postgres and I wonder if there is a host file I need to update to allow localhost access to mysql?
I get the following errors in tomcat:
http://localhost:8080/alfresco/
HTTP Status 404 - /alfresco/
type Status report
message /alfresco/
description The requested resource (/alfresco/) is not available.
Apache Tomcat/5.5.9
http://localhost:8080/manager/status
HTTP Status 403 - Access to the requested resource has been denied
type Status report
message Access to the requested resource has been denied
description Access to the specified resource (Access to the requested
resource has been denied) has been forbidden.
Apache Tomcat/5.5.9
some of my system info and a fuller tomcat catalina.out is at the bottom of the post:
java related command line:
$ sudo update-alternatives –config
java
Password:
There is only 1 program which provides java
(/usr/lib/j2sdk1.5-sun/bin/java). Nothing to configure.
greg@mystech:/opt/alfresco/tomcat/logs$ /usr/lib/j2sdk1.5-sun/bin/java
-version
java version "1.5.0_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
Java HotSpot(TM) Client VM (build 1.5.0_06-b05, mixed mode, sharing)
mysql related info
$ mysql -u alfresco -p
Enter password:
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 8 to server version: 4.1.12-Debian_1ubuntu3-log
Type 'help;' or '\h' for help. Type '\c' to clear the buffer.
mysql> use alfresco
Database changed
mysql> show tables
Empty set (0.00 sec)
mysql>
tomcat catalina.out file error:
   at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:409)
Caused by: org.apache.commons.dbcp.SQLNestedException: Cannot create
PoolableConnectionFactory (null,  message from server: "#HY000Host
'localhost.localdomain' is not allowed to connect to this MySQL server")
        at
org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:855)
        at
org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:540)
        at
org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider.getConnection(LocalDataSourceConnectionProvider.java:79)
        at
org.hibernate.jdbc.ConnectionManager.openConnection(ConnectionManager.java:303)
        … 59 more
Caused by: java.sql.SQLException: null,  message from server: "#HY000Host
the tomcat catalina.out:
12:26:19,220 ERROR [[Catalina].[localhost].[/alfresco]] Exception sending
context initialized event to listener instance of class
org.alfresco.web.app.ContextListener
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'descriptorComponent' defined in class path resource
[alfresco/application-context.xml]: Can't resolve reference to bean
'systemBootstrap' while setting property 'systemBootstrap'; nested exception
is org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'systemBootstrap' defined in class path resource
[alfresco/application-context.xml]: Initialization of bean failed; nested
exception is
org.springframework.transaction.CannotCreateTransactionException: Could not
open Hibernate session for transaction; nested exception is
org.hibernate.exception.GenericJDBCException: Cannot open connection
exception is
        at
org.hibernate.exception.ErrorCodeConverter.handledNonSpecificException(ErrorCodeConverter.java:92)
        at
org.hibernate.exception.ErrorCodeConverter.convert(ErrorCodeConverter.java:80)
        at
org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:43)
        at
org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:29)
        at
org.hibernate.jdbc.ConnectionManager.openConnection(ConnectionManager.java:306)
        at
org.hibernate.jdbc.ConnectionManager.getConnection(ConnectionManager.java:114)
        at org.hibernate.jdbc.JDBCContext.connection(JDBCContext.java:117)
        at org.hibernate.impl.SessionImpl.connection(SessionImpl.java:365)
        at
org.springframework.orm.hibernate3.HibernateTransactionManager.doBegin(HibernateTransactionManager.java:405)
        at
org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:289)
        at
org.springframework.transaction.interceptor.TransactionAspectSupport.createTransactionIfNecessary(TransactionAspectSupport.java:219)
        at
org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:50)
        at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
        at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
        at $Proxy15.getSystemUserName(Unknown Source)
        at
org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:266)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:971)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:941)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:334)
        at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:222)
        at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:146)
        at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:176)
        at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:105)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:891)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:707)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:316)
        at
        at
        at
org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:205)
        at
org.springframework.context.support.AbstractApplicationContext.getBeansOfType(AbstractApplicationContext.java:583)
        at
org.springframework.context.support.AbstractApplicationContext.registerListeners(AbstractApplicationContext.java:466)
        at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:307)
        at
org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:133)
        at
org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
        at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
        at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
        at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3669)
        at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4104)
        at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:759)
        at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:739)
        at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:524)
        at
org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:788)
        at
org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:677)
        at
org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:473)
        at
org.apache.catalina.startup.HostConfig.start(HostConfig.java:1102)
        at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
        at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
        at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1020)
        at
org.apache.catalina.core.StandardHost.start(StandardHost.java:718)
        at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1012)
        at
org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442)
        at
org.apache.catalina.core.StandardService.start(StandardService.java:450)
        at
org.apache.catalina.core.StandardServer.start(StandardServer.java:683)
        at org.apache.catalina.startup.Catalina.start(Catalina.java:537)
        at
        at
        at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:271)
PoolableConnectionFactory (null,  message from server: "Host
        at
        at
        at
        at
        … 59 more
Caused by: java.sql.SQLException: null,  message from server: "Host
        at com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:990)
        at com.mysql.jdbc.Connection.createNewIO(Connection.java:2544)
        at com.mysql.jdbc.Connection.<init>(Connection.java:1474)
        at
com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:264)
        at
org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:37)
        at
org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:290)
        at
org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:877)
        at
org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:851)
        … 62 more
30-Dec-2005 12:26:19 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
12:26:19,253 ERROR [[Catalina].[localhost].[/alfresco]] Exception sending
context destroyed event to listener instance of class
exception is
exception is
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        … 59 more
        at
        at
        at
        at
        at
        … 62 more
30-Dec-2005 12:26:20 PM org.apache.coyote.http11.Http11Protocol start
SEVERE: Error starting endpoint
java.net.BindException: Address already in use:8080
        at
org.apache.tomcat.util.net.PoolTcpEndpoint.initEndpoint(PoolTcpEndpoint.java:297)
        at
org.apache.tomcat.util.net.PoolTcpEndpoint.startEndpoint(PoolTcpEndpoint.java:312)
        at
org.apache.coyote.http11.Http11Protocol.start(Http11Protocol.java:182)
        at
org.apache.catalina.connector.Connector.start(Connector.java:1001)
        at
org.apache.catalina.core.StandardService.start(StandardService.java:459)
        at
        at
        at
30-Dec-2005 12:26:20 PM org.apache.catalina.startup.Catalina start
SEVERE: Catalina.start:
LifecycleException:  Protocol handler start failed: java.net.BindException:
        at
org.apache.catalina.connector.Connector.start(Connector.java:1003)
        at
        at
        at
        at
INFO: Server startup in 44142 ms
30-Dec-2005 12:26:20 PM org.apache.catalina.core.StandardServer await
SEVERE: StandardServer.await: create[8005]:
        at java.net.PlainSocketImpl.socketBind(Native Method)
        at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:359)
        at java.net.ServerSocket.bind(ServerSocket.java:319)
        at java.net.ServerSocket.<init>(ServerSocket.java:185)
        at
org.apache.catalina.core.StandardServer.await(StandardServer.java:346)
        at org.apache.catalina.startup.Catalina.await(Catalina.java:600)
        at org.apache.catalina.startup.Catalina.start(Catalina.java:560)
        at
        at
30-Dec-2005 12:26:20 PM org.apache.coyote.http11.Http11Protocol pause
INFO: Pausing Coyote HTTP/1.1 on http-8080
30-Dec-2005 12:26:20 PM org.apache.catalina.connector.Connector pause
SEVERE: Protocol handler pause failed
        at org.apache.jk.server.JkMain.pause(JkMain.java:675)
        at
org.apache.jk.server.JkCoyoteHandler.pause(JkCoyoteHandler.java:209)
        at org.apache.catalina.connector.Connector.pause(Connector.java:943)
        at
org.apache.catalina.core.StandardService.stop(StandardService.java:491)
        at
org.apache.catalina.core.StandardServer.stop(StandardServer.java:717)
        at org.apache.catalina.startup.Catalina.stop(Catalina.java:586)
        at
org.apache.catalina.startup.Catalina$CatalinaShutdownHook.run(Catalina.java:629)
30-Dec-2005 12:26:21 PM org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
30-Dec-2005 12:26:21 PM org.apache.catalina.connector.MapperListener destroy
WARNING: Error unregistering MBeanServerDelegate
        at
org.apache.catalina.connector.MapperListener.destroy(MapperListener.java:161)
        at org.apache.catalina.connector.Connector.stop(Connector.java:1044)
        at
org.apache.catalina.core.StandardService.stop(StandardService.java:521)
        at
        at
30-Dec-2005 12:26:21 PM org.apache.coyote.http11.Http11Protocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-8080
30-Dec-2005 12:26:21 PM org.apache.catalina.connector.Connector stop
SEVERE: Coyote connector has not been started
30-Dec-2005 12:28:50 PM org.apache.coyote.http11.Http11Protocol init
SEVERE: Error initializing endpoint
        at
        at
org.apache.coyote.http11.Http11Protocol.init(Http11Protocol.java:142)
        at
org.apache.catalina.connector.Connector.initialize(Connector.java:928)
        at
org.apache.catalina.core.StandardService.initialize(StandardService.java:580)
        at
org.apache.catalina.core.StandardServer.initialize(StandardServer.java:764)
        at org.apache.catalina.startup.Catalina.load(Catalina.java:490)
        at org.apache.catalina.startup.Catalina.load(Catalina.java:509)
        at
        at
        at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:243)
        at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:408)
30-Dec-2005 12:28:50 PM org.apache.catalina.startup.Catalina load
LifecycleException:  Protocol handler initialization failed:
        at
org.apache.catalina.connector.Connector.initialize(Connector.java:930)
        at
        at
        at
        at
INFO: Initialization processed in 3720 ms
30-Dec-2005 12:28:51 PM org.apache.catalina.core.StandardService start
30-Dec-2005 12:28:51 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.9
30-Dec-2005 12:28:51 PM org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
30-Dec-2005 12:28:53 PM org.apache.catalina.startup.HostConfig deployWAR
<!– end file –>
16 REPLIES 16
greg
Are you sure that the Tomcat server has access to the database
How do I tell if it does? Is there a special user in tomcat that I need to add to the mysql user tables?
that the database tables are InnoDB and that the default character set is utf8?
Yes the mysql tables are Innodb and utf8
Is the Tomcat install using the correct JDBC driver (mysql-connector-java-3.1.10-bin.jar)?
There is a library file /opt/alfresco/common/lib/mysql-connector-java-3.1.10-bin.jar but if it is being used by Tomcat I do not know. Where is this set, in the tomcat server.xml?  There are some JDBC drivers set in server.xml but they are not correct (and they are also commented out).
derek
If the tables are being created as INNODB and UTF-8, then that side is fine.
I noticed this in the traces:
If there are multiple Alfresco servers running against the same database, then the duplicate key exception could readily be expected.  It looks almost as if there are two web-apps attempting to start in the same server.
Regards
greg
The address in use was probably a result of my troubleshooting (I tried starting it as root versus sudo'in from my user account) and ended up with multiple copies running. I've created a proper rc.d package that now boots tomcat and alfresco at start up. The initial error I receive now is as follows, it does sound like it is having trouble connecting to the database:
Jan 26, 2006 9:43:03 PM net.sf.joott.uno.UnoConnection connect
SEVERE: connection failed: com.sun.star.connection.NoConnectException:
java.net.ConnectException: Connection refused
21:43:04,696 ERROR [transform.magick.AbstractImageMagickContentTransformer]
ImageMagickContentTransformer not available: Failed to execute command:
imconvert
/opt/alfresco/tomcat/temp/Alfresco/ImageMagickContentTransformer_init_source_55205.gif
/opt/alfresco/tomcat/temp/Alfresco/ImageMagickContentTransformer_init_target_55206.png
21:43:12,992 ERROR [hibernate.util.JDBCExceptionReporter] Incorrect
arguments to mysql_stmt_execute
21:43:13,013 ERROR [event.def.AbstractFlushingEventListener] Could not
synchronize database state with session
org.hibernate.exception.GenericJDBCException: Could not execute JDBC batch
derek
Could you send me the rest of the trace, please?
Regards
greg
here you go:
Jan 26, 2006 9:41:55 PM org.apache.coyote.http11.Http11Protocol init
Jan 26, 2006 9:41:55 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 6378 ms
Jan 26, 2006 9:41:56 PM org.apache.catalina.core.StandardService start
Jan 26, 2006 9:41:56 PM org.apache.catalina.core.StandardEngine start
Jan 26, 2006 9:41:56 PM org.apache.catalina.core.StandardHost start
Jan 26, 2006 9:42:01 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: connecting using "socket,host=localhost,port=8100,tcpNoDelay=1"…
SEVERE: connection failed: com.sun.star.connection.NoConnectException: java.net.ConnectException: Connection refused
21:43:04,696 ERROR [transform.magick.AbstractImageMagickContentTransformer] ImageMagickContentTransformer not available: Failed to execute command: imconvert /opt/alfresco/tomcat/temp/Alfresco/ImageMagickContentTransformer_init_source_55205.gif  /opt/alfresco/tomcat/temp/Alfresco/ImageMagickContentTransformer_init_target_55206.png
21:43:12,992 ERROR [hibernate.util.JDBCExceptionReporter] Incorrect arguments to mysql_stmt_execute
21:43:13,013 ERROR [event.def.AbstractFlushingEventListener] Could not synchronize database state with session
org.hibernate.exception.GenericJDBCException: Could not execute JDBC batch update
   at org.hibernate.exception.ErrorCodeConverter.handledNonSpecificException(ErrorCodeConverter.java:92)
   at org.hibernate.exception.ErrorCodeConverter.convert(ErrorCodeConverter.java:80)
   at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:43)
   at org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatcher.java:200)
   at org.hibernate.jdbc.AbstractBatcher.prepareStatement(AbstractBatcher.java:91)
   at org.hibernate.jdbc.AbstractBatcher.prepareStatement(AbstractBatcher.java:86)
   at org.hibernate.jdbc.AbstractBatcher.prepareBatchStatement(AbstractBatcher.java:169)
   at org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:2033)
   at org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:2410)
   at org.hibernate.action.EntityInsertAction.execute(EntityInsertAction.java:51)
   at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:243)
   at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:227)
   at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:140)
   at org.hibernate.event.def.AbstractFlushingEventListener.performExecutions(AbstractFlushingEventListener.java:296)
   at org.hibernate.event.def.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:27)
   at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:870)
   at org.hibernate.impl.SessionImpl.managedFlush(SessionImpl.java:344)
   at org.hibernate.transaction.JDBCTransaction.commit(JDBCTransaction.java:106)
   at org.springframework.orm.hibernate3.HibernateTransactionManager.doCommit(HibernateTransactionManager.java:488)
   at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:401)
   at org.springframework.transaction.interceptor.TransactionAspectSupport.doCommitTransactionAfterReturning(TransactionAspectSupport.java:260)
   at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:376)
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:337)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:971)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:941)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:334)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:222)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:146)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:176)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:105)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:891)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:707)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:316)
   at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:205)
   at org.springframework.context.support.AbstractApplicationContext.getBeansOfType(AbstractApplicationContext.java:583)
   at org.springframework.context.support.AbstractApplicationContext.registerListeners(AbstractApplicationContext.java:466)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:307)
   at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:133)
   at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
   at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
   at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
   at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3669)
   at org.apache.catalina.core.StandardContext.start(StandardContext.java:4104)
   at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:788)
   at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:677)
   at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:473)
   at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1102)
   at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1020)
   at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1012)
   at org.apache.catalina.core.StandardServer.start(StandardServer.java:683)
Caused by: java.sql.BatchUpdateException: Incorrect arguments to mysql_stmt_execute
   at com.mysql.jdbc.ServerPreparedStatement.executeBatch(ServerPreparedStatement.java:642)
   at org.apache.commons.dbcp.DelegatingStatement.executeBatch(DelegatingStatement.java:294)
   at org.hibernate.jdbc.BatchingBatcher.doExecuteBatch(BatchingBatcher.java:58)
   at org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatcher.java:193)
   … 67 more
21:43:13,093 ERROR [web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'descriptorComponent' defined in class path resource [alfresco/application-context.xml]: Can't resolve reference to bean 'systemBootstrap' while setting property 'systemBootstrap'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'systemBootstrap' defined in class path resource [alfresco/application-context.xml]: Initialization of bean failed; nested exception is org.alfresco.error.AlfrescoRuntimeException: Bootstrap failed
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:345)
Caused by: org.springframework.jdbc.UncategorizedSQLException: (HibernateTransactionManager): encountered SQLException [Incorrect arguments to mysql_stmt_execute]; nested exception is java.sql.BatchUpdateException: Incorrect arguments to mysql_stmt_execute
   at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.translate(SQLStateSQLExceptionTranslator.java:99)
   at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.translate(SQLErrorCodeSQLExceptionTranslator.java:257)
   at org.springframework.orm.hibernate3.HibernateTransactionManager.convertJdbcAccessException(HibernateTransactionManager.java:600)
   at org.springframework.orm.hibernate3.HibernateTransactionManager.doCommit(HibernateTransactionManager.java:496)
   … 48 more
   … 52 more
21:43:13,145 ERROR [[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
   … 48 more
   … 52 more
21:43:13,159 ERROR [[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
   … 48 more
   … 52 more
Jan 26, 2006 9:43:13 PM org.apache.catalina.core.StandardContext start
21:43:13,181 ERROR [[Catalina].[localhost].[/alfresco]] Exception sending context destroyed event to listener instance of class org.alfresco.web.app.ContextListener
   … 48 more
   … 52 more
Jan 26, 2006 9:43:13 PM org.apache.coyote.http11.Http11Protocol start
Jan 26, 2006 9:43:14 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Jan 26, 2006 9:43:14 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/114  config=null
Jan 26, 2006 9:43:14 PM org.apache.catalina.storeconfig.StoreLoader load
Jan 26, 2006 9:43:14 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 79477 ms
Jan 26, 2006 9:49:48 PM org.apache.coyote.http11.Http11Protocol pause
Jan 26, 2006 9:49:49 PM org.apache.catalina.core.StandardService stop
Jan 26, 2006 9:49:49 PM org.apache.coyote.http11.Http11Protocol destroy
Jan 28, 2006 8:19:49 PM org.apache.coyote.http11.Http11Protocol init
Jan 28, 2006 8:19:49 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 4860 ms
Jan 28, 2006 8:19:50 PM org.apache.catalina.core.StandardService start
Jan 28, 2006 8:19:50 PM org.apache.catalina.core.StandardEngine start
Jan 28, 2006 8:19:50 PM org.apache.catalina.core.StandardHost start
Jan 28, 2006 8:19:53 PM org.apache.catalina.startup.HostConfig deployWAR
Jan 28, 2006 8:20:30 PM net.sf.joott.uno.UnoConnection connect
Jan 28, 2006 8:20:31 PM net.sf.joott.uno.UnoConnection connect
20:20:31,568 ERROR [transform.magick.AbstractImageMagickContentTransformer] ImageMagickContentTransformer not available: Failed to execute command: imconvert /opt/alfresco/tomcat/temp/Alfresco/ImageMagickContentTransformer_init_source_46037.gif  /opt/alfresco/tomcat/temp/Alfresco/ImageMagickContentTransformer_init_target_46038.png
20:20:39,062 ERROR [hibernate.util.JDBCExceptionReporter] Incorrect arguments to mysql_stmt_execute
20:20:39,083 ERROR [event.def.AbstractFlushingEventListener] Could not synchronize database state with session
   … 67 more
20:20:39,187 ERROR [web.context.ContextLoader] Context initialization failed
   … 48 more
   … 52 more
20:20:39,205 ERROR [[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
derek
Which MySQL driver are you using?
Have you tried doing everything from scratch again?
Regards
greg
I finally got it working. I believe the problem was I was using the mysql package installed by synaptic on Ubuntu. Once I downloaded and installed the max version of mysql manually it worked like a charm.
thanks for your help!
