Simplest case of LDAP authentication doesn't work.. pls help
geoffrey1211
What I want to do is to login on the alfresco login page using ONLY the active directory credentials (I am using Active Directory Server).    How can I do this?   I keep getting this error:
16:27:37,865  WARN  [authentication.ldap.LDAPInitialDirContextFactoryImpl] LDAP server supports anonymous bind ldap://delljoeb:10389
16:27:37,896  INFO  [authentication.ldap.LDAPInitialDirContextFactoryImpl] LDAP server does not support simple string user ids and invalid credentials at ldap://delljoeb:10389
16:27:37,912  INFO  [authentication.ldap.LDAPInitialDirContextFactoryImpl] LDAP server does not fall back to anonymous bind for a simple dn and password at ldap://delljoeb:10389
16:27:37,928  INFO  [authentication.ldap.LDAPInitialDirContextFactoryImpl] LDAP server does not fall back to anonymous bind for known principal and invalid credentials at ldap://delljoeb:10389
Here are my configuration files:
ldap.authentication.userNameFormat=cn=%s,ou=users,ou=system
# The LDAP context factory to use
# The URL to connect to the LDAP server
ldap.authentication.java.naming.provider.url=ldap://delljoeb:10389
# The authentication mechanism to use
# The default principal to use (only used for LDAP sync)
ldap.authentication.java.naming.security.principal=cn=admin,ou=users,ou=system
# The password for the default principal (only used for LDAP sync)
ldap.authentication.java.naming.security.credentials=secret
My XML too just in case:
<beans>
   <!– The main configuration has moved into a properties file –>
    <bean name="ldapAuthenticationPlaceholderConfigurer" class="org.springframework.beans.factory.config.PropertyPlaceholderConfigurer">
        <property name="ignoreUnresolvablePlaceholders">
            <value>true</value>
        </property>
        <property name="locations">
            <value>classpath:alfresco/extension/ldap-authentication.properties</value>
        </property>
    </bean>
    <!– DAO that rejects changes - LDAP is read only at the moment. It does allow users to be deleted with out warnings from the UI. –>
    <bean name="authenticationDaoLDAP" class="org.alfresco.repo.security.authentication.DefaultMutableAuthenticationDao" >
        <property name="allowDeleteUser">
            <value>true</value>
        </property>
    </bean>
    <!– LDAP authentication configuration –>
    You can also use JAAS authentication for Kerberos against Active Directory or NTLM if you also require single sign on from the
    web browser. You do not have to use LDAP authentication to synchronise groups and users from an LDAP store if it supports other
    authentication routes, like Active Directory.
    <bean id="authenticationComponentLDAP"
          class="org.alfresco.repo.security.authentication.ldap.LDAPAuthenticationComponentImpl"
          parent="authenticationComponentBase">
        <property name="LDAPInitialDirContextFactory">
            <ref bean="ldapInitialDirContextFactory"/>
        </property>
        <property name="userNameFormat">
            This maps between what the user types in and what is passed through to the underlying LDAP authentication.
            "%s" - the user id is passed through without modification.
            Used for LDAP authentication such as DIGEST-MD5, anything that is not "simple".
            "cn=%s,ou=London,dc=company,dc=com" - If the user types in "Joe Bloggs" the authenticate as "cn=Joe Bloggs,ou=London,dc=company,dc=com"
            Usually for simple authentication. Simple authentication always uses the DN for the user.
            <value>${ldap.authentication.userNameFormat}</value>
        </property>
        <property name="nodeService">
            <ref bean="nodeService" />
        </property>
        <property name="personService">
            <ref bean="personService" />
        </property>
        <property name="transactionService">
            <ref bean="transactionService" />
        </property>
        <property name="escapeCommasInBind">
            <value>${ldap.authentication.escapeCommasInBind}</value>
        </property>
        <property name="escapeCommasInUid">
            <value>${ldap.authentication.escapeCommasInUid}</value>
        </property>
    </bean>
    This bean is used to support general LDAP authentication. It is also used to provide read only access to users and groups
    to pull them out of the LDAP reopsitory
    <bean id="ldapInitialDirContextFactory" class="org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl">
        <property name="initialDirContextEnvironment">
            <map>
                <!– The LDAP provider –>
                <entry key="java.naming.factory.initial">
                    <value>${ldap.authentication.java.naming.factory.initial}</value>
                </entry>
                <!– The url to the LDAP server –>
                <!– Note you can use space separated urls - they will be tried in turn until one works –>
                <!– This could be used to authenticate against one or more ldap servers (you will not know which one ….) –>
                <entry key="java.naming.provider.url">
                    <value>${ldap.authentication.java.naming.provider.url}</value>
                </entry>
                <!– The authentication mechanism to use      –>
                <!– Some sasl authentication mechanisms may require a realm to be set –>
                <!–                java.naming.security.sasl.realm –>
                <!– The available options will depend on your LDAP provider –>
                <entry key="java.naming.security.authentication">
                    <value>${ldap.authentication.java.naming.security.authentication}</value>
                </entry>
                <!– The id of a user who can read group and user information –>
                <!– This does not go through the pattern substitution defined above and is used "as is" –>
                <entry key="java.naming.security.principal">
                    <value>${ldap.authentication.java.naming.security.principal}</value>
                </entry>
                <!– The password for the user defined above –>
                <entry key="java.naming.security.credentials">
                    <value>${ldap.authentication.java.naming.security.credentials}</value>
                </entry>
            </map>
        </property>
    </bean>
</beans>
Please help!!!   Thank you.
Geoffrey
12 REPLIES 12
lakshya
This can help you Smiley Happy
Steps to follow for LDAP authentication in Alfresco:
Step 1:
Open
<Alfresco tomcat>\shared\classes\alfresco\extension\ ldap-authentication.properties
Change the following properties:
ldap.authentication.userNameFormat=%[email protected]
ldap.authentication.java.naming.provider.url=ldap://ptdc.abc.co.in:389
ldap.authentication.java.naming.security.authentication=SIMPLE
#ldap.authentication.java.naming.security.principal=<userid>
#ldap.authentication.java.naming.security.credentials=<password>
# Escape commas entered by the user at bind time
# Useful when using simple authentication and the CN is part of the DN and contains commas
# Escape commas entered by the user when setting the authenticated user
# Useful when using simple authentication and the CN is part of the DN and contains commas, and the escaped \, is
# pulled in as part of an LDAP sync
# If this option is set to true it will break the default home folder provider as space names can not contain \
Step 2:
Rename file ldap-authentication-context.xml.sample to ldap-authentication-context.xml
Step 3:
Restart the server and login with persistent domain credentials. No need to give domain name.
Step 4:
Set User as admin
Open
<Alfresco tomcat>\webapps\alfresco\WEB-INF\classes\alfresco\authority-services-context.xml
and change the value of user adminUsers from admin. In our case, we have replaced ‘admin’ with ‘laxmi_tidke’.
Example:
<property name="adminUsers">
            <set>
             <value>laxmi_tidke</value>
             <value>administrator</value>
          </set>
        </property>
geoffrey1211
thanks for your reply.  I however figured out that the "uid" attribute is required on the AD server in order for this DIGEST-MD5 to work - SASL Realm is not necessary at all.
naveenalfresco
:cry:   Anyone pls help me.  Its urgent
I am not able to set the LDAP and Alfresco properly since 4 days.   I am getting the following error
WARN  [org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl] LDAP server supports anonymous bind ldap://172.22.3.134:389
INFO  [org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl] LDAP server does not support simple string user ids and invalid credentials at ldap://172.22.3.134:389
INFO  [org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl] LDAP server does not fall back to anonymous bind for a simple dn and password at ldap://172.22.3.134:389
INFO  [org.alfresco.repo.security.authentication.ldap.LDAPInitialDirContextFactoryImpl] LDAP server does not fall back to anonymous bind for known principal and invalid credentials at ldap://172.22.3.134:389
My configurations files are as below
ldap.authentication.userNameFormat=cn=%s,ou=people,dc=someco,dc=com
ldap.authentication.java.naming.provider.url=ldap://172.22.3.134:389
ldap.authentication.java.naming.security.principal=cn=Manager,dc=someco,dc=com
<beans>
            <value>true</value>
        </property>
        </property>
    </bean>
            <value>true</value>
        </property>
    </bean>
    <bean id="authenticationComponentImplLDAP"
        </property>
        </property>
        </property>
        </property>
        </property>
        </property>
        </property>
    </bean>
            <map>
                </entry>
                </entry>
                </entry>
                </entry>
                </entry>
            </map>
        </property>
    </bean>
</beans>
chaining-authentication-context.xml
<beans>
    <!– Chaining –>
    <bean id="authenticationServiceImpl" class="org.alfresco.repo.security.authentication.ChainingAuthenticationServiceImpl">
        <property name="authenticationServices">
            <list>
                <ref bean="authenticationServiceImplLDAP"/>
            </list>
        </property>
        <property name="mutableAuthenticationService">
            <ref bean="authenticationServiceImplAlfresco"/>
        </property>
    </bean>
    <!– Alfresco Auth –>
    <bean id="authenticationServiceImplAlfresco" class="org.alfresco.repo.security.authentication.AuthenticationServiceImpl">
        <property name="authenticationDao">
            <ref bean="authenticationDaoAlfresco"/>
        </property>
        <property name="ticketComponent">
            <ref bean="ticketComponent"/>
        </property>
        <property name="authenticationComponent">
            <ref bean="authenticationComponentImplAlfresco"/>
        </property>
    </bean>
    <bean id="authenticationDaoAlfresco" class="org.alfresco.repo.security.authentication.RepositoryAuthenticationDao">
            <ref bean="nodeService"/>
        </property>
        <property name="dictionaryService">
            <ref bean="dictionaryService"/>
        </property>
        <property name="namespaceService">
            <ref bean="namespaceService"/>
        </property>
        <property name="searchService">
            <ref bean="searchService"/>
        </property>
        <property name="userNamesAreCaseSensitive">
            <value>${user.name.caseSensitive}</value>
        </property>
        <property name="passwordEncoder">
            <ref bean="passwordEncoder"/>
        </property>
    </bean>
    <bean id="authenticationComponentImplAlfresco" class="org.alfresco.repo.security.authentication.AuthenticationComponentImpl">
        </property>
        <property name="authenticationManager">
            <ref bean="authenticationManager"/>
        </property>
        <property name="allowGuestLogin">
            <value>true</value>
        </property>
    </bean>
   <!– LDAP Auth –>
    <bean id="authenticationServiceImplLDAP" class="org.alfresco.repo.security.authentication.AuthenticationServiceImpl">
            <ref bean="authenticationDaoLDAP" />
        </property>
            <ref bean="ticketComponent" />
        </property>
            <ref bean="authenticationComponentImplLDAP" />
        </property>
    </bean>
    <bean id="authenticationComponentImplLDAP" class="org.alfresco.repo.security.authentication.ldap.LDAPAuthenticationComponentImpl">
        </property>
            <value>cn=%s,ou=people,dc=someco,dc=com</value>
        </property>
    </bean>
    <bean id="authenticationDaoLDAP" class="org.alfresco.repo.security.authentication.ntlm.NullMutableAuthenticationDao"/>
</beans>
Can any one pls help me to configure the LDAP with Alfresco.
Advance Thanks
