Hi everybody!
I'm new, both in this forum and in activiti. So I'm sorry for asking what I suppose is a simple question, but I couldn't find any helpful answer anywhere.
I need to send a signal to a receive task running on a remote activiti engine. How can I do it?
My idea is the following: we run a activiti engine in a standard installation on tomcat with a very simple process, which is waiting for a signal when a manual task ist finished. The manual task ist done in a java swing application, which should send the signal on pressing a button. I am now looking for a code example that shows, what should happen after pressing the button
What ist the best way to do this? Can anybody help, please?
Thanks in advance
Norbert
