12-28-2006 04:35 AM
<!– Definition of new Model –>
<!– The important part here is the name - Note: the use of the my: namespace
which is defined further on in the document –>
<model name="my:mynewmodel" xmlns="http://www.alfresco.org/model/dictionary/1.0">
<description>Example custom Model</description>
<author></author>
<version>1.0</version>
<!– Imports are required to allow references to definitions in other models –>
<imports>
<!– Import Alfresco Dictionary Definitions –>
<!– Import Alfresco Content Domain Model Definitions –>
</imports>
<!– Introduction of new namespaces defined by this model –>
<!– NOTE: The following namespace my.new.model should be changed to reflect your own namespace –>
<namespaces>
<namespace uri="my.new.model" prefix="my"/>
</namespaces>
<types>
<!– Definition of new Content Type: Standard Operating Procedure –>
<type name="my:sop">
<title>Standard Operating Procedure</title>
<parent>cm:content</parent>
<properties>
<property name="my:publishedDate">
<type>d:datetime</type>
</property>
<property name="my:authorisedBy">
<type>d:text</type>
</property>
</properties>
<associations>
<association name="my:signOff">
<target>
<class>cm:content</class>
<mandatory>false</mandatory>
<many>false</many>
</target>
</association>
<child-association name="my:processSteps">
<target>
<many>true</many>
</target>
</child-association>
</associations>
</type>
</types>
<aspects>
<!– Definition of new Content Aspect: Image Classification –>
<aspect name="my:imageClassification">
<title>Image Classfication</title>
<properties>
<property name="my:width">
<type>d:int</type>
</property>
<property name="my:height">
<type>d:int</type>
</property>
<property name="my:resolution">
<type>d:int</type>
</property>
</properties>
</aspect>
</aspects>
</model><alfresco-config>
<!– Example of overriding the from email address –>
<config>
<client>
<from-email-address>[email protected]</from-email-address>
<search-max-results>100</search-max-results>
</client>
</config>
<!– Example of adding languages to the list in the login page –>
<config evaluator="string-compare" condition="Languages">
<languages>
<language locale="ca_ES">Catalan</language>
<language locale="da_DK">Danish</language>
<language locale="de_DE">German</language>
<language locale="es_ES">Spanish</language>
<language locale="el_GR">Greek</language>
<language locale="fr_FR">French</language>
<language locale="it_IT">Italian</language>
<language locale="ja_JP">Japanese</language>
<language locale="du_NL">Dutch</language>
<language locale="pt_BR">Portuguese (Brazilian)</language>
<language locale="ru_RU">Russian</language>
<language locale="fi_FI">Finnish</language>
<language locale="tr_TR">Turkish</language>
<language locale="zh_CN">Simplified Chinese</language>
</languages>
</config>
<!– Example of configuring advanced search –>
<config evaluator="string-compare" condition="Advanced Search">
<advanced-search>
<content-types>
</content-types>
<custom-properties>
<meta-data aspect="app:simpleworkflow" property="app:approveStep" />
</custom-properties>
</advanced-search>
</config>
<!– Example of changing the sort direction for a view in the client –>
<config evaluator="string-compare" condition="Views">
<views>
<view-defaults>
<topic>
<sort-direction>ascending</sort-direction>
</topic>
</view-defaults>
</views>
</config>
<!– Example of adding a custom icon to the Create Space dialog –>
<config evaluator="string-compare" condition="cm:folder icons">
<icons>
<icon name="space-icon-custom" path="/images/icons/space-icon-custom.gif" />
</icons>
</config>
<!– The config below shows how to incorporate the example model–>
<!– into the web client, for this to work you will need to –>
<!– rename example-model-context.xml.sample to example-model-context.xml –>
<config evaluator="string-compare" condition="Content Wizards">
<content-types>
<type name="my:sop" />
</content-types>
</config>
<config evaluator="node-type" condition="my:sop">
<property-sheet>
<show-property name="mimetype" display-label-id="content_type"
component-generator="MimeTypeSelectorGenerator" />
<show-property name="size" display-label-id="size"
converter="org.alfresco.faces.ByteSizeConverter"
show-in-edit-mode="false" />
<show-property name="my:publishedDate" />
<show-association name="my:signOff" />
<show-property name="my:authorisedBy" />
<show-child-association name="my:processSteps" />
</property-sheet>
</config>
<config evaluator="aspect-name" condition="my:imageClassification">
<property-sheet>
<show-property name="my:width"/>
<show-property name="my:height"/>
<show-property name="my:resolution"/>
</property-sheet>
</config>
<config evaluator="string-compare" condition="Action Wizards">
<aspects>
<aspect name="my:imageClassification"/>
</aspects>
</config>
<advanced-search>
<content-types>
</content-types>
<custom-properties>
<meta-data type="my:sop" property="my:authorisedBy" />
<meta-data aspect="my:imageClassification" property="my:resolution" />
</advanced-search>
</config>
<config evaluator="node-type" condition="wiki:page">
<property-sheet>
<show-property name="wiki:restrict"/>
<show-property name="wiki:category"/>
</property-sheet>
</config>
<config evaluator="string-compare" condition="Custom Content Types">
<content-types>
<type name="wiki:page"/>
</content-types>
</config>
<advanced-search>
<content-types>
<type name="wiki:page" />
</content-types>
<custom-properties>
<meta-data type="wiki:page" property="wiki:restrict" />
<meta-data type="wiki:page" property="wiki:category" />
</advanced-search>
</config>
</alfresco-config><?xml version='1.0' encoding='UTF-8'?>
<beans>
<!– Registration of new models –>
<bean id="extension.dictionaryBootstrap" parent="dictionaryModelBootstrap" depends-on="dictionaryBootstrap">
<property name="models">
<list>
<value>alfresco/extension/exampleModel.xml</value>
</list>
</property>
</bean>
</beans>
02-27-2007 10:40 AM
02-27-2007 10:45 AM
02-27-2007 10:50 AM
02-27-2007 10:51 AM
02-27-2007 10:57 AM
02-27-2007 10:58 AM
02-27-2007 11:14 AM
02-28-2007 03:31 AM
<aspects>
</aspects>
</config>
02-28-2007 09:42 AM
