send same content to multiple projects in same alf instance
Options
05-16-2010 10:43 PM
Hello.
I have been using alfresco for a month now… I have used avm deployment too…
What i want to do is, have an origin project, send all its contents to other projects, say target1, target2 and target3.
Point to be considered is all the projects are in the same alfresco instance.
I am not sure if this is possible using avm deployment.
Could anyone tell me any option to achieve this? (* copy same contents across multiple projects in same alfresco instance).
I mean with or without avm deployment, this is to be done…
Thanks in advance.
With Best Rgds,
Mayur2509.
Thanks in advance.
With Best Rgds,
Mayur2509.
Labels:
Archive
Options
05-17-2010 10:30 AM
For WCM authoring, if you simple want to copy the latest file or folder using Alfresco Explorer then you also have the option to copy-and-paste from one web project to another (in source web project, use "View details -> Copy" and in the destination web project, use "Shelf -> Clipboard -> Paste All" from the left-hand pane).
Regards,
Jan
Regards,
Jan
