03-21-2010 05:35 PM
<process-definition xmlns="urn:jbpm.org:jpdl-3.1" name="wf:parallelgroupreview">
<swimlane name="initiator"></swimlane>
<start-state name="start">
<task name="wf:submitGroupReviewTask" swimlane="initiator" />
<transition name="" to="startreview"/>
</start-state>
<node name="startreview">
<action class="org.alfresco.repo.workflow.jbpm.ForEachFork">
<foreach>#{people.getMembers(bpm_groupAssignee)}</foreach>
<var>reviewer</var>
</action>
<event type="node-enter">
<script>
<variable name="wf_approveCount" access="write" />
<expression>
wf_approveCount = 0;
</expression>
</script>
</event>
<transition name="review" to="review" />
</node>
<task-node name="review">
<task name="wf:reviewTask">
<assignment class="org.alfresco.repo.workflow.jbpm.AlfrescoAssignment">
<actor>#{reviewer}</actor>
</assignment>
<event type="task-create">
<script>
if (bpm_workflowDueDate != void) taskInstance.dueDate = bpm_workflowDueDate;
if (bpm_workflowPriority != void) taskInstance.priority = bpm_workflowPriority;
</script>
</event>
</task>
<transition name="reject" to="endreview" />
<transition name="approve" to="endreview">
<script>
<variable name="wf_approveCount" access="read,write" />
<expression>
wf_approveCount = wf_approveCount +1;
</expression>
</script>
</transition>
</task-node>
<join name="endreview">
<transition to="isapproved" />
</join>
<decision name="isapproved">
<action class="org.alfresco.repo.workflow.jbpm.AlfrescoJavaScript">
<script>
<variable name="wf_reviewerCount" access="write"/>
<expression>people.getMembers(bpm_groupAssignee).length;</expression>
</script>
</action>
<script>
<variable name="wf_requiredPercent" access="write"/>
<expression>wf_requiredPercent = wf_requiredApprovePercent;</expression>
</script>
</action>
<script>
<variable name="wf_actualPercent" access="write"/>
<expression>wf_actualPercent = ((wf_approveCount * 100) / people.getMembers(bpm_groupAssignee).length);</expression>
</script>
</action>
</event>
<transition name="reject" to="rejected" />
<transition name="approve" to="approved">
<script>
<!–cambio el nombre–>
document.properties.name = document.properties.name + "*OK*";
<document.save();
</script>
<condition>#{wf_actualPercent >= wf_requiredApprovePercent}</condition>
</transition>
</decision>
<task-node name="rejected">
<task name="wf:rejectedParallelTask" swimlane="initiator" />
<transition to="end" />
</task-node>
<task-node name="approved">
<task name="wf:approvedParallelTask" swimlane="initiator" />
</task-node>
<end-state name="end"/>
22:25:46,852 INFO [org.alfresco.config.SystemPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/hibernate-cfg.properties]
22:25:46,854 INFO [org.alfresco.config.SystemPropertiesFactoryBean] Loading properties file from class path resource [alfresco/extension/custom-hibernate-dialect.properties]
22:25:53,894 ERROR [org.alfresco.repo.content.transform.magick.AbstractImageMagickContentTransformer] ImageMagickContentTransformer not available: Failed to perform ImageMagick transformation:
Execution result:
os: Linux
command: [./ImageMagick/bin/convert, /opt/Alfresco/apache-tomcat-5.5.28/temp/Alfresco/ImageMagickContentTransformer_init_source_911172118054496741.gif[0], /opt/Alfresco/apache-tomcat-5.5.28/temp/Alfresco/ImageMagickContentTransformer_init_target_4416840871799592960.png]
succeeded: false
exit code: 1
out:
err: Cannot run program "./ImageMagick/bin/convert": java.io.IOException: error=2, No such file or directory
22:25:55,423 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
22:25:58,962 ERROR [org.alfresco.repo.content.transform.RuntimeExecutableContentTransformer] Failed to start a runtime executable content transformer:
Execution result:
os: Linux
command: [./bin/pdf2swf, -V]
succeeded: false
exit code: 1
out:
err: Cannot run program "./bin/pdf2swf": java.io.IOException: error=2, No such file or directory
22:26:04,025 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
22:26:05,119 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
22:26:05,626 DEBUG [org.alfresco.repo.avm.TransactionalLookupCache.init] preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@4383e3, name=log4j:logger=org.alfresco.repo.avm.TransactionalLookupCache.init
22:26:05,652 DEBUG [org.alfresco.web.bean.TemplateMailHelperBean] preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@4383e3, name=log4j:logger=org.alfresco.web.bean.TemplateMailHelperBean
22:26:07,698 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /opt/Alfresco/repositorio
22:26:07,758 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
22:26:07,924 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
22:26:07,927 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
22:26:13,053 ERROR [org.alfresco.fileserver] Failed to get local domain/workgroup name, using default of WORKGROUP
22:26:13,054 ERROR [org.alfresco.fileserver] (This may be due to firewall settings or incorrect <broadcast> setting)
22:26:13,285 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
22:26:13,332 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_18-b07; maximum heap size 981,375MB
22:26:13,332 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco license: Enterprise - v3.1 granted to Intecna (does not expire)
22:26:13,332 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Enterprise): Current version 3.1.2 (390) schema 1011 - Installed version 3.1.2 (390) schema 1011
22:27:23,381 ERROR [org.jbpm.graph.def.GraphElement] action threw exception: Sourced file: inline evaluation of: `` document.properties.name = document.properties.name + "OK"; document.sa . . . '' : Method save() not found in bsh scripted object: auto: document
Sourced file: inline evaluation of: `` document.properties.name = document.properties.name + "OK"; document.sa . . . '' : Method save() not found in bsh scripted object: auto: document : at Line: 4 : in file: inline evaluation of: `` document.properties.name = document.properties.name + "OK"; document.sa . . . '' : document .save ( )
at bsh.This.invokeMethod(Unknown Source)
at bsh.Reflect.invokeObjectMethod(Unknown Source)
at bsh.Name.invokeMethod(Unknown Source)
at bsh.BSHMethodInvocation.eval(Unknown Source)
at bsh.BSHPrimaryExpression.eval(Unknown Source)
at bsh.Interpreter.eval(Unknown Source)
at org.jbpm.graph.action.Script.eval(Script.java:130)
at org.jbpm.graph.action.Script.eval(Script.java:73)
at org.jbpm.graph.action.Script.execute(Script.java:62)
at org.jbpm.graph.def.GraphElement.executeAction(GraphElement.java:264)
at org.jbpm.graph.def.GraphElement.executeActions(GraphElement.java:220)
at org.jbpm.graph.def.GraphElement.fireAndPropagateEvent(GraphElement.java:190)
at org.jbpm.graph.def.GraphElement.fireEvent(GraphElement.java:174)
at org.jbpm.graph.def.Transition.take(Transition.java:138)
at org.jbpm.graph.def.Node.leave(Node.java:394)
at org.jbpm.graph.exe.ExecutionContext.leaveNode(ExecutionContext.java:136)
at org.jbpm.graph.node.Decision.execute(Decision.java:152)
at org.jbpm.graph.def.Node.enter(Node.java:319)
at org.hibernate.proxy.pojo.cglib.CGLIBLazyInitializer.invoke(CGLIBLazyInitializer.java:157)
at org.jbpm.graph.def.Node$$EnhancerByCGLIB$$49892876.enter(<generated>)
at org.jbpm.graph.def.Transition.take(Transition.java:151)
at org.jbpm.graph.def.Node.leave(Node.java:358)
at org.jbpm.graph.node.Join.execute(Join.java:191)
at org.jbpm.graph.node.TaskNode.leave(TaskNode.java:209)
at org.jbpm.graph.node.TaskNode$$EnhancerByCGLIB$$83cf1ec0.leave(<generated>)
at org.jbpm.graph.exe.Token.signal(Token.java:195)
at org.jbpm.graph.exe.Token.signal(Token.java:166)
at org.jbpm.graph.exe.Token$$EnhancerByCGLIB$$f617cf0a.signal(<generated>)
at org.jbpm.taskmgmt.exe.TaskInstance.end(TaskInstance.java:488)
at org.alfresco.repo.workflow.jbpm.WorkflowTaskInstance.end(WorkflowTaskInstance.java:133)
at org.jbpm.taskmgmt.exe.TaskInstance.end(TaskInstance.java:427)
at org.alfresco.repo.workflow.jbpm.JBPMEngine$26.doInJbpm(JBPMEngine.java:1687)
at org.springframework.orm.hibernate3.HibernateTemplate.execute(HibernateTemplate.java:372)
at org.springframework.orm.hibernate3.HibernateTemplate.execute(HibernateTemplate.java:338)
at org.alfresco.repo.workflow.jbpm.JBPMEngine.endTask(JBPMEngine.java:1655)
at org.alfresco.repo.workflow.WorkflowServiceImpl.endTask(WorkflowServiceImpl.java:544)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:304)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.alfresco.repo.security.permissions.impl.AlwaysProceedMethodInterceptor.invoke(AlwaysProceedMethodInterceptor.java:40)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:49)
at org.alfresco.repo.audit.AuditComponentImpl.audit(AuditComponentImpl.java:275)
at org.alfresco.repo.audit.AuditMethodInterceptor.invoke(AuditMethodInterceptor.java:69)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:106)
at $Proxy52.endTask(Unknown Source)
at org.alfresco.web.bean.workflow.ManageTaskDialog.transition(ManageTaskDialog.java:431)
at org.apache.myfaces.el.MethodBindingImpl.invoke(MethodBindingImpl.java:132)
at org.apache.myfaces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:61)
at javax.faces.component.UICommand.broadcast(UICommand.java:109)
at javax.faces.component.UIViewRoot._broadcastForPhase(UIViewRoot.java:97)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:171)
at org.apache.myfaces.lifecycle.InvokeApplicationExecutor.execute(InvokeApplicationExecutor.java:32)
at org.apache.myfaces.lifecycle.LifecycleImpl.executePhase(LifecycleImpl.java:95)
at org.apache.myfaces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:70)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:139)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.alfresco.web.app.servlet.AuthenticationFilter.doFilter(AuthenticationFilter.java:81)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:873)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
22:27:23,413 ERROR [org.alfresco.web.ui.common.Utils] A system error happened during the operation: Failed to signal transition 'approve' from workflow task 'jbpm$84'
org.alfresco.service.cmr.workflow.WorkflowException: Failed to signal transition 'approve' from workflow task 'jbpm$84'
at org.alfresco.repo.workflow.jbpm.JBPMEngine.endTask(JBPMEngine.java:1702)
Caused by: org.jbpm.graph.def.DelegationException: Sourced file: inline evaluation of: `` document.properties.name = document.properties.name + "OK"; document.sa . . . '' : Method save() not found in bsh scripted object: auto: document
at org.jbpm.graph.def.GraphElement.raiseException(GraphElement.java:387)
at org.jbpm.graph.def.GraphElement.raiseException(GraphElement.java:378)
at org.jbpm.graph.def.GraphElement.executeAction(GraphElement.java:281)
… 50 more
Caused by: Sourced file: inline evaluation of: `` document.properties.name = document.properties.name + "OK"; document.sa . . . '' : Method save() not found in bsh scripted object: auto: document : at Line: 4 : in file: inline evaluation of: `` document.properties.name = document.properties.name + "OK"; document.sa . . . '' : document .save ( )
… 101 more
03-23-2010 02:35 PM
9:27:52,255 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
19:27:53,237 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
19:27:53,763 DEBUG [org.alfresco.repo.avm.TransactionalLookupCache.init] preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@13727fe, name=log4j:logger=org.alfresco.repo.avm.TransactionalLookupCache.init
19:27:53,838 DEBUG [org.alfresco.web.bean.TemplateMailHelperBean] preRegister called. Server=com.sun.jmx.mbeanserver.JmxMBeanServer@13727fe, name=log4j:logger=org.alfresco.web.bean.TemplateMailHelperBean
19:27:55,969 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /opt/Alfresco/repositorio
19:27:56,046 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
19:27:56,227 INFO [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
19:27:56,231 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
19:28:01,375 ERROR [org.alfresco.fileserver] Failed to get local domain/workgroup name, using default of WORKGROUP
19:28:01,375 ERROR [org.alfresco.fileserver] (This may be due to firewall settings or incorrect <broadcast> setting)
19:28:01,641 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
19:28:01,686 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_18-b07; maximum heap size 981,375MB
19:28:01,686 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco license: Enterprise - v3.1 granted to Intecna (does not expire)
19:28:01,687 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Enterprise): Current version 3.1.2 (390) schema 1011 - Installed version 3.1.2 (390) schema 1011
19:31:14,821 ERROR [org.jbpm.graph.def.GraphElement] action threw exception: Failed to execute supplied script: Access Denied. You do not have the appropriate permissions to perform this operation.
org.alfresco.scripts.ScriptException: Failed to execute supplied script: Access Denied. You do not have the appropriate permissions to perform this operation.
at org.alfresco.repo.jscript.RhinoScriptProcessor.executeString(RhinoScriptProcessor.java:254)
at org.alfresco.repo.processor.ScriptServiceImpl.executeScriptString(ScriptServiceImpl.java:314)
at org.alfresco.repo.processor.ScriptServiceImpl.executeScriptString(ScriptServiceImpl.java:292)
at $Proxy180.executeScriptString(Unknown Source)
at org.alfresco.repo.workflow.jbpm.AlfrescoJavaScript.executeScript(AlfrescoJavaScript.java:178)
at org.alfresco.repo.workflow.jbpm.AlfrescoJavaScript.execute(AlfrescoJavaScript.java:132)
at org.jbpm.graph.def.Action.execute(Action.java:122)
at org.jbpm.graph.def.Node$$EnhancerByCGLIB$$c72b321.enter(<generated>)
at org.jbpm.graph.node.TaskNode$$EnhancerByCGLIB$$46b8a96b.leave(<generated>)
at org.jbpm.graph.exe.Token$$EnhancerByCGLIB$$b90159b5.signal(<generated>)
Caused by: org.alfresco.repo.security.permissions.AccessDeniedException: Access Denied. You do not have the appropriate permissions to perform this operation.
at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:53)
at $Proxy7.addAspect(Unknown Source)
at org.alfresco.repo.jscript.ScriptNode.addAspect(ScriptNode.java:1473)
at org.alfresco.repo.jscript.ScriptNode.addAspect(ScriptNode.java:1450)
at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:243)
at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:66)
at org.mozilla.javascript.gen.c6._c0(AlfrescoJS:1)
at org.mozilla.javascript.gen.c6.call(AlfrescoJS)
at org.mozilla.javascript.gen.c6.exec(AlfrescoJS)
at org.alfresco.repo.jscript.RhinoScriptProcessor.executeScriptImpl(RhinoScriptProcessor.java:449)
at org.alfresco.repo.jscript.RhinoScriptProcessor.executeString(RhinoScriptProcessor.java:250)
… 125 more
Caused by: net.sf.acegisecurity.AccessDeniedException: Access is denied.
at net.sf.acegisecurity.vote.AffirmativeBased.decide(AffirmativeBased.java:86)
at net.sf.acegisecurity.intercept.AbstractSecurityInterceptor.beforeInvocation(AbstractSecurityInterceptor.java:394)
… 150 more
19:31:14,837 ERROR [org.alfresco.web.ui.common.Utils] A system error happened during the operation: Failed to signal transition 'approve' from workflow task 'jbpm$101'
org.alfresco.service.cmr.workflow.WorkflowException: Failed to signal transition 'approve' from workflow task 'jbpm$101'
Caused by: org.jbpm.graph.def.DelegationException: Failed to execute supplied script: Access Denied. You do not have the appropriate permissions to perform this operation.
… 50 more
Caused by: org.alfresco.scripts.ScriptException: Failed to execute supplied script: Access Denied. You do not have the appropriate permissions to perform this operation.
… 101 more
… 125 more
… 150 more
03-23-2010 02:52 PM
at $Proxy7.addAspect(Unknown Source)Asi que tendras que comprobar si el usuario que realiza la transicion tiene permisos sobre el documento para añadir un aspecto ( creo que contribuidor te valdria .. no obstante si tienes problemas tira por coordinador y seguro que deja .. luego podras crearte tu rol especifico si te interesa ).
03-23-2010 04:44 PM
03-23-2010 05:56 PM
// Para ejecutar codigo javascript en algun momento denerminado de los nodos(partes del workflow) que quieras
//debes utilizar los event , en este ejemplo ejecuto el codigo al entrar al nodo aceptar por ejemplo(node-enter)
//pero podria utilizar otros en la wiki estan los que hay disponibles
<script>
//por otra parte ya he visto que has descubierto que no puede utilizar el objeto document en este contexto si no
//que debes acceder a los "hijos"(recursos/adjuntos) del workflows mediante su propiedad children, a la que te refieres
//cono children[0], aqui abajo tienes un ejemplo de como recorrerlos todos, porque debes valorar la posibilidad de que
//en un mismo workflow los usuarios puedan adjuntarte varios documentos, que lo pueden hacer a no ser que tu lo evites de //alguna manera y ademas pueden añadir mas documentos en cualquier paso del workflow tambien, a no ser que tu lo evites //tambien, en cuanto al tema de los permisos si por ejemplo necesitas que un usuario sin permisos pueda ejecutar las //acciones que realices sobre los documentos, puedes eliminar y asignar permisos durante los pasos del workflow para ese //usuario o grupo a tu antojo y si te los guardas de alguna manera(en una propiedad o aspecto por ejemplo) puedes volver a //dejar al usuario o grupo con los permisos que tenia antes de iniciar el workflow despues de finalizarlo, es decir que solo //tenga mas permisos de los normales cuando ejecute un workflow X que tu quieras, bueno son opciones que te doy, para //ello esto se hace rompiendo la herencia java para los permisos de los espacios sobre los documentos de manera que estos //permisos solo se mantienen para el usuario o grupo que tu hayas modificado sobre el documento en concreto del workflow
//tienes como ejemplo este codigo tambien con este for, lo que hace es,
//Por cada documento que tenga el workflow, rompe la herencia, recorre cada uno de los permisos que tenga y los elimina
//y por ultimo asigna el rol X al usuario actual que este haciendo uso del workflow.
Espero que todo esto te oriente un poco mas.
for (var i = 0; i < bpm_package.children.length; i++)
bpm_package.children[i].setInheritsPermissions(false);
var permissions = bpm_package.children[i].permissions;
var acl=[];
for (var j=0; j < permissions.length; j++)
acl = permissions[j].split(";");
var perm=acl[2];
var grp=acl[1];
bpm_package.children[i].removePermission(perm,grp);
bpm_package.children[i].setPermission("Consumer", reviewer.properties["cm:userName"]);
</script>
</action>
</event>Tags
