Problems with Actitivi 5.9 and Web Service calls
erny18031
Hi.
Hi would like to use the standard BPMN way to call web services (no specific clients).
My BPMN is something like this:
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL"
             xmlns:activiti="http://activiti.org/bpmn"
             xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI"
             xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC"
             xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI"
             typeLanguage="http://www.w3.org/2001/XMLSchema"
             expressionLanguage="http://www.w3.org/1999/XPath"
             targetNamespace="http://www.activiti.org/test"
             xmlns:tns="http://www.activiti.org/test"
             xmlns:weather="http://www.webserviceX.NET">
  <import importType="http://schemas.xmlsoap.org/wsdl/"
        location="http://www.webservicex.net/globalweather.asmx?WSDL"
        namespace="http://www.webserviceX.NET" />
  <process id="ProcesoEjemplo" name="ProcesoEjemplo">
    <ioSpecification>
        <dataInput id="dataInputOfProcess" itemSubjectRef="tns:requestItem" />
        <dataOutput id="dataOutputOfProcess" itemSubjectRef="tns:responseItem" />
        <inputSet>
           <dataInputRefs>dataInputOfProcess</dataInputRefs>
        </inputSet>
        <outputSet>
           <dataOutputRefs>dataOutputOfProcess</dataOutputRefs>
        </outputSet>
     </ioSpecification>
    <serviceTask id="wscall" name="LLamar WS" implementation="##WebService" operationRef="tns:operationId">
        <ioSpecification>
              <dataInput itemSubjectRef="tns:requestItem" id="dataInputOfServiceTask" />
              <dataOutput itemSubjectRef="tns:responseItem" id="dataOutputOfServiceTask" />
              <inputSet>
                      <dataInputRefs>dataInputOfServiceTask</dataInputRefs>
              </inputSet>
              <outputSet>
                      <dataOutputRefs>dataOutputOfServiceTask</dataOutputRefs>
              </outputSet>
        </ioSpecification>
        <dataInputAssociation>
            <sourceRef>dataInputOfProcess</sourceRef>
              <targetRef>dataInputOfServiceTask</targetRef>
            <assignment>
                  <from>${dataInputOfProcess.pais}</from>
                  <to>${dataInputOfServiceTask.CountryName}</to>
                </assignment>
        </dataInputAssociation>
        <dataOutputAssociation>
            <sourceRef>dataOutputOfServiceTask</sourceRef>
              <targetRef>dataOutputOfProcess</targetRef>
            <assignment>
                  <from>${dataOutputOfServiceTask}</from>
                  <to>${dataInputOfProcess.ciudades}</to>
                </assignment>
          </dataOutputAssociation>
    </serviceTask>
  </process>
  <interface name="Interface" implementationRef="weather:GlobalWeatherSoap">
      <!– Operation: implementationRef = QName of WSDL Operation –>
      <operation id="operationId" name="Operacion WS" implementationRef="weather:GetCitiesByCountry">
         <inMessageRef>tns:requestMessage</inMessageRef>
         <outMessageRef>tns:responseMessage</outMessageRef>
      </operation>
  </interface>
<message id="requestMessage" itemRef="tns:requestItem" />
<message id="responseMessage" itemRef="tns:responseItem" />
<itemDefinition id="requestItem" structureRef="weather:GetCitiesByCountry" />
<itemDefinition id="responseItem" structureRef="weather:GetCitiesByCountryResponse" />
</definitions>
Whenever I run the test (whithout activiti-cxf) I get :
org.activiti.engine.ActivitiException: Could not find importer for type http://schemas.xmlsoap.org/wsdl/ | diagrams/ProcesoEjemplo.bpmn20.xml | line 16 | column 50
Could not import item of type http://schemas.xmlsoap.org/wsdl/ | diagrams/ProcesoEjemplo.bpmn20.xml | line 16 | column 50
When I include activiti-cxf, I get the following error:
java.lang.ClassCastException: com.sun.codemodel.JCodeModel$JReferencedClass cannot be cast to com.sun.codemodel.JDefinedClass
   at org.activiti.engine.impl.webservice.CxfWSDLImporter.importStructure(CxfWSDLImporter.java:152)
   at org.activiti.engine.impl.webservice.CxfWSDLImporter.importTypes(CxfWSDLImporter.java:146)
   at org.activiti.engine.impl.webservice.CxfWSDLImporter.importFrom(CxfWSDLImporter.java:106)
   at org.activiti.engine.impl.webservice.CxfWSDLImporter.importFrom(CxfWSDLImporter.java:69)
   at org.activiti.engine.impl.bpmn.parser.BpmnParse.parseImports(BpmnParse.java:310)
What do I wrong?
Thanx.
Erny
4 REPLIES 4
trademak
Can you create a unit test that reproduces this error?
Best regards,
mss21
I am trying to test a public webservice by invoking it from webservice task. I have modified the .bpmn xml with the entries.
could anyone share a example on how to invoke a public webservice and how to test it,
Also can we create 2 service task and link them to pass the output of 1 service as input to another.
jurtiaga
I´m using the Activiti 5.10 and I have the same problem.
When I´m goint to deploy the process I get the error: "could not find importer for type http //schemas.xmlsoap.org/wsdl/"
I´ve attached the unit Test for this process, this page does not allow me to upload the files, so here we go…
#######################  UNIT TEST #############################
package org.activiti.designer.test;
import static org.junit.Assert.*;
import java.util.HashMap;
import java.util.Map;
import java.io.FileInputStream;
import org.activiti.engine.RepositoryService;
import org.activiti.engine.runtime.ProcessInstance;
import org.junit.Rule;
import org.junit.Test;
public class ProcessTestProcess1 {
private String filename = "D:/ws.bpmn";
@Rule
@Test
public void startProcess() throws Exception {
  RepositoryService repositoryService = activitiRule.getRepositoryService();
  repositoryService.createDeployment().addInputStream("process1.bpmn20.xml",
    new FileInputStream(filename)).deploy();
  Map<String, Object> variableMap = new HashMap<String, Object>();
  variableMap.put("name", "Activiti");
  ProcessInstance processInstance = runtimeService.startProcessInstanceByKey("process1", variableMap);
  assertNotNull(processInstance.getId());
  System.out.println("id " + processInstance.getId() + " "
    + processInstance.getProcessDefinitionId());
frederikherema1
Try adding activiti-cxf as a dependency, the webservice-parsing is handled by this class: org.activiti.engine.impl.webservice.CxfWSDLImporter
