Recursive nesting of indexbackup_temp directories
hbf
I've upgraded to Alfresco 2.9b and have just realised that my alf_data directory contains
audit.contentstore
contentstore
contentstore.deleted
lucene-indexes
  archive
  indexbackup_temp  (*)
    archive
    indexbackup_temp
      <story goes on recursively in here to some extent>
    locks
    system
  locks
  system
  user
  workspace
Can I safely remove the directory indexbackup_temp (marked with a star above)?
Should I reindex afterwards?
Kaspar
P.S. This seems to be JIRA issue AR-2175.
12 REPLIES 12
andy
Hi
You can avoid this problem by moving the back up localtion.
Andy
natew
How does one move the backup location?  Is that a property somewhere?
hbf
From the JIRA issue discussion (see above), I assumed it is sufficient to set
dir.root=/home/whatever/repository-server/alf_data
dir.indexes.backup=${dir.root}/backup-lucene-indexes
but that does not solve the issue:
2008-09-02 03:00:22,106 ERROR DefaultScheduler_Worker-3 org.quartz.core.JobRunShell - Job DEFAULT.indexBackupJobDetail threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: Failed to copy Lucene index root:
   Index root: /home/icarbasel/icar-checkout/knowledge-center-icar/trunk/repository-server/alf_data/lucene-indexes
   Target: /home/icarbasel/icar-checkout/knowledge-center-icar/trunk/repository-server/alf_data/lucene-indexes/backup-lucene-indexes
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory$LuceneIndexBackupComponent$BackUpWithAllWriteLocksWork.doWork(AbstractLuceneIndexerAndSearcherFactory.java:1061)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory$CoreLockWork$1.doWork(AbstractLuceneIndexerAndSearcherFactory.java:1253)
        at org.alfresco.repo.search.impl.lucene.index.IndexInfo.doWithFileLock(IndexInfo.java:2115)
        at org.alfresco.repo.search.impl.lucene.index.IndexInfo.doWithWriteLock(IndexInfo.java:2082)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneBase.doWithWriteLock(AbstractLuceneBase.java:334)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory$CoreLockWork.doWork(AbstractLuceneIndexerAndSearcherFactory.java:1247)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory$NestingLockWork.doWork(AbstractLuceneIndexerAndSearcherFactory.java:1229)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory.doWithAllWriteLocks(AbstractLuceneIndexerAndSearcherFactory.java:1192)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory$LuceneIndexBackupComponent.backupImpl(AbstractLuceneIndexerAndSearcherFactory.java:1026)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory$LuceneIndexBackupComponent.access$000(AbstractLuceneIndexerAndSearcherFactory.java:930)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory$LuceneIndexBackupComponent$1.execute(AbstractLuceneIndexerAndSearcherFactory.java:1001)
        at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:236)
        at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:166)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory$LuceneIndexBackupComponent.backup(AbstractLuceneIndexerAndSearcherFactory.java:1005)
        at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory$LuceneIndexBackupJob.execute(AbstractLuceneIndexerAndSearcherFactory.java:1131)
        at org.quartz.core.JobRunShell.run(JobRunShell.java:202)
        at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:529)
Caused by: java.io.FileNotFoundException: /home/icarbasel/icar-checkout/knowledge-center-icar/trunk/repository-server/alf_data/lucene-indexes/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexba\
ckup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/ind\
exbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp\
/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_\
temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbac\
kup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/inde\
xbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/\
indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_t\
emp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexback\
up_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/index\
backup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/i\
ndexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_te\
mp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbacku\
p_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexb\
ackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/in\
dexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_tem\
p/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup\
_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/indexbackup_temp/archive/SpacesStore/58fe283e-7849-11dd-a590-8bf63e7d4f4f/segments.gen (File name too long)
        at java.io.FileOutputStream.open(Native Method)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:131)
        at org.apache.commons.io.FileUtils.doCopyFile(FileUtils.java:503)
        at org.apache.commons.io.FileUtils.doCopyDirectory(FileUtils.java:617)
Am I doing something wrong?
Kaspar
