Showstopping problems with character encoding
kosmosik
I've installed Alfresco Community Edition to evaluate it. Everything quite works but when I input international (polish like: ąźłęźżółę etc.) characters in some fields and send the form they are stored and apear as "????" in browser.
F.e. it happens for description of folder/space but in usernames it is OK.
I've installed Alfresco on RHEL5, Tomcat (bundled one), MySQL (UTF8 database).
I've searched everywhere but I can't find the root of problem and I've ran out of ideas. Smiley Sad Any suggestions?
steve
You should be seeing your entered characters being displayed, not question marks.
This normally points to a misconfiguration somewhere - can you check that the following settings are in your 'my.cnf' config cile for MySQL:
[mysql]
default-character-set=utf8
and
[mysqld]
# The default character set that will be used when a new schema or table is
# created and no character set is defined
Steve
