Problems starting alfresco
thomas91
at the moment I have problems starting alfresco (it formerly already worked), also the ftp-server which I have configured don't seem to start (also formerly already worked):
11:17:50,279 WARN  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'.  'dir.root' should be overridden to point to a specific folder.
11:17:50,279 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: ./alf_data
11:17:50,356 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
11:17:50,461 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
11:17:50,464 INFO  [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
11:17:55,566 ERROR [org.alfresco.smb.protocol] Failed to get local domain/workgroup name, using default of WORKGROUP
11:17:55,566 ERROR [org.alfresco.smb.protocol] (This may be due to firewall settings or incorrect <broadcast> setting)
11:17:55,790 WARN  [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
11:17:55,794 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_07-b06; maximum heap size 493,063MB
11:17:55,794 WARN  [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493,063MB is less than recommended 512MB
11:17:55,794 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (a 1032) schema 128 - Installed version 3.0.0 (a 1032) schema 128
Rgds
Thomas
10 REPLIES 10
thomas91
I checked catalina.out and see that there are more errors:
09:53:36,425 UserSmiley Frustratedystem WARN  [repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'.  'dir.root' should be overridden to point to a specific folder.
09:53:36,425 UserSmiley Frustratedystem INFO  [repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: ./alf_data
09:53:36,498 UserSmiley Frustratedystem INFO  [admin.patch.PatchExecuter] Checking for patches to apply …
09:53:36,600 UserSmiley Frustratedystem INFO  [admin.patch.PatchExecuter] No patches were required.
09:53:36,604 UserSmiley Frustratedystem INFO  [repo.module.ModuleServiceImpl] Found 0 module(s).
09:53:36,767 UserSmiley Frustratedystem INFO  [alfresco.ftp.server] Starting server FTP …
09:53:36,923 UserSmiley Frustratedystem WARN  [alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
09:53:36,927 UserSmiley Frustratedystem INFO  [service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_07-b06; maximum heap size 493,063MB
09:53:36,927 UserSmiley Frustratedystem WARN  [service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 493,063MB is less than recommended 512MB
09:53:36,928 UserSmiley Frustratedystem INFO  [service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (a 1032) schema 128 - Installed version 3.0.0 (a 1032) schema 128
16.09.2008 09:53:42 org.apache.coyote.http11.Http11BaseProtocol start
SCHWERWIEGEND: Error starting endpoint
java.net.BindException: Address already in use:8080
        at org.apache.tomcat.util.net.PoolTcpEndpoint.initEndpoint(PoolTcpEndpoint.java:298)
        at org.apache.tomcat.util.net.PoolTcpEndpoint.startEndpoint(PoolTcpEndpoint.java:313)
        at org.apache.coyote.http11.Http11BaseProtocol.start(Http11BaseProtocol.java:151)
        at org.apache.coyote.http11.Http11Protocol.start(Http11Protocol.java:76)
        at org.apache.catalina.connector.Connector.start(Connector.java:1090)
        at org.apache.catalina.core.StandardService.start(StandardService.java:457)
16.09.2008 09:53:42 org.apache.catalina.startup.Catalina start
SCHWERWIEGEND: Catalina.start:
LifecycleException:  service.getName(): "Catalina";  Protocol handler start failed: java.net.BindException: Address already in use:8080
        at org.apache.catalina.connector.Connector.start(Connector.java:1097)
INFO: Server startup in 26340 ms
killing the 8080 java process solved the prolblem, but such an error should also be shown in alfresco.log not only in catalina.out!
Rgds
Thomas
