I've downloaded Activiti 5.1 and installed the Eclipse Activiti Designer plugin into Eclipse Helios. I created a simple diagram and created a unit test. When trying to run the unit test using JUnit 4.1 I get the stack trace below. In the JUnit logging window I see this message:
In response to another post on this forum, I tried explicitly adding a dependency in my POM file for slf4j: <dependency> <groupId>org.slf4j</groupId> <artifactId>slf4j-jdk14</artifactId> <version>1.5.6</version> </dependency>
Then mvn eclipse:clean and mvn eclipse:eclipse but this had no affect.
I *think* I've got some version mismatch on slf4j jars but don't know for sure.
Any ideas? ——-
java.lang.NoSuchMethodError: org.objectweb.asm.ClassWriter.<init>(I)V at net.sf.cglib.core.DebuggingClassWriter.<init>(DebuggingClassWriter.java:47) at net.sf.cglib.core.DefaultGeneratorStrategy.getClassWriter(DefaultGeneratorStrategy.java:30) at net.sf.cglib.core.DefaultGeneratorStrategy.generate(DefaultGeneratorStrategy.java:24) at net.sf.cglib.core.AbstractClassGenerator.create(AbstractClassGenerator.java:216) at net.sf.cglib.core.KeyFactory$Generator.create(KeyFactory.java:144) at net.sf.cglib.core.KeyFactory.create(KeyFactory.java:116) at net.sf.cglib.core.KeyFactory.create(KeyFactory.java:108) at net.sf.cglib.core.KeyFactory.create(KeyFactory.java:104) at net.sf.cglib.proxy.Enhancer.<clinit>(Enhancer.java:69) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at org.apache.ibatis.io.ClassLoaderWrapper.classForName(ClassLoaderWrapper.java:191) at org.apache.ibatis.io.ClassLoaderWrapper.classForName(ClassLoaderWrapper.java:91) at org.apache.ibatis.io.Resources.classForName(Resources.java:229) at org.apache.ibatis.builder.xml.XMLConfigBuilder.safeCglibCheck(XMLConfigBuilder.java:171) at org.apache.ibatis.builder.xml.XMLConfigBuilder.settingsElement(XMLConfigBuilder.java:159) at org.apache.ibatis.builder.xml.XMLConfigBuilder.parseConfiguration(XMLConfigBuilder.java:66) at org.apache.ibatis.builder.xml.XMLConfigBuilder.parse(XMLConfigBuilder.java:55) at org.activiti.engine.impl.cfg.ProcessEngineConfigurationImpl.initSqlSessionFactory(ProcessEngineConfigurationImpl.java:389) at org.activiti.engine.impl.cfg.ProcessEngineConfigurationImpl.init(ProcessEngineConfigurationImpl.java:244) at org.activiti.engine.impl.cfg.ProcessEngineConfigurationImpl.buildProcessEngine(ProcessEngineConfigurationImpl.java:221) at org.activiti.engine.impl.test.TestHelper.getProcessEngine(TestHelper.java:211) at org.activiti.engine.test.ActivitiRule.initializeProcessEngine(ActivitiRule.java:104) at org.activiti.engine.test.ActivitiRule.starting(ActivitiRule.java:96) at org.junit.rules.TestWatchman$1.evaluate(TestWatchman.java:46) at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:76) at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50) at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193) at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52) at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191) at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42) at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184) at org.junit.runners.ParentRunner.run(ParentRunner.java:236) at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:49) at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Looks like a version mismatch between the asm we use and the asm that cglib expects. What version of cglib do you see in the dependency-tree (mvn dependency:tree).
Moving this thread to the Activiti Designer-forum.
Did you create a new Activiti project in the Designer? You also executed the mvn eclipse:eclipse command on the project? Did you change the generated pom.xml?
I haven't experienced any problems with slf4j therefore all these questions.
Guys, thx for the quick reply. I solved the problem. I went back and created a new simple diagram and generated the unit test class. When I run this as a Junit through Eclipse, I get an error about a missing class related to registering a Spring bean (org/springframework/beans/factory/support/BeanDefinitionRegistry) . Previously, to solve that problem I had included all the libraries from activiti-5.1\setup\files\dependencies\libs and I picked up an inappropriate version of an slf4j jar file.
I added the same jars as are referenced in the activiti-engine-examples project and the unit test finds all its jars and runs to completion.
Perhaps there's a maven step I previously missed that would have solved the initial problem with not finding the springframework jar? I'll reread doc and see if this was all user error
