Problems running the benchmark in Alfresco 3.3
jmbarroso
I'm trying to run the benchmark following the steps listed on page: http://wiki.alfresco.com/wiki/Server_Benchmarks
When I run the jar (alfresco-bm-3.3.jar):
java -Xmx128M -jar alfresco-bm-3.3.jar –username=admin –password=admin –config=test.properties
I get the error:
A failure prevented proper execution.
            at java.io.File.<init>(File.java:222)
            at org.alfresco.repo.model.filefolder.loader.FileFolderRemoteLoader.makeSession(FileFolderRemoteLoader.java:164)
            at org.alfresco.repo.model.filefolder.loader.FileFolderRemoteLoader.initialize(FileFolderRemoteLoader.java:69)
            at org.alfresco.repo.model.filefolder.loader.FileFolderRemoteLoader.main(FileFolderRemoteLoader.java:386)
            at com.simontuffs.onejar.Boot.run(Boot.java:287)
            at com.simontuffs.onejar.Boot.main(Boot.java:137)
test.properties file has the following parameters:
    session.name=TEST
    Session.sourceDir=/opt/jboss/actuacion/loadTest/test
    session.rmiUrls=rmi://localhost:50500/
    session.storeIdentifiers=workspaceStore
    session.folderProfile=1, 5
    test.load.upload.fast=2, 0, 1, 2, true, 1
    test.load.totals.basic=1, 15000, 0, 1, true
What am I doing wrong?
Thanks!
9 REPLIES 9
mrogers
Is probably due to your upper case 'S' in session.
It's clearly a small bug, the configuration file should be validated and you should get a sensible error message.
jmbarroso
Thank you very much, the problem was the upper case 'S'. I checked the file a thousand times and I did not see the error.
Now I have another error:
ERROR: Failed to establish connection to server:
   Server: rmi://localhost:50500/
   Error:  org/aopalliance/intercept/MethodInterceptor
java.lang.NoClassDefFoundError: org/aopalliance/intercept/MethodInterceptor
        at java.lang.ClassLoader.defineClass1(Native Method)
        at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
        at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
        at com.simontuffs.onejar.JarClassLoader.defineClass(JarClassLoader.java:626)
        at com.simontuffs.onejar.JarClassLoader.findClass(JarClassLoader.java:532)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
        at org.alfresco.repo.remote.FileFolderRemoteClient.connect(FileFolderRemoteClient.java:61)
        at org.alfresco.repo.remote.FileFolderRemoteClient.<init>(FileFolderRemoteClient.java:55)
        at org.alfresco.repo.model.filefolder.loader.LoaderSession.connect(LoaderSession.java:189)
        at org.alfresco.repo.model.filefolder.loader.LoaderSession.initialize(LoaderSession.java:122)
        at org.alfresco.repo.model.filefolder.loader.FileFolderRemoteLoader.makeSession(FileFolderRemoteLoader.java:226)
Caused by: java.lang.ClassNotFoundException: org.aopalliance.intercept.MethodInterceptor
        at com.simontuffs.onejar.JarClassLoader.findClass(JarClassLoader.java:535)
        … 27 more
No remote servers are available
But the RMI port is listening:
 netstat -a | grep 50500
tcp        0      0 *:50500                     *:*                         LISTEN
To enable RMI API, I followed the steps in the wiki (http://wiki.alfresco.com/wiki/Server_Benchmarks) and added to the folder '/ WEB-INF/classes/alfresco /
extension / ' the following xml: bm-remote-loader-context.xml
cat bm-remote-loader-context.xml
<!DOCTYPE beans PUBLIC "-//SPRING/DTD BEAN//EN"
    "http://www.springframework.org/dtd/spring-beans.dtd">
<beans>
    <!– Remote FileFolderService exposure –>
    <bean id="fileFolderRemoteServer" class="org.alfresco.repo.remote.FileFolderRemoteServer">
        <property name="transactionService">
            <ref bean="TransactionService"/>
        </property>
        <property name="fileFolderService">
            <ref bean="FileFolderService"/>
        </property>
        <property name="authenticationService">
            <ref bean="AuthenticationService"/>
        </property>
        <property name="mimetypeService">
            <ref bean="MimetypeService"/>
        </property>
    </bean>
    <bean id="fileFolderRemoteRMI" class="org.springframework.remoting.rmi.RmiServiceExporter">
        <property name="service">
            <ref bean="fileFolderRemoteServer"/>
        </property>
        <property name="serviceInterface">
            <value>org.alfresco.service.cmr.remote.FileFolderRemote</value>
        </property>
        <property name="serviceName">
            <value>org.alfresco.FileFolderRemote</value>
        </property>
        <property name="registryPort">
            <value>${alfresco.rmi.services.port}</value>
        </property>
    </bean>
    <!– Remote Loader exposure –>
    <bean id="loaderRemoteServer" class="org.alfresco.repo.remote.LoaderRemoteServer">
        </property>
        </property>
        <property name="nodeService">
            <ref bean="NodeService"/>
        </property>
        <property name="nodeDaoService">
            <ref bean="nodeDaoService"/>
        </property>
        </property>
        </property>
        <property name="checkOutCheckInService">
            <ref bean="CheckoutCheckinService"/>
        </property>
        <property name="fileFolderRemote">
        </property>
    </bean>
    <bean id="loaderRemoteServerRMI" class="org.springframework.remoting.rmi.RmiServiceExporter">
            <ref bean="loaderRemoteServer"/>
        </property>
            <value>org.alfresco.service.cmr.remote.LoaderRemote</value>
        </property>
            <value>org.alfresco.LoaderRemote</value>
        </property>
        </property>
    </bean>
</beans>
Any ideas?
Regards!
mrogers
Issue ALF-2224.   You need to add aopalliance.jar to your classpath.
jmbarroso
You're right,  adding the library solves the problem, thank you very much.
Now appears another error. I think it's another bug (ALF-5733😞
java -classpath '.:/opt/jboss/actuacion/loadTest/aopalliance.jar:/opt/jboss/actuacion/loadTest/alfresco-bm-3.3.jar' com.simontuffs.onejar.Boot –username=admin
   Server: rmi://localhost:60600/
   Error:  Could not find RMI service [rmi://localhost:60600/org.alfresco.FileFolderRemote] in RMI registry; nested exception is java.rmi.NotBoundException: org.alfresco.FileFolderRemote
org.springframework.remoting.RemoteLookupFailureException: Could not find RMI service [rmi://localhost:60600/org.alfresco.FileFolderRemote] in RMI registry; nested exception is java.rmi.NotBoundException: org.alfresco.FileFolderRemote
        at org.springframework.remoting.rmi.RmiClientInterceptor.lookupStub(RmiClientInterceptor.java:211)
        at org.springframework.remoting.rmi.RmiClientInterceptor.prepare(RmiClientInterceptor.java:147)
        at org.springframework.remoting.rmi.RmiClientInterceptor.afterPropertiesSet(RmiClientInterceptor.java:135)
        at org.springframework.remoting.rmi.RmiProxyFactoryBean.afterPropertiesSet(RmiProxyFactoryBean.java:68)
        at org.alfresco.repo.remote.FileFolderRemoteClient.connect(FileFolderRemoteClient.java:65)
Caused by: java.rmi.NotBoundException: org.alfresco.FileFolderRemote
        at sun.rmi.registry.RegistryImpl.lookup(RegistryImpl.java:106)
        at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
        at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef.java:386)
        at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:250)
        at sun.rmi.transport.Transport$1.run(Transport.java:159)
        at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
        at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
        at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
        at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
        at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(StreamRemoteCall.java:255)
        at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:233)
        at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:359)
        at sun.rmi.registry.RegistryImpl_Stub.lookup(Unknown Source)
        at java.rmi.Naming.lookup(Naming.java:84)
        at org.springframework.remoting.rmi.RmiClientInterceptor.lookupStub(RmiClientInterceptor.java:200)
        … 16 more
Maybe I should try the 3.4 benchmark.  I hope not to get in trouble for running alfresco-bm-3.4.jar on alfresco 3.3 server.
Regards,
Juanma
[EDIT]
Using the version of alfresco-bm obtained from alfresco-community-3.4.d.zip I have the same fault.
Any ideas to help me to launch the benchmark?
Thanks !!
mrogers
Why are you trying to connect to 60600?    Your config above was for the default value of 50500.
rmacian
jmbarroso
Also changed the port in the config. I wanted to verify that the problem was not the port.
http://forums.alfresco.com/es/viewtopic … 749#p13749 same question on spanish forum
I asked on both forums, hopefully not a problem. Normally in this forum will get more answers Smiley Tongue
jmbarroso
I solved the problem using the benchmark of alfresco 3.4 and copying bm-remote-loader-context.xml in a new alfresco instalattion.
Now I have the problem of not being able to connect from another machine, but I understand that this is another problem.
Thank you very much for the help!
sharifu
How would i benchmark on 4.0d?
this is what i am doing
[root@alfrescotest indexing]# java -Xmx128M -jar bin/alfresco-bm.jar –username=controlRole –password=1234 –config=test.properties
java.lang.NoClassDefFoundError: org/alfresco/repo/security/permissions/PermissionCheckValue
   at org.alfresco.repo.model.filefolder.loader.FileFolderRemoteLoader.makeSession(FileFolderRemoteLoader.java:216)
Caused by: java.lang.ClassNotFoundException: org.alfresco.repo.security.permissions.PermissionCheckValue
   … 16 more
I have enabled bm-remote-loader-context.xml
my test.properties have values taken from  http://wiki.alfresco.com/wiki/Server_Benchmarks
session.name=TEST
session.sourceDir=/opt
session.storeIdentifiers=TEST-01, TEST-02, TEST-03, TEST-04, TEST-05
session.folderProfile=1, 10, 10, 10, 10, 10
test.load.upload.fast=2, 0, 10000, 6, false, 1
#test.load.totals.basic=1, 15000, 0, 1, true
