Problems with ' in filename
platypus69
I'm using CmisSync with Alfresco Community and I've some problems with files with " ' " in the name.
Indeed, I've this error :
2016-03-01 08:45:34,533 [9] ERROR CmisSync.Lib.Sync.CmisRepo+SynchronizedFolder [(null)] - Could not download file: C:\Users\anynomised\CmisSync\anynomised\55-Installation serveurs\Serveur\Résolution problème\Manuel de l\u2019utilisateur de HP Array Configuration Utility-c00709070.pdf
I try to solve it with the developer of CmisSync (https://github.com/aegif/CmisSync/issues/657) but we've found that there is 3 patterns depending on the method of uploading the file :
    Pattern 1: Uploading via CMIS Workbench to https://www.alfresco.com/cmis results in cmis:name ’
    Pattern 2: Uploading via Share drag-and-drop to your Alfresco 5.1 results in cmis:name '
    Pattern 3: Uploading via ? to your Alfresco 5.1 results in cmis:name \u2019
Can you explain it and help us ?
Thank you
nicolasraoul
It looks like Pattern 2 has been interpreted by the forum application, in fact it should read "& a p o s ;" without the spaces.
To summarize: Three ways of uploading the same file to Alfresco (CMIS Workbench, Share, etc), three different resulting cmis:name.
