[solved]problem while installing and restarting alfresco
ahmetuslu
Hi, I'm new in alfresco and I have some problems during the installations. I need help !!!
I'm using 2.9B version on Windows Server 2003 64bit edition with mysql 64bit edition.
My SQL part is ok, I have two problems as listed below.
— While starting Alfresco, it gives an error message about WinsockNetBIOSException, but it Alfresco works. After some investigation I learned that it is about CIFS access. But my users will use alfresco from web, is there any way to close this error or is it a problem ?
org.alfresco.filesys.netbios.win32.WinsockNetBIOSException: 10047:CreateDatagramSocket - Address family not supported by protocol family
   at org.alfresco.filesys.netbios.win32.Win32NetBIOS.CreateDatagramSocket(Native Method)
   at org.alfresco.filesys.netbios.win32.NetBIOSSocket.createDatagramSocket(NetBIOSSocket.java:162)
   at org.alfresco.filesys.smb.mailslot.WinsockNetBIOSHostAnnouncer.initialize(WinsockNetBIOSHostAnnouncer.java:103)
   at org.alfresco.filesys.smb.mailslot.HostAnnouncer.run(HostAnnouncer.java:270)
— My second problem is, after I installed and started alfresco firs time it works. But when I stop by using "alf_stop.bat" I can not start Alfresco again until I remove and setup the database files again by using "db_remove.bat" and "db_setup.bat". It gives
ERROR [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema auto-update failed
com.mysql.jdbc.exceptions.MySQLSyntaxErrorException: Table 'jbpm_action' already exists
   at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:936)
   at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2870)
   at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1573) ….
because alfresco tries to create database schemas for every start, it can not see the existing schemas from previous starts. So If I remove db and setup db again, all the users and content from previous start is deleted. Is there any way to not execute AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect.sql scripts while restarting Alfresco.
I'm in trouble with these errors and any help will be a sunlight for me Smiley Happy
-thanks in advance.
ahmetuslu
My full log file is below. Alfresco gives this for second start. For first start it only gives first error(org.alfresco.filesys.netbios.win32.WinsockNetBIOSException: 10047:CreateDatagramSocket - Address family not supported by protocol family) but it works..
Thanks for your reply.
10:36:34,375 ERROR [org.alfresco.repo.content.transform.magick.AbstractImageMagickContentTransformer] ImageMagickContentTransformer not available: Failed to perform ImageMagick transformation:
Execution result:
   os:         Windows 2003
   command:    imconvert "Z:\Alfresco\tomcat\temp\Alfresco\ImageMagickContentTransformer_init_source_1978.gif"  "Z:\Alfresco\tomcat\temp\Alfresco\ImageMagickContentTransformer_init_target_1979.png"
   succeeded:  false
   exit code:  1
   out:
   err:        imconvert: Not enough pixel data `Z:\Alfresco\tomcat\temp\Alfresco\ImageMagickContentTransformer_init_source_1978.gif'.
imconvert: missing an image filename `Z:\Alfresco\tomcat\temp\Alfresco\ImageMagickContentTransformer_init_target_1979.png'.
10:36:37,562 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
10:36:41,609 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
10:36:41,718 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script Z:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaCreate-org.hibernate.dialect.MySQLInnoDBDialect-1980.sql (Generated).
10:37:02,859 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script Z:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-1981.sql (Copied from classpath:alfresco/dbscripts/create/2.1/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoPostCreate-2.1-FKIndexes.sql).
10:37:03,015 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script Z:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-1982.sql (Copied from classpath:alfresco/dbscripts/create/1.4/org.hibernate.dialect.MySQLInnoDBDialect/post-create-indexes-02.sql).
10:37:03,312 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] All executed statements written to file Z:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-All_Statements-1983.sql.
10:37:47,937 ERROR [org.alfresco.util.exec.RuntimeExecBootstrapBean] Bootstrap command failed:
Execution result:
   os:         Windows 2003
   command:    "Z:/Alfresco/openoffice/program/soffice" "-accept=socket,host=localhost,port=8100;urp;StarOffice.ServiceManager" "-env:UserInstallation=file:///Z:/Alfresco/oouser" -nologo -headless -nofirststartwizard -nocrashrep -norestore
   succeeded:  false
   exit code:  2
   out:
   err:        Cannot run program ""Z:/Alfresco/openoffice/program/soffice"": CreateProcess error=3, The system cannot find the path specified
10:37:48,218 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: Z:\Alfresco\alf_data
10:37:48,234 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Uygulanacak yamalar kontrol ediliyor …
10:37:49,515 INFO  [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
10:37:49,859 ERROR [org.alfresco.smb.protocol.mailslot] HostAnnouncer initialization error
10:37:51,046 WARN  [org.alfresco.util.OpenOfficeConnectionTester] A connection to OpenOffice could not be established.
10:37:51,046 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_01-b06; maximum heap size 493,063MB
10:37:51,046 WARN  [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493,063MB is less than recommended 512MB
10:37:51,046 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.9.0 (B 683) schema 116 - Installed version 2.9.0 (B 683) schema 116
13:51:46,796 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
13:51:51,156 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
13:51:51,593 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script Z:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-21895.sql (Generated).
13:51:51,609 ERROR [org.alfresco.repo.domain.schema.SchemaBootstrap] Statement execution failed:
   SQL:  create table JBPM_ACTION (ID_ bigint not null auto_increment, class char(1) not null, NAME_ varchar(255), ISPROPAGATIONALLOWED_ bit, ACTIONEXPRESSION_ varchar(255), ISASYNC_ bit, REFERENCEDACTION_ bigint, ACTIONDELEGATION_ bigint, EVENT_ bigint, PROCESSDEFINITION_ bigint, TIMERNAME_ varchar(255), DUEDATE_ varchar(255), REPEAT_ varchar(255), TRANSITIONNAME_ varchar(255), TIMERACTION_ bigint, EXPRESSION_ text, EVENTINDEX_ integer, EXCEPTIONHANDLER_ bigint, EXCEPTIONHANDLERINDEX_ integer, primary key (ID_)) type=InnoDB
   Error: Table 'jbpm_action' already exists
   File: Z:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-21895.sql
   Line: 1
13:51:51,609 ERROR [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema auto-update failed
   at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1665)
   at com.mysql.jdbc.Connection.execSQL(Connection.java:3118)
   at com.mysql.jdbc.Connection.execSQL(Connection.java:3047)
   at com.mysql.jdbc.Statement.execute(Statement.java:692)
   at org.apache.commons.dbcp.DelegatingStatement.execute(DelegatingStatement.java:261)
   at org.alfresco.repo.domain.schema.SchemaBootstrap.executeStatement(SchemaBootstrap.java:700)
   at org.alfresco.repo.domain.schema.SchemaBootstrap.executeScriptFile(SchemaBootstrap.java:675)
   at org.alfresco.repo.domain.schema.SchemaBootstrap.updateSchema(SchemaBootstrap.java:485)
   at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:767)
13:51:51,625 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Schema auto-update failed
   at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:815)
Caused by: com.mysql.jdbc.exceptions.MySQLSyntaxErrorException: Table 'jbpm_action' already exists
   … 34 more
13:51:51,625 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
   … 34 more
13:51:51,640 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
   … 34 more
ahmetuslu
hello belmekki,
Thanks a lot. It solved my second problem. It was comment line so I thought that it is disabled, I didn't noticed. Thanks again.
although my first error message(org.alfresco.filesys.netbios.win32.WinsockNetBIOSException: 10047:CreateDatagramSocket - Address family not supported by protocol family) alfresco works from web. If the error does not cause any problem while using from Web, it is enough for me. Do u think error message causes any problem ?
Good days…
ahmetuslu
I disable the CIFS server form "..\Alfresco\tomcat\webapps\alfresco\WEB-INF\classes\alfresco\file-servers.xml" and error gone now. I changed the JVM max heap size and everything looks fine now.
Thanks for your replies.
Regards..
